Key Fob Case/Shell replacement
Discussion in 'Gen 2 Prius Main Forum' started by priusgto, Apr 23, 2015.
  1. priusgto
    priusgto Active Member
    193
    227
    Northern Arizona
    I saw a few old threads asking about a replacement shell for the gen II fobs but didn't see anybody who has found one. Just in case there is none available, I found a silicone cover that might work in a pinch if anyone has the same problem. Found it on Ebay but haven't ordered one yet until I know a replacement shell isn't available. Do a search for Prius Fob cover.
    49,089
    looks pretty cool, thanks! would it be cost prohibitive to buy a used fob and swap guts?
  3. xliderider
    xliderider Senior Member
    7,852
    3,103
    Honolulu, HI
  4. priusgto
    193
    227
    Northern Arizona
    xliderider, I saw that case on Ebay but read the feedback and some reported it didn't fit the Prius.
  5. priusgto
    193
    227
    Northern Arizona
    All the used ones I see are pricey.
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    I have a silicone key fob jacket.
    It's really nice and I like it, but I take it as protection for the case...not as a replacement or repair for the actual case.
    priusgto likes this.
  7. TampaPrius.com
    TampaPrius.com Active Member
    461
    296
    Tampa, Florida
    I have ordered the silicone inserts and they are a perfect fit but the bottom button is for a trunk release-not panic button and has to be cut out.
    The replacement shell that is linked above also shows the same trunk release which gen2 Prius doesn't have.
  8. TampaPrius.com
    461
    296
    Tampa, Florida
    Also noticed the key blank on the eBay shell is different than gen2 key
  9. priusgto
    193
    227
    Northern Arizona
    The shell on ebay key does look like it would fit but I wonder if the trunk release button
    After comparing my key with the shell on ebay, it does look it would work, other than the trunk release and wrong type of key blank. I ordered one and will see how it goes. Will post back when I get it.
  10. xliderider
    7,852
    3,103
    Honolulu, HI
    Maybe the trunk release button can be swapped into the new case.
  11. priusgto
    193
    227
    Northern Arizona
    Well, I ordered the replacement case and the seller cancelled it and said it won't work on the US model. I think it was the trunk release button that he was referring to. So I ordered the silicone cover instead. The ones with the panic button were $16.00 each so I ordered the ones with the trunk release instead. Got 3 for $12.00 including shipping. They fit perfect and the trunk release didn't need to be cut out. They even have a nice Toyota emblem on the back.
  12. bisco
    49,089
    looks pretty sweet, thanks for getting back to us!
  13. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    I just ordered the case cover myself...got the same deal buy two get one free...I still need to replace my fobs as one has no buttons life to push...broken off the board, shocked it still works in the dash..these cover will keep the dirt out until I can find fobs under $40 bucks used.
  14. EastR
    EastR Junior Member
    82
    Miami, FL
    2016 Prius v wagon
    On my 2006, one of the key fobs rubber connecting the lock button to the plastic case has warped to the point that it sticks up and I cannot insert the key into the slot on the car to operate the car. Tried to use super glue to hold it down but the rubber button has warped too far. Any links to a new plastic case? And has anyone done the internals transfer to a new plastic case? Thanks.
  15. TampaPrius.com
    461
    296
    Tampa, Florida
    Just FYI
    If anyone needs the rear part of the key fob with spring tab, you can order it separate from the dealer.
    Part number 89751-47010
    Price is $10-13
    SFO likes this.
  16. TampaPrius.com
    461
    296
    Tampa, Florida
    You can find the rubber inserts on ebay
    Toyota Prius Repair Silicone Key Pad for 3 Button Remote | eBay
  17. EastR
    EastR Junior Member
    82
    Miami, FL
    2016 Prius v wagon
  18. TampaPrius.com
    461
    296
    Tampa, Florida
    I have ordered and used these before. They work as advertised.
  19. EastR
    EastR Junior Member
    82
    Miami, FL
    2016 Prius v wagon
    Was able to to find the 3 button silicone by messaging the seller on Ebay (thanks TampaPrius). It is item # 201360675812, shipped fast but just waiting on delivery from AUS. Any help on removing the old buttons? They peeled out of one side, but seem attached below the plastic crossbars and I don't want to break the plastic while removing the buttons. Photo below.
  20. xliderider
    7,852
    3,103
    Honolulu, HI
    I'm guessing it will be easier if you open the case up? ;)
