Keeping the 12V Battery Alive
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sumedha, Aug 13, 2013.
  1. Sumedha
    Sumedha Junior Member
    52
    Colombo, Sri Lanka
    I am going out of the country for 2 weeks and I am wondering whether my 12V battery will hold up until I come back. Usually, it dries up when the car is not running for 2 weeks and I have experienced it a whle back.
    I had a Mazda Protege before and I asked my father to start it and keep the engine running for about 10 minutes to get it 12V battery charging.
    I can ask my father to start it. But Prius usually starts with ICE OFF and in this situation, can it charge the 12V battery or what do I need to do to keep the juice in for 2 weeks ?
  2. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
  3. Britprius
    Britprius Senior Member
    5,194
    1,912
    Herefordshire England
    The Prius engine does not need to run to charge the battery "it has no alternator in the normal meaning". All the car needs is to be made ready and left in park, this will charge the 12 volt battery.
    If the car is normally parked outside a solar charger will keep the battery happy. Failing that a battery tender left on for the duration will work well.
    Another option is to disconnect the 12 volt battery at the negative terminal, but this has the disadvantage of loosing radio presets and auto window settings "no big deal".
    John (Britprius)
  4. prev93
    prev93 Member
    63
    Califon, NJ
    I left my car in the garage for a month with no ill effect.
  5. Figgy
    Figgy New Member
    Santa Monica, CA
  6. Figgy
    Figgy New Member
    Santa Monica, CA
    To keep the Prius battery alive while traveling for weeks with a Solar Power Battery Charger that I bought for around $27 on Amazon.com. The brand I got is Wagan Tech. Best thing I ever did. I usually go away for around 6 weeks at a time and had to ask friends to turn on the car and drive it around. Not anymore! My car is in a garage with dim light and it still works. I didn't get this answer from Toyota. They never helped me when I first tried to find a solution. It was the guy from the Triple A who told me what to do as he charged my dead battery. He said everyone with a Prius had this problem.
  7. Figgy
    Figgy New Member
    Santa Monica, CA
    Get the Solar Power Battery Charger by Wagan Tech.
  8. JC91006
    16,470
    8,384
    I have 4 Priis and I don't have this problem.
  9. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    Is 2 weeks a common length of time? If it is I may need to get a charger. Figgy is this the one you are referring to:
  10. Roland1555
    Roland1555 Senior Member
    282
    68
    Vancouver BC
    If your father knows to put the car into ready mode by pressing on the brake peddle before pressing the power button, the big hybrid battery will charge the 12 volt without the gas engine needing to be on.... it is always charged by the hybrid battery to the inverter at the front, then back to the 12 volt using a dc to dc inverter circuit.
    If you had not said that it 'dried' up already once during a two week period of non use, I'd say don't worry about it as 2 weeks is nothing if the battery is in good condition and properly charged.
    My car is an early 2010, and I recently replaced my 12 volt battery because it is 5 years old and the capacity was degraded. Never needed a boost in those 5 years, but I can't be bothered with that kind of stuff happening when it is likely going to be most inconvenient.
    Here I live in a moderate almost Mediterranean climate on the Pacific West Coast.... could be your battery lives in hotter conditions than mine, and maybe you don't have the solar roof running a cooling fan all the time when the sun is high to keep heat down for the batteries.... some 2012 people have had to change out already. Get it load tested and see if a tender or replacement is in order.
    Have a safe trip,
    Roland
  11. WE0H
    WE0H Senior Member
    3,247
    527
    I use a walwart with clipleads and leave it plugged in 24/7. I tested several walwart's until I found one that would maintain the battery at 13.2 volts. The car is 2.5 years old and only has 1500 miles on it so you can kinda figure how much it sits powered off ;)
    Mike
  12. macman408
    macman408 Electron Guidance Counselor
    1,179
    365
    Sooooo... about every half mile you drive, you post a message on PriusChat? o_O
  13. WE0H
    WE0H Senior Member
    3,247
    527
    Since I bought my Kia Soul I have not been into the Prius thing so much as before. I did renew the license on my Prius the other week so I can drive it now :) She's a little dusty in the garage so a bath is in order first :)
    Mike
  14. Patrick Glass
    Patrick Glass Junior Member
    San Antonio, TX
    I have left my 2013 for a month with no problems. One time, I was gone for 6 weeks and I hooked a batteryminder to the battery connection in the fuse box and that worked out just fine. I guess everyone knows about the battery connector inside the fuse box under the hood. It's a lot more convenient to use than having to gain access to the battery at the rear of the car.
    WE0H likes this.
  15. SeattleHawaii
    SeattleHawaii Member
    48
    57
    Seattle, Wa & Papaikou, Hi
    Hi - quick question: So...just got a Prius 2014 and was wondering what to do when I leave for extended periods of time to keep the 12V Battery charged. As per your post, it sounds the Solar charger from Wagan will do the trick. However in a different post on this board it says that the cigarette lighter which the Wagan plugs in is NOT active when the car is turned off. Hence the charging wouldn't work. You say above that it's working for you......so....is the cigarette lighter on when the car is turned off and the Solar charger with the regular cigarette lighter plug works to trickle charge the battery, or does it not work (or need modifications.)
    thanks much for clarifying!
  16. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    The manual only says the outlets can be used when the power switch is set to Acc or On and not to use the outlets too long when the hybrid system is Off. Seems somewhat contradictory. FWIW, I just took my Garmin out and plugged it into an outlet, it didn't turn on. I hit the Power switch and the Garmin turned on. I hit the switch again twice to turn it off and the Garmin dimmed, meaning it was now on battery power.
  17. Roland1555
    282
    68
    Vancouver BC
    True, I've used the front. But if I am not able to be around the car and come home late at night. The car is always outside. The ctek charger has included a little 12 inch cable with which you can leave it attached to the 12 volt terminals in the back. The cable has a plug with cover that extends up onto the cargo floor, so you can just lay the charger on the floor with it attached to the cable. My hatch will close over the extension cord which is plugged into an outlet inside the garage. Of course the garage door closes over the cord too. So everything is secure and the charger is automatic. It does some cycling magic as part of the process where it is claimed it recovers the battery from sulphation.
    Roland
    WE0H likes this.
  18. macman408
    1,179
    365
    That means not to use them for too long when you're not in READY; i.e. the hybrid system (HV battery and ICE) are off. In ACC and IG-ON, the hybrid system is still off, and you're running only from the 12V battery. If it gets low, you might not be able to start the car. On the other hand, if you're in READY, the HV battery will keep the 12V battery charged, and the ICE will keep the HV battery charged. You're on your own for filling the gas tank once every few days, though. ;)
  19. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    Thank you, it makes sense now. I'm quickly learning I can't always assume terms mean the same thing as they would in manuals for traditional cars. :)
  20. SeattleHawaii
    48
    57
    Based on this reply, you could use the Wagan battery charger with the cigarette lighter plug for trickle charging the battery while gone for a while? Can anybody confirm that they have successfully done that?
