keyless entry
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by GaryD1, Jul 24, 2014.
  1. GaryD1
    GaryD1 Active Member
    302
    138
    Seagrove, NC
    I received 2 sets of keyless entrys with new Prius. I thought I would share this info with the group. The keyless entry battery in the set my wife uses started getting a reading "key not detected" so I changed the battery and that stopped that. This was in Jan of this year, car being 3 year old, battery died. The set that I use started not wanting to unlock the doors and also the same readout in the dash panel so I did the same for my set and thought that corrected the problem but not. A month later it started doing the same thing again with my set. I changed the battery again. This worked good for a few weeks but started repeating the same thing again, wouldn't unlock the doors, sort of off and on, sometimes it would and sometimes it wouldn't. I decided to take a look inside and work on the keyless entry myself. The thing that fixed it was, there are springs inside that the battery lay against to make contact I guess. I took a small pen and pulled up each bow spring I will call them and that corrected the problem. Its been a couple months now and no more problems. Just thought I would pass this on. I've found the forum to be helpful over the last 3 years so this may or may not help someone in the future.
    bisco and alexcue like this.
  2. retired4999
    2,652
    625
    Eau Claire, Wi.
    Yep! a good thing to remember, and check every time when replacing the fob battery's.!
    Thanks!:)
  3. Paul Miller
    Paul Miller New Member
    Eugene, Or
    Do all 2014 Prius' have keyless entry? There is no button under my steering column.
  4. Tideland Prius
    16,073
    Keyless entry? Yes
    Smart Key System? No (that’s the one with the button under the steering wheel column).
    Those with keyless entry require the key fob to be slotted into the dash before starting the car.
    Those equipped with SKS will allow keyless start.
  5. bisco
    48,994
    i think all gen3 have sks (2014 included) but there hasn't been a button under the dash since 2009 (gen2)
  6. bisco
    48,994
    they eliminated the button on gen 3. you now have to go into the menu to turn it on and off.
  7. CR94
    CR94 Senior Member
    2,642
    1,134
    Northwestern S.C.
    There's a button down there, but it's for TPMS, not SKS.
  8. bisco
    48,994
    no wonder my fob wouldn't shut off, and my tires pressure are screwed up :cool:
    RMB and CR94 like this.
