LOW MPG - Engine starts quiet often
Discussion in 'Gen 2 Prius Fuel Economy' started by BillyLhr, Aug 22, 2014.
  1. BillyLhr
    BillyLhr Junior Member
    Hi There
    Though I have been here many times but this the first time I am putting up a question regarding loss of MPG that has puzzled me.
    I own a 07 Prius (Japanese import), for over 1 and a half years now. I recently sent it for routine service and got the spark plugs and throttle body cleaned as well. My workshop manager told me they reset the ECU (onboard computer as well) although I dint ask for it.
    Any how since this was done, my MPG average has remarkably reduced. (from 63 to 45) I am a light foot driver and always used to get around 60 plus MPG irrespective of the weather conditions.
    I use 5W30 Grade oil.
    looking through different discussion on Prius chat, some people have suggest that the drop in MPG might be due to a weaker 12 V battery, which I believe is OK as I don't get any ignition issues.
    The other reason some people say could either be a blocked air intake of the traction battery heat sync or chocked heat sync fan. I will get that checked.
    Can any one suggest or share from their experience what could be other reasons for this drop in MPG.
    Thanks for reading such a long text, and I look forward to your helpful inputs
    Read more: http://priuschat.com/conversations/add#ixzz3B7P74fBN
    Follow us: @PriusChat on Twitter | PriusChat on Facebook
  2. jdenenberg
    jdenenberg EE Professor
    3,862
    1,863
    Trumbull, CT
    2020 Prius
    LE AWD-e
    It can take some trip cycles for the ECU to relearn its parameters for your Prius to operate at peak efficiency.
    The mechanism that sometimes causes a weak 12v battery to lower MPG is when it continuously pulls charging current without getting fully charged. This is wasted energy. Note that you should measure the resting voltage of your battery (>12v), the voltage with some load current (still > 12v), and the voltage with your Prius in "ready" (about 14v) to determine if it is sound.
    These can reduce the useful life of your HV battery, so do check them.
    Check your tire pressure as a low PSI will drop MPG.
    Good luck,
    JeffD
  3. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Tyre pressures affect mpg's as do non low rolling resistance tyres. Have you changed your tyres lately?
    A failing 12v really does cause a drop in mpg's for the reason given by Jeff. If yours is the original 12v then it is possibly due a change. If you can't check it with a multimeter then try the following; in a morning after the car has been sat overnight put the car in Acc mode (NOT Ready) and then wind all 4 windows down at once and then back up again. If they struggle and the interior lights go dim or out then your 12v is a likely problem. Now put the car in Ready mode and repeat. If they fly up and down quickly you know it's the 12v that is on its way out.
    Where in the World are you? Helps on advice on replacement parts. If you're in the UK or Ireland then you can get a new Toyota 12v battery for the Prius for about £95/€120 fully fitted.
    Keep us all posted.
    49,796
    welcome to priuschat! all the best!(y)
  5. bisco
    49,796
    this happens quite often, i'm not sure i've ever read a thread where there is resolution, other than the o/p being mistaken.
  6. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Check the obvious things like tyre pressures and 12V battery health, but other than that just drive it. Most of the loss is only in the reported fuel consumption anyway (check it at the pump). The reported MPG can take many tanks full before it calibrates to it's former accuracy.
  7. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    The title says "engine starts quite often", so I am guessing that it means the car is not going into electric mode as expected. What is the state of charge indicator doing on the energy display? Are you seeing 6 blue bars most of the time?
    For example, if the engine is not putting out its normal amount of power, the car will lean on the battery to make up the difference, but that quickly brings down the charge. That will in turn cause the engine to run more, trying to return the charge. This may rectify itself after the learning period by the ECU's mentioned above.
  8. bisco
    49,796
    how many miles on her?
