Light scratches on dash - how to remove
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PixelRogue, Jul 18, 2010.
  1. PixelRogue
    317
    57
    US
    Hello everyone.
    I places a few 'innocent' pieces of long plastic in my Prius (2010) and the light pieces of plastic scratched up the dash. Scratches do not appear to be deep, however whatever type of plastic the dash is made from doesn't seem to want to rub out.
    Thoughts?
  2. pixelmixer
    pixelmixer New Member
    102
    Seal Beach CA
    I've got the same issue. It appears the texture of some of the interior plastics react this way upon light abrasion, and I would also like to hear of a "fix." These scratches are very apparent where you put your fingers to open the center console lid. (fingernails)
  3. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    If only there was a sub-forum for care, maintenance & troubleshooting. Oh, yeah, there is. ;)
  4. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    I have always used Brasso to remove scratches in plastic watch crystals. I also discovered that it is very good at removing scratches in other hard plastics. I used it to clean up the bakelite in an old telephone.
  5. erikl
    erikl New Member
    36
    SF Bay Area
    For very shallow surface scuffs on the dash plastic, I used plain chapstick with good results. Rub the chapstick in vertically, in the same direction as the textured streaky things. It basically moisturized the scuff and eliminated the whitish edge, if that makes sense.
    Even better than chapstick would be something waxier, approaching a crayon but with a little extra moisture...
  6. passionate1
    passionate1 New Member
    Alhambra, California
    Rent a new Prius and R&R the Plastic thingy!...lol
  7. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    420
    Whereabouts Unknown
    I have the same concern with light scratches on the interior surfaces of my Prius. I finally decided that the best way to deal with these tiny flaws is ignore them. AHhhhh...; that feels better.
  8. mainerinexile
    mainerinexile No longer in exile!
    403
    73
    Maine
    I've seen suggestions to use a hairdryer to lightly warm the area of scratches. Has anyone tried this?
    By the way, I know some people have criticized the plastic in Prii, but I like the concept of using non-oil based plastics. I can live with a few scratches if it isn't made from oil.
  9. xlricklx
    xlricklx Junior Member
    Miami
    So did any of these work?
  10. Skiesthelimit
    Skiesthelimit New Member
    I needed to carry some 10ft gutters and PVC pipes so I put them on top of the dash to hall home. Ended with several scratches on the top that would not rub out.
    For light scratches that cannot be rubbed out, I used Dark Grey Rust-Oleum Automobile Primer. Spray a little into a jar, add a tint of black enamel, mix and apply using a small brush or toothpick. Let it dry for a few hours, then rub it to blend the texture into the surrounding. The primer is a flat finish that seems to match the color and sheen of the dash. Important Note: if you have already applied a silicone based finish to the dash, the paint will not hold.
