Leaving Headlights On and EV Range?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by bilofsky, Jun 11, 2013.
  1. El Dobro
    El Dobro A Member
    7,079
    3,259
    In NJ, it's headlights on with the wipers because they're considered "lighted lamps" by the law. As for the power draw I've never noticed much difference to care when driving in EV mode.
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Power Resource IB is the amp from the inverter. It routes power from the PHV battery and the generator to the motor. I believe the DC-to-DC converter changes the PHV battery voltage to 12v, it should account for the 12v system.
    We can do a virtual PID that subtracts Power Resource IB from Batt Pack Current Val. The difference would be the amp that the dc-to-dc converter draws. This will only be accurate only when the generator is not active (no regen or ICE making power).
    PID:
    Name: 12V Bus Amp
    Equation: VAL{Batt Pack Current Val} - VAL{Power Resource IB}
    Unit: kW
    bilofsky likes this.
  3. bilofsky
    bilofsky Privolting Member
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    With the car on, fully charged and parked, that value stays at 0.0 most of the time. If I turn the headlights or brights on or off, it will momentarily jump to 0.1 or 0.3 or 1.0 (or -0.5 a couple of times) and then go back to 0.
    Is that anything other than the lag between two otherwise identical measurements?
    (And should the unit be Amps?)
  4. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Yes, would be Amp.
    Have you tried adding more load on 12V? Turn on the music with a good bass.
    Edit: Hmm, perhaps they both display the same value.
  5. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    Hmmm. It never rains in California.
  6. bilofsky
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    And the answers ...
    Using a clamp-on ammeter on the positive lead of the 12v battery of my PIP Advanced with the car turned off, I measured:
    Headlamps 81 w.
    Brights 215 w.
    Side markers, etc. 29 w.
    Edit: These are the total power from the battery for the headlight switch positions shown. So "Headlamps" means all power drawn when the switch is in the headlights on position.
    usbseawolf2000 and bisco like this.
  7. bisco
    51,584
    so, 100w would use about 1/30 of a fully charged battery in an hour? for me about 1/2 mile. since i can only drive on ev for about 1/2 hour, it would be 1/4 mile.
  8. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    Probably less than the carbon that would be generated by the emergency vehicles driven to the scene of an accident that would have been avoided, and what would be generated repairing/replacing two or more damaged cars.
