Is tire rotation "required maintenance"?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by cutter44, Oct 5, 2015.
  1. cutter44
    cutter44 Member
    213
    MA
    This is probably a silly question, but I'm trying to be particularly careful about covering my butt, especially after spending extra $$ for an extended warranty.
    Anyway, I know tire rotation is recommended at 5k, but I can't imagine it being required to keep warranty valid. Here's the situation. According to the 5k recommendation, I was planning on rotating my tires today, as I just turned over 45k miles and I last did them at 40k. However, in another couple of months and a few thousand more miles I'm going to be swapping over to my winter/snow tires. At that point, it will have been about 8k miles between rotation. Hell, I know some people never rotate their tires. I used to do them on other vehicles I've had at anywhere from 7500k to 10k miles.
    Which brings me back to the original question. 5k miles is just a recommendation, right? No potential (warranty) issues down the road if I forgo it for another 3k miles? Seems a little silly to do it now.
    Thanks.
  2. E Risch
    E Risch Junior Member
    49
    Nashville
    You may want to consult your particular warranty statement, But tires are have their own manufactures warrenty
  3. cutter44
    cutter44 Member
    213
    MA
    Yeah, I should have clarified. I'm not worried about the tire warranty (I've never seen a tire warranty worth much of anything in normal use). I was concerned about whether it might impact Toyota's warranty on the rest of the vehicle.
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    I don't know.
    My approach as long as I was under "Toyota Care"--first two years, with no extended warranty, was to let the dealership do the rotations, when I let them do the Oil Changes.
    Then at least it was in the service records.
    Past that point I expect it's up to me. And my continued philosophy is that tire rotations are cheap, easy...usually quick.
    I have the original OEM tires, so I'm probably nearing borrowed time with them anyway. But when I replace, I'll choose a place that offers free rotations.
  5. E Risch
    49
    Nashville
    between the tire and the car it makes no difference, however I cant speak of your "extended", your at the mercy of how the policy statement is written, especially if it says anything about tires.
    I have driving off the lot and immediately replaced the tires and no one ever said a word throughout the service period of the warranty. never had an "extended" though.
  6. X HCH2
    X HCH2 Member
    119
    38
    Upstate SC
    Tire rotation primarily is to extend the life of your tires. I don't think Toyota cares about your tires a bit, as items of normal wear. It's up to you.
    X
  7. HGS
    HGS Member
    307
    122
    I think you're probably OK not rotating the tires. I agree that Toyota doesn't care about your tires. The tire warranty could be affected, is about the only thing. If they are the original tires, there's not much warranty left with that mileage.
  8. cutter44
    cutter44 Member
    213
    MA
    Thanks.
    Yeah, the OEM tires are long history. I bought the car used with 34k miles on it and the dealer included a set of brand new new Hankook Optima 426 tires. Whether or not they're great tires, I wasn't expecting them as I had already made the deal figuring I'd just get the used ones that were on the car when I test drove it, so I was happy.
    I'm not going to worry about it. I can't imaging my not rotating tires at (a very conservative) 5k miles will have any impact on the rest of the vehicle's warranty.
  9. HGS
    HGS Member
    307
    122
    Right. It would be sad and funny at the same time if they wouldn't fix a problem because the tires were not rotated. Like they would say, "we're not covering your power steering failure because your tires weren't rotated". One does not have anything to do with the other.
    Cheers!
  10. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    I'd be spending my worries and anxiety cycles getting the extended contract money back,
    E Risch likes this.
  11. The Electric Me
    9,083
    5,798
    Yeah, even though my personal approach is to just go ahead and rotate tires, because it's usually cheap (free) and easy, my speculation is that it wouldn't have any affect on the warranty coverage of the rest of your vehicle.
    Toyota would have to prove that whatever components failure was a direct connection to not rotating your tires, which I would think would be nearly impossible.
    As long as all your tires are in "safe" and operational condition, I don't see how Toyota could deny coverage.
  12. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Cutter if we assume MA means Massachusetts, then you are in the US and the Magnuson–Moss Warranty Act applies.
    The warrantor has to prove your action caused parts to fail; if you did not rotate the tires, it would be easy to prove that is why the tires failed, but it is wildly unlikely they could prove that unrotated tires caused the paint to fade.
    "In addition, the warrantor may not impose any duty, other than notification, upon any consumer, as a condition of securing the repair of any consumer product that malfunctions, is defective, or does not conform to the written warranty. However, the warrantor may require consumers to return a defective item to its place of purchase for repair." So there really is no required maintenance, just suggested maintenance. If you fail to follow the suggestions, that gives the warrantor a defense he did not have. Magnuson–Moss Warranty Act - Wikipedia, the free encyclopedia
  13. bisco
    49,075
    i'm thinking, what if the tyres start wearing in a funny pattern, it affects your alignment and causes premature front end wear and rear?
  14. Mendel Leisk
    38,325
    I never "rotate" the tires, per se. Having snow tires on separate rims, I just incorporate the rotation into the switch over.
    Tire rotation is purely to extend tire life, it would have no bearing on other mechanical items. One caution, beside tire rotation there's visual brake inspection, and fluid level check. So take a quick look at the brakes and check the dipstick.
  15. davidc83
    davidc83 Member
    113
    50
    Scottsburg, Indiana
    2015 Prius c
    Just rotate the tires yourself or write down in the maintenance log the tires were rotated. It is illegal in the United States for any car manufacturer to insist warranties are invalid if maintenance not done by certified tech or dealer. Anyone can do the maintenance as long as you can prove (receipts) or log (any type of maintenance log) can be provided-and if they try; lawsuit in federal court and you will win.
  16. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    I can't imagine any instance where not rotating tires would cause warranty problems if anything else has issues. Don't worry about it.
    Tire rotation is so that your tires wear evenly, front to back. You don't even HAVE to rotate if you don't care about that. You would just replace the front tires and motor on. The only problem with that would be your rear tires would age and sun crack, which might cause problems of their own...after 5 yrs on the job.
  17. Mendel Leisk
    38,325
    One spin-off of brake rotation is it's hand-in-hand with brake inspections, which are also part of maybe every other maintenance interval.
  18. cmstlist
    cmstlist Member
    183
    40
    Toronto, ON
    Incidentally I contacted a local Toyota dealership to inquire about swapping my winter tires-on-rims and storing them. I was told that if I'm going to be taking in my car for the annual Maintenance Service anyway, it includes a tire rotation and they can put on the winter tires in lieu of said rotation. I suppose when switching back I could ask them if they'd typically carry out a "rotation" when putting them back?
  19. Mendel Leisk
    38,325
    Yes. They mark the location the tires come off of, then swap them front to back at next install.
  20. cmstlist
    cmstlist Member
    183
    40
    Toronto, ON
    There you go. So if you use two sets of tires per year anyway you don't need to explicitly get them rotated (unless you're using the car very heavily?).
