Lock/Unlock Beep
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Kirby M., Jun 28, 2016.
  1. Kirby M.
    Kirby M. New Member
    2014 Prius c
    When I lock or unlock my Prius C with the handle or the key, it used to beep, now it no longer will beep, I've checked the doors and hood to make sure they are all shut and it will still not beep.
    Any help is appreciated, its kinda driving me nuts...
    Thanks in advance!!
    49,166
    welcome! the locks all work fine, but no beep?
  3. skayaks
    skayaks Active Member
    123
    107
    Massachusetts
    My C2 only flashes the flashers. (Locked: once; Unlocked: twice, just as stated in the manual.)
    So I assume you have a C3 or C4 with smart key.
    The beep can be turned off by the dealer (per pg. 521 of my 2013 manual).
    Any chance a dealer changed the programming during a routine visit?
  4. Kirby M.
    Kirby M. New Member
    2014 Prius c
    Yep just randomly stopped.
  5. Kirby M.
    Kirby M. New Member
    2014 Prius c
    I do have a smart key, I'm not sure what version, I've checked in the settings and the beep still shows to be turned on.
  6. bisco
    49,166
    maybe the beeper burned out, or fuse?
  7. Mendel Leisk
    Mendel Leisk Luddite
    38,419
    Maybe per post #3?
  8. Kirby M.
    Kirby M. New Member
    2014 Prius c
    Any idea or location of the beeper or fuse? Trying to avoid taking it into the dealership
  9. bisco
    49,166
    sorry, no. never heard of anything like this. are you sure it's not ambient noise? a lot of times, i can't hear mine in busy areas.
  10. bisco
    49,166
    do the lights flash?
  11. bisco
    49,166
    one thing i might try before the dealer is to disconnect the negative 12 volt battery post for a minute, to reset the computers. you might lose a few settings like radio stations and etc.
  12. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    You can reprogram or do an initial program yourself through the screen. I can't remember how, but I set all that on mine. Don't be afraid.
    It's pretty easy. Check your OWNERS MANUAL, maybe...
  13. Luiggi
    Luiggi New Member
    Suffolk
    Did you ever figure out why it did that? Or did you fix it? I'm having the same exact problem. I got a 2013 prius c three with SKS
  14. Luiggi
    Luiggi New Member
    Suffolk
    Anybody any updates on this??
