Looking for Plug and Play BRIGHTER Headlight Replacements
Discussion in 'Gen 3 Prius Accessories and Modifications' started by LuvMy2010, Dec 30, 2013.
  1. LuvMy2010
    LuvMy2010 Junior Member
    33
    Wichita
    My OEM headlights are not bright enough for me. I want to upgrade to something brighter, but don't want to mess with wiring, fuses, relays, etc... What does everyone suggest for a brighter bulb without all the hoopla?
  2. VTAERO
    VTAERO Junior Member
    Fredericksburg, VA
    I had tried the Sylvania Silver Star Ultra, but they only lasted a couple of months. Well short of what I thought would be a year. I'm looking too.
    I found mine on Amazon about 35$ for the pair. Walmart had them for almost 70$. Glad I looked on Amazon. But now I'm not happy about the longevity.
    Nexus 7 ? 4
  3. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    A 35w digital HID kit doesn't need a relay or anything like that. Yeah, you still need to hide the ballasts, but you can use all of the OEM wiring.
    In my experience, silverstars and other super bright halogens are expensive and have a fairly short lifespan. You can get an HID kit for the same price and the bulbs will last way longer. I've had bulbs last three years before they began to change color.
    Also, it's worth knowing that you pretty much need to move the coolant tank to change the bulb in the passenger side, so better to do it once and not worry about it for a while.
  4. LuvMy2010
    33
    Wichita
    I have zero mechanical ability. I did add a second horn to my prius and that took every ounce of mechanical know how I have. So, keeping that in mind. Could I change to an 35w digital HID kit myself? How easy is it to do?
  5. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    An HID kit would be best but it does require a bit of tinkering so I would not recommend it if you don't want to mess with mounting the little ballast boxes although that is basically all that needs to be done since HIDs just plug in to the existing wiring like a bulb.
    That said, if you just want to replace your stock halogen bulbs with better ones, look for a 'xenon', 'ultra' or 'crystal' type bulb (H11, 55w) like these:
    Philips H11 CrystalVision Ultra Headlight Bulb, Pack of 2 : Amazon.com : Automotive
    It gives off a more pure white light rather than off white like the stock ones. These tend to be slightly brighter as well, but also do not last quite as long.
  6. jzchen
    jzchen Newbie!
    3,296
    1,006
    Arcadia, CA
    I've used PIAA bulbs, but am not sure if I have a fair brightness comparison as it is replacement for blown bulbs.
    SCH-R530M ?
  7. mediahound
    903
    155
    Piaa, Hella, Phillips are all good. I'd just buy the cheapest of the 3.
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I would add thay for whatever reason, the lamps come from the factory pointed way low. Me and others here re-aimed and found a vast improvement from the stock bulbs.
  9. mediahound
    903
    155
    Mine seem just about right but how do you move them up?
  10. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    Try xexonsupply. They have a true plug/play kit and a video showing how-to on an actual Prius.
    tedjohnson likes this.
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    it might be the later models have set better. to adjust, there is an adjustment shaft towards the rear of the headlight housing. rotate to adjust up or down. thereis a good thread with all the details i cant remember off hand. :)
  12. xliderider
    xliderider Senior Member
    7,849
    3,102
    Honolulu, HI
    I'm using modified H9 65w bulbs in my Camry and they are definitely brighter than stock (H11 55w). Some of the reviews on Amazon specifically mention substituting H11 bulbs with H9 bulbs for an easy upgrade over stock:
    Amazon.com: Philips H9 Standard Headlight Bulb, Pack of 1: Automotive
    You just need to modify 2 things on the H9 bulbs to get them to fit on your H11 lowbeam harness connector and to fit in the H11 mounting socket in the back of the headlight housing.
    SCH-I535
  13. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    They are supposed to carry 1 year warranty
  14. Steve terry
    Steve terry Member
    217
    Oklahoma
    How do you raise them.
  15. xliderider
    7,849
    3,102
    Honolulu, HI
    At the back of the headlight housing there is a wheel with serrations on it, kind of looks like a small silver bottle cap. It also has a small, 8 mm bolt head on the back of it. I find it easiest to use this 8mm bolt to adjust the aim. Turn the wheel with a socket wrench counter clockwise to raise the projectors, and clockwise to lower the aim. I look at the serrations on the wheel and count how many notches I move the wheel when turning, if that makes any sense lol.
    SCH-I535
  16. Steve terry
    Steve terry Member
    217
    Oklahoma
    Thanks. Will have to look at them
  17. xliderider
    7,849
    3,102
    Honolulu, HI
    Regarding aim. You want to use a flat, level area with a wall about 30 ft away. The cutoff line on the wall should be slightly below the height of your headlight height at the car.
    You definitely don't want your beams to be rising upward from your lights or they'll be glaring into oncoming drivers eyes.
    SCH-I535
  18. burstaneurysm
    469
    144
    Chicago, IL
    It's not terribly difficult. Check this out.
  19. LuvMy2010
    33
    Wichita
    That kit looks easy enough! There's a separate high beam bulb though, correct? I've read a post somewhere about a guy putting an LED in place of the high beam. I wonder if it serves any purpose other than matching the HID bulbs.
  20. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    The H9 upgrade is simple and effective, increasing output from, iirc, ~1250 lumens to ~2300. Effective and very cheap. Be very careful if adjusting aim to follow procedure with measurements with the car loaded on a very level surface. There is the potential to put out a lot of glare to oncoming drivers if you get it wrong.