  9. BillyLhr
    @jdenenberg Thanks of the replies,
    I have driven it around 3,000 Miles since the service was done/ ECU was reset, can you please suggest how long it usually takes for the ECU to relearn its parameters for optimal performance
    I have also had my 12 V battery checked it seems to be working fine (did power windows and headlight test early morning too)
    Have adjusted the tyre pressure- another point that I forgot to mention earlier is that I changed my tyres from 185/60/15 to 195/65/15 to get better road clearance. Could this be one of the reasons for drop in MPG ?
    Cheers
    Billy
  10. BillyLhr
    @GrumpyCabbie
    Thanks for the inputs mate. You've guessed it right, I did change my tyres from 185/60/15 (Dunlop Enasave) to 195/65/15(Yokohama ADVAN DB Decible) to get better road clearance. earlier on I had
    I know larger/ wider tyres cause more friction but is a 15-20 MPG drop normal for such a little change in tyre size?
    I have done the battery test as you suggest, the windows rolled up and down on ACC just fine.
    I am based in Pakistan.
    Cheers
    Billy
  11. BillyLhr
    @bisco
    Thanks I have learnt a lot form different forum here- I am so happy to have found Prius Chat
  12. BillyLhr
    @uart
    I am in a habit of calculating the MPG manually at each refill. It used to be almost the same as shown by its MFD. But since the ECU reset it has a difference of about 3-4 MPG. (manual calc. results being on the lower side)
    Thanks
    Billy
  13. BillyLhr
    @nh7o
    Yes, I have observed that the engine starts quiet often. the moment I press on the accelerator paddle the engine kicks in irrespective of the speed (even below 35 MPH) or the traction battery's level of charge.
    I haven't been very particular in observing their behaviour, but from what ever little observation I have made, the charge indicators mostly stay in blue, I have seen them go to 6-7 bars at times.
    They do some times fall to Purple bars. But haven't lately seen them truing green (full charge)- I will observe the behaviour of charge indicators keenly and report back.
    cheers
    Billy
    #13 BillyLhr, Aug 25, 2014
  14. BillyLhr
    @bisco it has done just under 100k Miles.
    Can you please explain what o/p means?
  15. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Not sure about a 20 mpg drop but I guess it's possible. Think of it this way, a 10% drop on a car doing 30 mpg isn't noticeable but it is on a 60 mpg car. Maybe your fuel consumption meter is now misreading (as will the speedo?) because of the difference sized tyres?
    When I changed to no LRR tyres by accident my top end mpg's just couldn't be achieved. Then when I used thinner oil (gen3 Prius only) the mpg's dropped too. Amazing that these two items can make such a difference but they can. The Prius is finely tuned for economy in the same way a Ferrari is for speed.
  16. BillyLhr
    Makes sense thanks
  17. bisco
    49,796
    original poster, that's you.:)
    BillyLhr likes this.
  18. nh7o
    1,686
    340
    Hawaii
    I would say that the tyres are not the concern here. If the engine starts even at low speed and relatively higher battery charge, then that needs to be sorted out. This happened after the 12V was removed, which resets the ECUs. This should have sorted itself out by now. As was mentioned, this kind of behavior has been posted here before, but no real understanding has come about. The only thing I can suggest is to obtain the mini VCI code reader and start looking at the various ECUs and see what temperatures and other data might be out of normal range. The car is acting as though:
    *it incorrectly senses the HV battery is low
    *it senses the HV system as overheated
    *it senses the engine temperature as too low and still needs to warm up
    * the HV ECU is out to lunch.
    Only guessing here.
  19. JC91006
    16,498
    8,408
    I'm not sure about you averaging 63mpg for a year and a half. That's a remarkable average that I can't say I've seen. Maybe for 1 downhill stretch for 10 miles but for a year and a half is quite remarkable. I also don't think tire pressure or a bad 12v would cause a 20mpg drop to 45mpg.
    I own 3 of these Gen2 cars and my average on all of them is right around 45 mpg, one slightly higher, one slightly lower.....but I don't think any of them exceed 50mpg on combined highway/city driving.
    I believe there is nothing wrong with your car.
  20. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    The OPs based in Pakistan. I'm guessing he's using UK mpg's where 63 mpg is 52 mpg US, which is still pretty good going though.
