Just hooked up ScanGauge II & immediately got these error codes
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Green Hokie, Sep 16, 2007.
  1. Green Hokie
    Green Hokie Member
    189
    Glen Allen, VA
    U0100
    U0111
    What do these two error codes mean?
    Here's what I did.
    1. Prius was completely off.
    2. Connected the supplied cable from SGII to the OBDII plug.
    3. Noticed that the SGII was attempting to connect to the Prius but I think it could not since the Prius was completely off.
    4. Pressed the POWER button on the Prius twice (without depressing the brake pedal) to bring the vehicle into the "IG-ON" mode where all accessories are functional.
    5. The word "problem" immediately appeared on the upper left-hand corner of the MFD screen. Also, the master warning light (large triangle w/ exclamation mark) appeared on the main instrument cluster.
    6. Pressed the Prius POWER button again to turn everything off.
    7. Then, while depressing the brake pedal and I pressed the POWER button to turn the vehicle completely on.
    8. Got the same two messages as noted above in step #5.
    9. Pressed "scan" on the SGII and got the two codes mentioned at the very top.
    10. Pressed "clear codes" on the SGII.
    11. As expected, both error/warning messages on the MFD & instrument cluster went away.
    I haven't driven the Prius to see if everything works normally. The ICE did run for a few moments, as it always does after you first turn the vehicle on. I think/hope everything is OK.
    Any ideas why I got those two error/warning messages?
  2. galaxee
    galaxee mostly benevolent
    9,810
    466
    MD
    those are CAN communication errors. it may be a fluke, they may stay gone. unfortunately, they may not.
    if they come back, get that SG out of there and head to the dealer.
  3. Green Hokie
    Green Hokie Member
    189
    Glen Allen, VA
    Thank you, Galaxee. I'm hoping those two trouble codes appeared simply because I did not have the Prius completely on before connecting the SGII to the OBDII plug. The SGII instruction manual does say to turn the vehicle on before plugging it into the OBDII plug... which I did not do. That would explain why the SGII could not initially communicate with the Prius. Perhaps this was when those two CAN communication errors actually occured.
    I'll just have to keep an eye on it & hope those error messages don't return. I'll also contact Linear-Logic tomorrow to see if they can offer any explanations.
  4. galaxee
    9,810
    466
    MD
    an interruption or an abnormal spike on the CAN lines can cause that.
    one can plug in something to the DLC3 port at any time. if the SG simply can't communicate with the prius, oh well, the prius can still communicate with itself. when the prius can't communicate with itself, then you start to get codes.
    is that making sense?
  5. Green Hokie
    Green Hokie Member
    189
    Glen Allen, VA
    Yes. Thanks again, Galaxee.
  6. Highly ImPriused
    Highly ImPriused Impressive Member
    250
    Western NY
    I just received my scan gauge (as a birthday gift no less) and had the same problem after hooking it up tonight, except that my second code was different. The two I got were:
    U0100
    U0293
    I basically did the same thing described by the OP above. I was also able to clear the codes, but it took a few restarts to get the "red triangle of death" to disappear. Gave me quite the scare for a few tense minutes there. I assume this was a CAN communication error as described above caused by starting my Prius with the scan gauge attached rather than starting it first and then connecting the scan gauge to allow it to initialize properly.
    Green Hokie, if you're still out there, did those codes ever come back for you?
  7. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    If the SG is causing canbus transients that kick U codes, then
    that sounds like a problem Ron needs to look at asap. Other scan
    tools don't do that.
    _H*
  8. Highly ImPriused
    250
    Western NY
    <div class='quotetop'>QUOTE(hobbit @ Nov 2 2007, 01:28 AM) [snapback]533732[/snapback]</div>
    Is Ron with LinearLogic? Do you have contact information or just go through their website.
    In fairness, the owner's manual does state to turn the vehicle on prior to connecting the SG the first time. In both my case and that of the OP, we hooked up the SG initially prior to turing our Prius on in accessory mode. The codes did clear, the car operated normally this morning, and the SG seems to be functioning properly.
    I should have read and followed the owner's manual more carefully before connecting the SG. However, it would be nice if it explicitly stated that connecting the SG for the intitial time prior to starting the car can cause CAN communication errors. I don't know if this is a Prius-specific problem or not.
  9. Green Hokie
    Green Hokie Member
    189
    Glen Allen, VA
    <div class='quotetop'>QUOTE(Highly ImPriused @ Nov 1 2007, 09:00 PM) [snapback]533640[/snapback]</div>
    Hi there. Fortunately, not. Everything appears to be working just fine.
    If I see any more CAN communication errors, I will definitely report this to Ron at Linear-Logic and request either a new SG or a refund.
