Jump-Starting Weirdness, 100 Amp Fuse
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cb474, Jul 29, 2010.
  1. cb474
    cb474 Junior Member
    MC
    I experienced some weirdness trying to jump start a friends 2001 Prius and the 100 amp fuse got blown. I'm trying to figure out what happened.
    I read the user manual and am pretty positive that I did not reverse polarity on the auxillary battery, with the jumper cables. But as soon as I hooked up the cables the headlights and taillights came on, as well as both turn signal lights steady on, and I couldn't turn them off. I checked and checked. The key wasn't in. All the headlight switches were off. I just couldn't figure it out. After trying to let the auxillary battery charge for a while this way, the car was still totally dead and it was weird and I gave up.
    The next day my friend called AAA and they couldn't start it either. But she said they were pretty clueless, refusing to believe at first that the battery was in the trunk, and suspects maybe they reversed the polarity on the cables when they tried to jump it. She didn't see the headlights come on this time (although it was now during the day).
    So I'm trying to figure out 1) What was the deal with the headlights coming on? 2) Did I blow the fuse or the AAA guy or was it already blown for some reason? Are there other ways to blow the fuse than by reversing polarity?
  2. Patrick Wong
    18,200
    6,464
    Are you referring to the 100A DC/DC fuse? If the DC/DC fuse popped, that is evidence that the battery polarity was reversed, as the DC/DC converter output circuits will present a short to a reversed battery. In that case there's a good chance that the inverter will need to be replaced (which will probably cost around $3K at the Toyota dealer.)
    The lights are controlled by the light switch. However the body ECU is also in the circuit. It could be that the application of reverse polarity voltage caused that ECU to turn the lights on.
    The only other way to blow the 100A DC/DC fuse would be if the car was READY and then a sizable short developed from the 12V bus to ground, sufficient to conduct 100A+ so that the fuse would blow.
  3. cb474
    cb474 Junior Member
    MC
    Thanks for the explanations.
    I think it was the 100A DC/DC fuse. My friend took the car to the dealer and they just said the 100A fuse blew. I know they had to take the whole fuse box out to get at it, which sounds like the DC/DC fuse as I've seen it decribed online. Whatever fuse they replaced, that was all it took. So I guess the inverter was fine.
    What's the body ECU?
    When I was trying to figure out what was going on with the lights, I disconnected and reconnected the jumper cables and the lights would go on only with the jumper cables connected and then slowly fade out once they were disconnected. If the polarity was reversed, would that makes sense that the power coming from the other car could still be powering the headlights on the prius?
    Also I'm assuming it's not normal for the headlights to come on from hooking up jumper cables?
  4. Patrick Wong
    18,200
    6,464
    It's great to hear that the inverter was not damaged. You (and your friend) are extremely lucky!
    I'm not sure how to interpret why the lights "slowly fade out". If the polarity of the jump battery was reversed, that would force substantial current flow through the Prius 12V battery. Maybe that had the effect of slightly charging the Prius battery so that it would power the lights for a brief moment after you disconnected the jump cables.
    The body ECU controls miscellaneous systems. For example it keeps track of whether the doors, trunk and hood are open or closed. It controls the interior lighting and allows the gradual dimming of the lights when you enter the car and then close the door. Minor things like that.
    The headlight switch provides ground to the taillight and headlight relay coils, thus energizing the relays so that the lights will come on.
    However the body ECU is also connected in parallel with the switch, so if you had the switch off, then I assume the body ECU was effectively providing ground to the relay coils so that the lights would turn on.
    It definitely is not normal for the headlights to come on when jumping the car, assuming that the headlight switch is off. That would almost be like a Stephen King novel.
  5. cb474
    cb474 Junior Member
    MC
    Thanks again for all the explanations of how these systems work. It was very weird. I kept checking the headlight switch, but it was definitely off.
    Yes, the way the headlights faded when I disconnected the jumper cables was as if there was a little charge in the battery that was fading quickly.
