jump terminals on a 2013 prius c (under the hood) There or Not
Discussion in 'Prius c Main Forum' started by john roman, Apr 9, 2013.
  1. toyotechwv
    toyotechwv Toyota Technician
    474
    251
    Princeton, WV
    Should be plug and play, you already have a heavy gauge wire coming into that block which should be where they tap into for the terminal. If anyone is near southern WV i'd be willing to swap yours and take pics.
    SPH-D710 ? 2
  2. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    so for the people who dont have the jump connection (i still havent checked my C1 for it) there is already a heavy gauge positive wire coming there? the main reason i ask is because when i do hids, i want to do 55w but i want to run a relay. and if theres no positive heavy guage wire under the hood then i will not install 55w and get 35w.
  3. toyotechwv
    474
    251
    Princeton, WV
    If you look at John's pics on the first page, the empty area where the terminal should be you can see a bolt head with a red line down near the white connector towards the bottom of the pic. That is the feed wire for that terminal from what I can see on our Habanero C. BTW, someone called the dealer a bit ago from FL and asked one of our advisors about this. Call back and ask for me if you have further questions. If someone will provide me their VIN and pic (John?) of their 2013 that DOES NOT have the terminal, I will submit a DPR to Toyota regarding this issue.
  4. john roman
    john roman Junior Member
    35
    I went to the web site but couldnt sende pics my number is 904-248-8350 i can text you them.
  5. toyotechwv
    474
    251
    Princeton, WV
    ********Disclaimer********* Toyota has not authorized this repair, this will be considered a non-OEM modificaion if you have this performed on your vehicle.
  6. john roman
    35
    even though other 2013s have them it should be covered if others have them on it, i want to get it done it will be eaiser to do a jump
  7. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    So what exactly IS considered an OEM modification?
  8. toyotechwv
    474
    251
    Princeton, WV
    Accessories and parts listed for your vehicle by VIN. As noted the updated P/N for that block is for after 12/12 production. Unless they issue a TSB (which is why I'm submitting a DPR) you're installing a part that technically "wasn't designed for your vehicle". Am I saying it won't work, no. I'm confident that it should. Just be prepared to hear something similar from your dealer when you ask them to swap it.
  9. toyotechwv
    474
    251
    Princeton, WV
    My Parts Manager has agreed to order both blocks so I can compare them side by side. Will post pics when we get them.
  10. john roman
    35
    i did make a claim with toyota headquarters, my thing is the part is for a 2013 when it was manafactured shouldnt matter, and it should be taken care by toyota and be warranted.
  11. toyotechwv
    474
    251
    Princeton, WV
    On the Toyota parts system that part is listed by production date. Though I agree with you, they can argue that point based on the information given.
  12. john roman
    35
    so basically they probably are not going to cover it, im just waiting to see what the service mgr finds out.
  13. B2FiNiTY
    B2FiNiTY Active Member
    979
    226
    can't wait to see this
    ztanos likes this.
  14. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    So technically, HID lights are non-OEM parts. Homelink mirrors, backup cameras and rear hatch lights are all non-OEM parts as well.
  15. toyotechwv
    474
    251
    Princeton, WV
    If they want to be picky, yes. Of course you're in SET region so that's even worse. There is always a battle with them when we get an SET vehicle that has an issue with one of their "OEM" parts.
    ztanos likes this.
  16. john roman
    35
    I just got a call from the service manager from the dealer, and he stated that 2013 prius c do not have a jump terminal in the fuse box. He checked with southeast toyota and called out to tecnical support on califorinia and the is no terminal under the hood in the fuse box. im so confused ive seen pictures i dont know what to do.
  17. kingnba6
    1,018
    242
    NY
    i checked my 2013 c1 i bought in march. no jump terminals in mine.
  18. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    Was the production date 12/12?
  19. kingnba6
    1,018
    242
    NY
    i didnt have a chance to check that, it slipped my mind. that would be located on the door tag right?
  20. B2FiNiTY
    979
    226
    sounds like the only way to get it is to modify it yourself.
    since nowhere is toyota advertising this feature, they aren't liable to "modify" your car to have it.