    <div class='quotetop'>QUOTE(Highly ImPriused @ Nov 2 2007, 08:55 AM) [snapback]533805[/snapback]</div>
    You can call their toll free number and ask for Ron DeLong.
  10. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Yeah, I know I'm bumping an ancient thread, but +1 for me.
    I hooked up my SG today before powering on (have done this a few times) and hit the exact problems at the OP. I also got the red triangle of death, the yellow check engine light and a red car w/a ! on the MFD. I believe my power up was w/my foot on the brake.
    IIRC, the triangle of death, CEL and ! car on the MFD went after a few power cycles. ScanGauge showed codes U0100 and U0111 were stored.
    Luckily, I was leaving from the Toyota dealer after getting LSC A0N (inverter pump change) done and my transmission fluid changed. Hope it was just a fluke from my user error and me not following SG directions.
    2 people like this.
  11. snookums
    snookums Junior Member
    85
    16
    The 'Sauga, Ontario
    +1 for me yesterday when leaving work.
    Plugged in my SG2 after turning the car off, when I turned it back on the SG2 said "Connecting..." and just after putting it in reverse and putting my foot on the go pedal the red triangle of death, check engine, red "problem" icon on the MFD.
    Turned the car off and on about 5 times and it went back to normal. The SG2 shows U0100 and P0000; P0000 means the SG2 didn't read the code properly right?
  12. philmcneal
    philmcneal Taxi!
    332
    Simcoe Ontario
    I got the symptoms same as OP however mine happened after 10 mins of driving ... I was accelerating and I heard a nasty bump that you feel when the engine turns off and I was running on ev only .
    I stopped and I couldn't power off the car and I can hear the fans running near the radiator . At this time the car gave me codes U0100 And U0293 ... Clearing the codes did nothing and after waiting for the fan to die down I can finally power off the car ... Losing engine power was scary ... I wonder by clearing the codes and not using scangauge would prevent the problem?
    Freaked me out though as it happened as I was traveling at 56km per hour ... And then having no engine power ... And two icons came up ... One was the car with (!) and the other was the letters in caps PS...
    This sucks :(
  13. jdenenberg
    jdenenberg EE Professor
    3,863
    1,865
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The manual says to turn your car on BEFORE plugging in your ScanGauge. Plugging it in with the car off intermittently causes CAN communication errors. It is OK to leave it plugged in between trips.
    JeffD
  14. stefano5777
    stefano5777 Member
    380
    47
    St. Petersburg Florida
    Glad you said that Jeff as I leave my scangauge plugged in at all times with no ill effect.
  15. ilip88
    ilip88 New Member
    Boulder Colorado
    I have a 2004 Prius and I have a scanner to look for check engine light codes which says to plug it in and then turn on the ignition of the car without turning on the engine. Which of course means pressing the button twice without foot on the break. I made the mistake of pressing the button once which means the ignition was not on and so the scanner started looking for codes and I turned on the car and I got the master warning light and the same other lights that Green Hokie got came on including the check engine light ( which may have already been on) and then I pressed the button on my scanner and it gave me the codes U0100 and P0000 and U0293. Codes that had been previously on there which I hadn't cleared were gone. Is it possible that because I had plugged in the scanner and had only pressed the ignition switch once which only turns on the MFD and not the ignition and pressed the button on the scanner could have caused me to have the Master Warning light come on along with getting the codes I got when I did have the car turned on?
  16. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    778
    514
    Outside Philly, PA
    As mentioned earlier those are "lost communication" codes because the ECUs were not talking because they weren't powered up.
    Reconnect the proper way and I expect those issues won't reoccur, unless your connection to the car is loose.
  17. ilip88
    ilip88 New Member
    Boulder Colorado
    So I didn't cause any permanent problem with the car communicating with itself by improper use of the scanner? So those codes are not going to be trigged again just because I connected the scanner wrong which will cause the cars ECU's not to communicate properly on their own without having used the scanner again? In other words by clearing the codes they shouldn't come back on their own unless something is wrong with the car not caused by connecting the scanner wrong?
  18. ilip88
    ilip88 New Member
    Boulder Colorado
    I wouldn't head to a dealer I would find a good mechanic like I found where I live who works on hybrids because the dealer will charge you a lot more to fix the problem. I had to get an extra key fob made for my car which my mechanic charged me $150.00 for at the dealer it would have cost more then $300.00 dollars. I need it in case I lose the one I already had because if you lose it then you are screwed if you don't have another one.
  19. ilip88
    ilip88 New Member
    Boulder Colorado
    Why would those codes cause the master warning light and the light on the MFD warning of a problem with the hybrid batteries to come on? Is because the ECU's were not communicating so the car thinks the hybrid batteries are not working right?
