Leviton wants $1800+ to put in EVSE
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by devprius, Mar 2, 2012.
  1. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
    All,
    At HomeDepot.com a search for Electric Car Chargers displays -
    Search Results for electric car chargers at The Home Depot
    Leviton PORTABLE Evr-Green 12-Amp Blue Level 1 Electric Car Charger
    Model 002-EVC11-300 $899.00
    Internet Special $899.00 Free Shipping
    GE Residential Electric Vehicle (EV) Level 2 WattStation with Plug
    Model EVWSWBC-CP01 $999.00
    Internet Special $999.00 Free Shipping
    Legrand Electric Vehicle Level 2 Charging Station
    Model L2EVSE16 $749.00
    Internet Special $749.00 Free Shipping
    Schneider Electric EVlink 30A Level 2 Electric Vehicle Charging Station
    Model EV2430WS $799.00
    Internet Special $799.00 Free Shipping
    Leviton Evr-Green 16-Amp Blue Level 2 Electric Car Charging Station
    Model 002-EVB22-3PM $999.00
    Legrand also has a portable Level 1 charger and Home Depot is suppose to have, but it's not in the search results.
    Level 1 Portable EV Charger - L1EVSE
    Leviton is just EXPENSIVE !!!
  2. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    I just spoke to the building department of Pacifica. The permit for the charging station is only $139.20. Needless to say, I am not amused. Leviton is supposed to get back to me to explain the huge difference in pricing.
  3. tarantoga
    tarantoga Junior Member
    52
    Alameda, CA
    Can the 30A chargers be throttled to 20A or less?
    I have a 20A breaker and corresponding cable for a 240V outlet; since the 30A chargers don't seem to be more expensive than the 16A ones - is there a way to make sure they don't draw more than 16A (e.g. if a Tesla or future-plugin-car comes along and wants to use my charger)?
  4. mitch672
    mitch672 Technology Geek
    1,077
    197
    Randolph, MA
    Most cannot be set lower than their designed maximum, that's why I suggested getting the EVSE upgraded, it will by default use 12A @ 240, but can also be upgraded to handle the full 3.3KW charger at 16A @ 240V, both of which work on a 20A breaker, and will cost you 1/3 of these ridiculous prices.
    FYI, because most of these EVSEs cannot be set lower, that then drives electrical service upgrades and larger permit fees and labor costs, get it?
  5. tarantoga
    52
    Alameda, CA
    Yes, that exactly was my motivation - the house has only 100A and putting in a 30A or more circuit would push it over the brink :)
  6. devprius
    devprius /dev/geek
    979
    291
    Your house may only have a 100A input breaker, but that doesn't mean it's always drawing 100A at any one time. I've got a 125A main break, but if you add up all the breakers in the sub-panel, it adds up to way more than 125A. If there is room in your panel for a 30A breaker, then you should be good to go.
  7. pineprius
    pineprius 15th Hole #4
    245
    134
    NC
    Guys,
    I have 200A service, and a Dencor energy demand controller, which has instant and constant KW usage readout. Even at non-peak times (no demand control) I have rarely seen more than 17KW usage at any time, H2O heater, HVAC, dryer etc on at the same time. (An electric hot water heater cycles at 4500 watts when on, 4.5Kwh) and takes the most electrical usage. Many of you have gas H2O heaters. Without knowing your equipment, just have an electrican check it out. You'd be surprised how little draw there is at any one time. When unknown, electrical draw can be easily measured. Always know what you are dealing with to make sound decisions.
    Watts are amps X volts (either 120 or 240V) Do the math either way. It's still all a big secret. :scared::spy:
    Pineprius
  8. drees
    drees Senior Member
    1,782
    247
    While this is true for the LEAF, Tesla Roadster and I believe the Volt, this may or may not be true for the PiP. We'll have to wait for someone with a TED or similar to see if the amount of energy it takes to charge a PiP from empty changes based on charge rate.
    pEEf can very likely modify it for 240V operation, but if it's like the Panasonic unit that ships with the iMiEV, it can't be upgraded to 16A operation - but doesn't the PiP only pull 240V/12A max anyway?
    If charging at 240V instead of 120V generates any excess heat in the battery pack then Toyota picked the wrong cells to use in their pack. Given that the pack can handle at least 20-30 kW of power (during regen) I doubt a piddly ~3 kW is going to affect it much.
  9. hill
    8,072
    Don't EVER question me !
    :D
    (except of days that end with a 'Y'.)
    But so the main thought doesn't get lost ... those few kW's are not gona heat up the pack. It's pretty much a trickle charger on 120v, and too not much more delivered through the onboard charger using 240v. I'm starting to wonder if manufacturers are going low charge power to mollify the utility companies. These traction batteries could easily handle 30 amps if their on board chargers were sized up. With the state of charger technology, if the cells actually did start to get warm (during the last 15% of charge or so, the wattage could simply be throttled down.