    I did notice when I hooked up the ground jumper cable to the trunk latch in the Prius, completing the circuit, that there were a lot of sparks. I'm used to a few sparks, with that final connection when jumping a car, but this seemed like more than usual, though not alarmingly so. Could that be a sign that I was the one who reversed the polarity? (As opposed to the AAA guy who came the next day and who my friend said was surprisingly clueless about how to jump start a car.)
    Thinking back over it, I'm sure I didn't reverse the polarity on the Prius. But maybe I did on the battery in my car. Although I've jumped many cars over the years and never done that. Come to think of it, though, should reversing the polarity have also then blown fuses in my car (2006 Mazda3)?
  6. Patrick Wong
    18,200
    6,464
    Yes, if you see considerable sparking, that is evidence that the current flow is abnormally high. That would be due to incorrect battery polarity or an electrical short.
    Incorrect polarity would not affect your Mazda donor vehicle because 1) the jump cables are attached directly to the Mazda battery so no fuses are in the loop and 2) the Prius battery was dead or close to dead, so it would not be able to reverse the battery voltage polarity as seen by the Mazda's electrical systems.
    Now, if the Mazda was the recipient vehicle with a dead battery and you were jumping it from another vehicle with a good 12V battery and reversed battery polarity, then you would probably destroy the Mazda's alternator, as the diodes within would be blown. However it's a lot easier and cheaper to replace an alternator than it is to replace a Prius inverter.
  7. richard schumacher
    7,663
    1,038
    United States
    You were very lucky not to have destroyed anything more expensive than that fuse.
    General rule: when you do something, and weird and/or alarming sh!t happens, immediately undo whatever you did.
  8. cb474
    cb474 Junior Member
    MC
    Okay, thanks for all the thoughts and replies, Patrick.
  9. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    One cannot take somebodys word that the cable in your right hand is POSITIVE, you must walk up to the donor vehicle and verify that that cable is connected to the plus or the larger terminal, then connect, THEN, deal with the negative cable in exactly the same manner. It is sometimes somewhat difficult to discern the positive from the negative terminals. To pre-verify the positive cable under adverse conditions ( a storm ) strike the assumed pos to ground, IF, you get a myriad of sparks .........that's POSITIVE!
  10. Sandy Meyers
    Sandy Meyers Member
    153
    56
    Los Angeles
    2002 Prius
    I
    Patrick, I did the same thing, hooked up a booster pack, and it appears the 100A fuse is blown, from the reverse polarity. However, when I left the car for a time, after the car door was opened and closed, ignition turned on and off, battery cables were reconnected, and I opened the car door, the car horn set itself off and would not stop, until I disconnected the battery. Now I have nothing? What do you make of this? Is it simply the 100 amp, or is likely I also fried the inverter?
  11. Patrick Wong
    18,200
    6,464
    Hi Sandy,
    I don't know why the horn would be blowing. Does the car have an aftermarket alarm system? I suggest you disconnect the horn for now, while troubleshooting.
    See if you can find any other blown fuses. Remove each fuse, one at a time, and measure continuity with an ohmmeter. Do not rely on visual inspection. Replace all damaged fuses and make a list of their names for future troubleshooting reference.
    While you are checking the fuses, put a charger on the 12V battery. Make sure the battery is fully-charged or replaced with a new battery if the existing battery cannot be charged. Your problem started with a botched jumpstart so apparently the 12V battery was not in good condition at the time you decided a jumpstart was required.
    The goal is to get the Prius to the point where you can make it READY again. Once it becomes READY, measure voltage across the 12V battery. If much less than ~13.8V, then the DC/DC converter in the inverter has failed.
  12. Sandy Meyers
    Sandy Meyers Member
    153
    56
    Los Angeles
    2002 Prius
    I
    Hi Patrick, thanks for the info.
    The alarm is the manufactured installed alarm.
    I don't have tools to test the fuses, or diagnostic tools for reading codes.
    I've been researching a bit online. Trying to locate someone who can possibly do install of the 100 amp and a salvage inverter if it is fried. Any suggestions for contacting someone in Los Angeles/ Orange County area? I'm located in the Long Beach/airport area. I don't want to give up this car, I'm original owner with 93,000 miles and the care is in running great shape.
    Many thanks.
