Kill-a-Watt owners: PiP kWh usage accurate?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by tiggerntatie, May 6, 2012.
  1. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Just went to the hardware store and got a 2ft. 12 gauge 15 amp 125 volt extension cord. Thanks for the suggestion.:rockon:
    51,851
    well done p/k. let us know how many amps and kwh you're reading.
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    power comes on at dusk 8:30PM, Checked at 9:20PM : 11.78 AMPS 1.32Kwatt Apartment management found out I was charging without letting him know. I told him I will record Kwatts used tonight and multiply days since since April 23, 2012. I am going to check with DTE to see how much they charge for electricity.
    51,851
    that sounds just about right. we pay .16/kwh so a charge costs me around .50-.55.
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Charge started at 8:25pm ended at 10:58pm total kw's 3.0
  6. bisco
    51,851
    how much charge was in her before you began?
  7. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Completely depleted.
  8. bisco
    51,851
    thanks, that's interesting. i could be wrong but i think most people are seeing 3.2 or 3.3?
  9. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I'll keep you updated next time I'm hooked up
  10. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Here is my chargepoint history so far:
    kwh
    2012-05-10 12:02:51 (EDT) 2012-05-10 13:39:04 (EDT) 3.152
    2012-05-04 14:51:49 (EDT) 2012-05-04 16:20:39 (EDT) 2.914
    2012-05-03 09:56:31 (EDT) 2012-05-03 11:28:41 (EDT) 2.906
    2012-04-29 13:50:21 (EDT) 2012-04-29 15:26:32 (EDT) 3.115
    2012-04-27 09:28:26 (EDT) 2012-04-27 11:05:31 (EDT) 2.567
    2012-04-26 13:05:45 (EDT) 2012-04-26 14:22:02 (EDT) 2.292
    2012-04-25 12:36:54 (EDT) 2012-04-25 14:09:03 (EDT) 3.057
    2012-04-25 09:58:25 (EDT) 2012-04-25 11:28:55 (EDT) 2.918
    2012-04-24 14:06:27 (EDT) 2012-04-24 15:40:57 (EDT) 2.876
    2 people like this.
  11. bisco
    51,851
    and these are all from empty battery?
  12. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    No, only the first tread where I gave the time, amperage, and kwh. Not the Chargepoint readings.:D
    Today my battery just ended at .1 mile. Here is the latest Chargepoint reading:
    2012-05-13 14:11:50 (EDT) 2012-05-13 15:41:19 (EDT) 2.902 4.123 01:29:29
    .............................................................................KWH
    EV level at 10.8 miles
  13. bisco
    51,851
    got it, thanks! looks pretty normal!
  14. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Today I went to see my landlord. He agreed to charge me $15.00 a month to charge my car in my parking spot at my apartment. I told him not now, because the ChargePoint location a mile away is free. I told him I would let him know if I change my mind and decide to charge my car in my apartment parking spot.
  15. larryakoch
    larryakoch Junior Member
    82
    Pomona, ca
    On a one time reading from empty battery Kill a watt was 3.17 Full charge says I get about 13 miles.
  16. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Update: August 7, 2012
    EV before charge: 4.9 miles
    Trip Odo: 8.4 miles
    Charge start time: 8:26:15 pm
    Charge end time: 10:06:38 pm
    Kill a Watt time elapsed 1:42 hours
    EV after charge complete: 11.9 miles
    Kill a watt voltage: 105.8 vac @ 11.72 amps and 1235 watts
    109.9 vac @ 5.7 amps and 626 watts @ 9:50:00 pm
    115.7 vac @ .03 amps and 1.1 watts @ 10:06:38pm
    Total miles 1369 since acquiring PIP
    KWH 1.96
  17. CRT1
    CRT1 New Member
    Charging losses will be less at 240V.
  18. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I don't have that option available.
  19. CRT1
    CRT1 New Member
    You can upgrade your charging cable and get an electrician to install a 240V outlet. Cost $ but your car would charge in 1/2 the time and with better efficiency. You might make it back in time.
  20. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Already checked that out. I don't have $1,900.00 and the parking spot I would need to be next to the "upgraded" station has been assigned to some one else. (the landlord asked me if I wanted that spot, I told him no because I don't have the aforementioned $1,900.00) The parking spot's are the one pictured in my avatar. (110volt) The other parking spot is next to the DTE meter.