  10. mitch672
    1,077
    197
    Randolph, MA
    It's very likely that Toyota is using the exact same 3.3KW charger than Nissan is using (so it will have the same loss characteristics as well), so the max it can draw is 16A @ 240 (do the math). If the Panasonic EVSE Toyota is sourcing is built with 12AWG wire, it will be upgradeable to 16A, which will make it the equivilant of any wall mounted EVSE, for this generation of EVs. If its built with smaller wiring, (aka as the Volts is), then no, it will just squeek by for its supplied use at 12-13A @ 120V (only would require 14AWG wiring)
  11. drees
    drees Senior Member
    1,782
    247
    No, it's not likely that Toyota isusing the same charger. The PiP battery is only ~200V - the LEAF battery is nearly double that.
    Most of the additional loss when charging the LEAF (and the Tesla Roadster, for example) comes not from electrical losses in the charger, but pumping losses from pumping coolant to cool the charger (and the battery in the case of the Roadster). The LEAF appears to pump coolant the same speed regardless of charging speed - the Roadster appears to have a minimum pumping speed which doesn't slow down any further once charging below 240V/24A or so.
    I do not believe the onboard charger for the PiP is water cooled, it appears to be air cooled only.
    The Toyota supplied EVSE is very different in appearance to the unit supplied by Nissan/Mitsubishi. It's probably still supplied by Panasonic given their relationship, but I highly doubt they equipped it with 12ga wire given the effort Toyota went to optimize the cost of the vehicle.. I suspect that if the PiP did 240V/16A Toyota might quote the 240V charge time as ~1h15m instead of ~1h30m.
    So what PiP owner here is going to confirm the maximum 240V charge rate? I could not find a current spec anywhere on the Toyota site or in the owners manuals online.
  12. SKrueger
    SKrueger New Member
    52
    Los Angeles
    I wonder what's considered 20 feet. Technically I'd be within the 20 feet, but my electrical panel is on the floor below my garage.
    Are you saying they charge $100 just to give you a quote?
  13. devprius
    devprius /dev/geek
    979
    291
    Pretty much. Someone has to come out, evaluate things, take pics, etc. However, the $100 is applied towards the equipment and installation charges if you decide to use their product and installation services.
    Apparently if they have to run new conduit and wiring to the charging location, then they have to charge more money.
    Leviton is working on the concerns I have and will hopefully have a resolution that is satisfactory to both of us.
    While the L1 supplied charger does the job for me at home, it's just a bit of a pain to be constantly taking the charger in & out of the car. I'm not after shorter charging times so much as making it a little move convenient.
  14. Jozo
    Jozo PIP PIP HOORAY!
    145
    27
    Sacramento
    WOW! The permit charges are outrageous! I didn't have to pay anything like that here in Sacramento! I had my level 2 installed on December 29th - I really wanted to take advantage of the tax credit before it expired on the 31st. Yay! I made it!
  15. devprius
    devprius /dev/geek
    979
    291
    The permit fee is only $139.20 from my town. It's the contractor who is jacking up the price. Apparently it's to cover his time to pull the permits and sit around for the inspector. Both Leviton and I think it's a tad (very) excessive.
  16. Jozo
    145
    27
    Sacramento
    BTW - I had another reason for installing my level 2 charger (and wanting to get the tax credit) even though we technically don't need it - I assume all my vehicle in the future will use it!
  17. Rebound
    Rebound Senior Member
    3,961
    2,609
    Portland, OR
    Your PiP will draw only 16A, so there's no need to throttle anything. For safety, you should definitely wire the entire line from the circuit breaker to the EVSE with the proper gauge of electrical cable, so if, for any reason, current draw exceeds 16A, you won't have a fire.
    For the PiP, install a 20A breaker on either 120V or 240V. If you want to support a higher amperage EVSE, use thicker cable from the breaker to the EVSE, and a correspondingly higher breaker. No harm in that at all. I had 150 Amp service installed a few years ago. The main panel feeds to a 150A breaker. A 100 Amp breaker feeds our home's sub-panel, and those breakers total much more than 100 Amps. The main panel also has breakers for our water heater, AC and furnace, an will hold a breaker for the EVSE.
    100 Amp service can support a 20A or a 40A breaker. The worst thing that can happen is that you'll trip a breaker. What's important is that the wiring from the circuit breaker to the outlet is sufficient to support the amperage, so it won't overheat. The whole idea is to ensure that the circuit breaker is the point of failure.
    There are lots of appliances in a home that can draw 240V and high amperage for a long time -- electric ovens, clothes dryers, and AC units. Electricians know how to ensure this is safe.
  18. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    The Prius Plug-in draws less than 15A and only needs a 15A breaker. From 2012 Toyota Prius Plug-in Hybrid (click on "prius plug-in" under "prius plug-in hybrid FAQ":
  19. drees
    drees Senior Member
    1,782
    247
    True - but using a 20A circuit when pulling high current over long periods of time is never a bad idea. If nothing else the heavier gauge wire will be slightly more efficient so more of the power will go into your car and less into heating up wire.
    Has anyone confirmed how much current the PiP will draw on 240V? Is it 12A or 16A there?
    I assume that it's only 12A since the charge time is half - 240V/16A would let you charge in 45 minutes or so...
  20. Rebound
    3,961
    2,609
    Portland, OR
    Sorry, didn't want to start a war. It's just that, if you're going to run a new breaker, I think 20A is a way better way to go, because it adds virtually no expense and gives more overhead in a circuit that will draw fairly high current for many continuous hours.
    But, you're right, my opinion isn't fact. Mea culpa.
