List of known hacks / "easter eggs" ?
Discussion in 'Gen 2 Prius Audio and Electronics' started by Brent, Nov 14, 2005.
  1. Grayson73
    Grayson73 Junior Member
    62
    Maryland
    I would like to know this as well!
    Also, does the Nav unlock work to unlock the Bluetooth phone for a non-NAV car?
  2. BravoIndigoLimaLima
    BravoIndigoLimaLima Junior Member
    Birmingham, AL
    Does anyone know how to determine correct Type when in diagnostic mode?
  3. Simtronic
    Simtronic Active Member
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    Yes pin 5 on the top plug of three in the centre just behind dash, there is an illustration somewhere try the search funtion.
    seckwielen likes this.
  4. Tamim
    Tamim .
    Whoever discovered the disable reverse beep trick deserves to win the noble prize.
    stratusfear11 likes this.
  5. nutmeg
    nutmeg just rollin'
    24
    Loveland OH, USA
    I couldn't find a video of showing the reverse beep disable on youtube, but lots of videos complaining about it! I made one. If you think it is useful, feel free to add this link to the first page. Some people (like me!) learn best by watching.
    ZFL, Analog, Simtronic and 4 others like this.
  6. red06prius
    red06prius New Member
    Georgia
    does anyone know of a soft hack to disable the FM text messges while driving lock-out? I have a base model 06 Prius. I find this "feature" to be ridiculous, the information still scrolls through the station soft buttons in the default radio screen and is even more distracting and difficult to read than it would be in the MSG full screen.
  7. AceDeuceCoupe
    AceDeuceCoupe Junior Member
    35
    LA
    +1 thanks for the disable beep. Toyota has engineered our Prius super well, but that is one they slipped up on: beep should have been on the OUTSIDE, not INSIDE.
  8. Chitown Hustler
    Chitown Hustler Junior Member
    Chicago
    Four Touring
    :rockon: Been there LOVE IT brings back great memories
  9. alex1998
    alex1998 Junior Member
    new york
    Hello everyone!
    Can a used key fob (bought on ebay) be added as a second spare key or just a brand NEW key fob will work?
    I have programmed transponder (silver logo fob) successfully, but remote lock-unlock procedure has failed. ( Prius'08 with SKS)
    thank you.
  10. usnavystgc
    3,159
    988
    Tucson, AZ
    Only a brand new key fob will work.
  11. Nazbuster
    Nazbuster Junior Member
    Unable to get the diagnostic screen for the procedure to enable nav while driving.
    I hit Menu, Volume, tap upper/lower left twice as instructed, but do not get diagnostic screen. What's odd is that I used to be able to do this sometime in the past.
    I have a 2005 Prius with an updated map DVD. I recently had some work done where the multifunction display and radio were removed and replaced in the dash, but they are working fine now.
    Turn off signatures in Tapatalk Tapatalk
  12. Jeff606
    Jeff606 Junior Member
    23
    SF Bay area
    I use hit the upper left button (Display), then touch the screen tap upper/lower three times (each= upper, lower, upper, lower, upper, lower) that takes me to the diagnostic screen on my 2009 Touring.
  13. thegoldenhand
    thegoldenhand Junior Member
    44
    California USA
    on the 04 prius, is there a way to automatically lock all doors when in drive mode and automatically unlock all doors when park is pressed? I'd say automatically locking all doors when in drive and in motion is more important but if both is possible then great. thanks!
  14. Southpaw1969
    Southpaw1969 New Member
    22
    SoCal
    I disabled the reverse beep on my 2007 Prius using the instructions from the video posted by "Nutmeg". Worked first try, no snags.
    Very cool because I found the reverse beep to be very annoying.
    Is there a hack that will give the functionality that Lockpick 3 as posted by another poster here? I'd like to be able to use the video monitor screen to play videos from my iPhone/iPad, but don't really want to pay $230 to do it!
    Any way to do this? Thanks.
  15. Mohammad Taha
    Mohammad Taha New Member
    Jordan
    Is there any way to charge the HV battery by the engine?
    Regards
  16. Britprius
    Britprius Senior Member
    5,194
    1,912
    Herefordshire England
    Yes. Put the car in ready mode and D, and with your left foot firmly on the brake apply your right foot on the accelerator. You will see this charges the HV battery>
    John
    Simtronic and ZFL like this.
  17. danyulo
    danyulo New Member
    London UK
    Hi all, I can't get this to work on my '04. I get to the 'shift into reverse and back into park...' step, but after doing that, there is no " -b" on my display.
    I've tied varying the timings a little. And I have assumed that I should be using the shifter to get into reverse (whilst pressing down the brake) and then shifting back to neutral and pressing the park button (whithout pressing down on the brake).
    Does anyone have any tips?
  18. danyulo
    danyulo New Member
    London UK
    Forgot to say, at the 'power on the car' step, I have tried both just pressing the start button, pressing it twice to turn on systems, and also full starting it with the brake depressed.
  19. Britprius
    5,194
    1,912
    This does not work with a UK Prius. You cannot remove the beep for reverse or the seatbelts.
    John
    ZFL likes this.
  20. danyulo
    danyulo New Member
    London UK
    Ah righto thanks John
