1. Offline
    Ryephile The Technophile
    Start a Conversation
    Jul 10, 2012
    419
    141
    Metro Detroit
    Your Vehicle Year:
  2. Offline
    Mik1 Member
    Apr 17, 2012
    335
    49
    Houston, TX
    Your Vehicle Year:
    Thanks! Appreciate your feedback. The color is nice and the brightness is spot on. I do like the ballasts - their quality is good; however, TRS screwed a little bit with grounding electrode placing on the bulb itself, that is why I have tiny shades when I am driving. I am guessing from the previous posts, there is no such of a problem with xenonsupply. Toyota's H11 is very good, the cutoff line is precise and clear.
  3. Online
    col127 Member
    Apr 4, 2012
    229
    Your Vehicle Year:
    Hi All! Planning to get HIDs on my C3 eventually. Does having HIDs void warranty at all? Also, is it hard to install yourself? I've never done any thing like this before... :) Thanks!!!
  4. Offline
    Mik1 Member
    Apr 17, 2012
    335
    49
    Houston, TX
    Your Vehicle Year:
    Nope, your warranty will be ok. Installation is pretty simple - plug and play. The most "difficult" part is just to find the place for your ballasts.
  5. Offline
    daboy Junior Member
    May 2, 2012
    40
    Your Vehicle Year:
    I'm going to install mine this weekend. Here's a video from xenonsupply
  6. Online
    col127 Member
    Apr 4, 2012
    229
    Your Vehicle Year:
    Ballasts - do you have to drill anywhere to have those in a fixed place? How are they kept in the car without moving? :) Adhesives?
  7. Offline
    Mik1 Member
    Apr 17, 2012
    335
    49
    Houston, TX
    Your Vehicle Year:
    It depends on what you will get in your package. I wouldn't recommend any adhesives or double sided tapes since sooner or later it may fall off. Some people use plastic tie wraps another just use the metal brackets which come together with the ballasts. Your limit is just your own imagination, you can find a lot of small holes or spots in your car where you can actually attach the brackets without any drilling. I personally found couple of holes in my fenders and put my brackets there, see post #69; as well as posts #47, 54 and 57 in this thread.
  8. Offline
    MrUPSer New Member
    Jul 5, 2012
    Your Vehicle Year:
  9. Offline
    MrUPSer New Member
    Jul 5, 2012
    Your Vehicle Year:
    Did you order 4300 or 6000? Can you post pics?
  10. Offline
    GTI New Member
    Sep 17, 2012
    23
    Chicago, IL
    Your Vehicle Year:
    Any new coupon codes from xenonsupply?
  11. Offline
    MrUPSer New Member
    Jul 5, 2012
    Your Vehicle Year:
    youtube11 10%off just worked for me.
  12. Offline
    GTI New Member
    Sep 17, 2012
    23
    Chicago, IL
    Your Vehicle Year:
    ok, thanks. I used "xsforum15" and saved 15% ;)
  13. Offline
    Ryan Case New Member
    Nov 18, 2012
    26
    Normal, IL
    Your Vehicle Year:
    Installed the xenonsupply prius kit this weekend. 6K color.
    Notes:
    • Was surprised that there was not a factory connector (that I had to use the spade plugs into the factory connector
    • The driver side bulb was tricky to lock into place - I advise you look at the pattern of the factory bulb and then rotate the new xenon bulb approximately the same location
    • 6K lighting looks fine (nothing extraordinary)
    • The cut-off in the prius-c projector is low quality, I may replace these with real xenon projectors at some point
    • I used zip ties as I plan on removing these for service intervals. My past experiences with luxury brands has taught me to remove anything that causes contention on issues.
    • I would advise buying the bulb for above the lights - it looks stupid now.
    Overall a huge upgrade for 110 bucks shipped.
    Difficulty of installation 2/10
    Time spent - 20 Mintues
  14. Offline
    Jul 10, 2012
    419
    141
    Metro Detroit
    Your Vehicle Year:
    Care to elaborate on a couple points? You seem to be struggling when others haven't.
    *What factory connector wasn't in your car? The kit is literally plug-n-play with weather-sealed connectors.
    *What makes you say the projector cut-off is poor? Is there light bleed or is the cut-off fuzzy on yours? You may want to double check you seated the bulbs correctly.
    *"Bulb above the lights": do you mean the running light? Why do you think it looks stupid, because it's a lower color temp?
  15. Offline
    GTI New Member
    Sep 17, 2012
    23
    Chicago, IL
    Your Vehicle Year:
    This kit is not 100% plug n play. There is no more socket connector for the factory lightbulb connector, instead there are two wires red and black with metal pins on the end that have to be connected to the factory lightbulb socket. This type of connection is far from being weather-sealed, Lol. I secured mine with some electrical tape and hope it won't get loose over time.
    The cut-off is actually pretty good IMO at least with my 4300K.
    The parking light above the headlight looks kinda off with HIDs on ( too yellow ) I replaced mine with super white 194 LED
  16. Offline
    Jul 10, 2012
    419
    141
    Metro Detroit
    Your Vehicle Year:
  17. Offline
    JLee81 Junior Member
    Feb 27, 2012
    58
    Maryland
    Your Vehicle Year:
    I just purchased the same kit and, as the previous post states, it only has wires with spade connectors rather than the actual harness that connects to the factory wiring.
    Sent from my SGH-T989 using Tapatalk 2
  18. Online
    col127 Member
    Apr 4, 2012
    229
    Your Vehicle Year:
    I just ordered the same kit - waiting to receive it - I was expecting it to be plug and play since I'm not very handy with cars. - when you guys are talking about wires + spade connectors, how do you conect them then to the car - where do you do that?
  19. Offline
    Jul 10, 2012
    419
    141
    Metro Detroit
    Your Vehicle Year:
    -->GTI & JLee81: when did you get your kits from XenonSupply? I'm wondering if they downgraded the connectors since I bought mine back in August.
  20. Online
    allen2oo3 Junior Member
    Aug 29, 2012
    43
    Orange County, CA
    Your Vehicle Year:
    If you checkout the 3rd gen forums, we have also experienced the same thing. Another user and I have asked for the h11 connector and xenon supply told us both that they would mail them out. Mine will hopefully arrive tomorrow or friday.
Share This Page
