Key Fob locked in car
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cyberpriusII, May 14, 2014.
  1. cyberpriusII
    cyberpriusII Prodigyplace says I'm Super Kris
    1,135
    1,560
    Iowa
    Sorry, I promised myself not to post anymore for awhile....but...
    A friend texted me this morning and said this is the second time she has locked her smart key fob in her Prius. And, as I do, she thought this was impossible.
    I told her to check that the light on the fob lights when she presses it to make sure the battery is O.K., but have not heard back from her.
    Anyway, I did a bit of web looking and found John's always helpful PDF of information, and he talks about a smart button under the steering wheel (I have not looked for it yet), but, is there anything else I should tell her to check...to be honest, although I would never tell her this -- locking the fob in the car is a REAL dumb blonde move.:ROFLMAO:
    Oh, I guess I should add her boyfriend rescued her with the spare, so no need to talk about breaking out windows or anything...
  2. JC91006
    16,470
    8,383
    What you are describing is impossible if the battery is in good working order. If the battery is dead, then it's possible.
    Also there is an SKS button under the steering wheel, if that's turned off, it MIGHT be possible to lock the key in the car. Wanna try and see?
    cyberpriusII likes this.
  3. cyberpriusII
    1,135
    1,560
    Iowa
    John's info said if the fob battery is really low, that some strange things might happen. But in that case the light should not light up when the buttons are pushed. Mine are fine, so I can't experiment with that low fob battery issue.
    However, JC, I think you are more qualified for the experiment with the SKS button. Give it a shot (have your cell phone with you) and let us know what you find out....:p J/K
    Kris
    dorunron likes this.
  4. JC91006
    16,470
    8,383
    I'll test in an hour when my car gets back, will let you know. Someone took mine :mad:
  5. JC91006
    16,470
    8,383
    If the car cannot detect the fob (when the battery is low or dead), it won't know it's in the car. So in theory, it can be locked inside when this scenario happens.
  6. fuzzy1
    10,049
    No, there are some radio dead spots inside where the car cannot detect the presence of the fob, so can be fooled into believing the fob is not present.
    But a weak battery might contribute to this, expanding the size of the dead spots.
  7. JC91006
    16,470
    8,383
    This is good to know, isn't Priuschat great? I wasn't aware there are dead spots in the car. I guess it's like having the keyfob in a purse made with a foil lining.
  8. JC91006
    16,470
    8,383
    Ok, you CAN lock the key in the car with the SKS function turned off. It won't detect the key inside.
    ijim2011 and dorunron like this.
  9. ijim2011
    ijim2011 Junior Member
    23
    Northern New York (basically Canada)
    Wow. Glad I leave it on then
    iPhone ?
