Low Rolling Resistance replacement tires: Current List
Discussion in 'Gen 2 Prius Fuel Economy' started by F8L, Apr 17, 2011.
  1. Iamjo20
    Iamjo20 Member
    259
    hmmm--ok--well I am simply hoping that the tire place will exchange the horrible BF Goodrich--
  2. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    My 2014 Prius has the Ecopia EP 20 tires and they are a excellent tire in all conditions. I would look at Energy Saver, maybe for my next set, but I am extremely happy with the EP 20's. Hal
  3. Iamjo20
    Iamjo20 Member
    259
    thanks! :)
  4. Iamjo20
    Iamjo20 Member
    259
    why would you change to Energy saver?
  5. Mendel Leisk
    41,334
    Iamjo20 has second gen, level 5 Prius. Not sure what tire it has, but suspect it's not 195/65R15, the ONLY size Ecopia EP20 comes in. Ecopia EP422 comes in a plethora of sizes though. EP20 are good for rolling resistance, speaking from personal experience. Ecopia EP422 I've heard are good, don't know for sure. I think reviews on the 422 are kinda mixed.
  6. Iamjo20
    Iamjo20 Member
    259
    It is a 185/65R15--as were the original Goodyear Integrity tires.......so the EP 20 will not work...........
  7. Iamjo20
    Iamjo20 Member
    259
    what about Goodyear Assurance Fuel Max, passenger all season?
    I will probably only have this vehicle for another year at most (waiting for info on 2016 Prius)--BUT want the BEST fuel efficiency possible--and I HAVE to get rid of the new Goodrich tires--hopefully--the MPG has dropped at least 10 MPG--not acceptable!
  8. Iamjo20
    Iamjo20 Member
    259
    or Continental True Contact--Standard Touring--all season ????? this seems to be a best seller at Tire Rack.....
  9. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    I bought a used Gen3 and they dealership put brand new Goodyear Integrity tires on it, UGH. Are the regular Integrity tires known for being mega-inefficient as far as LRR goes? Or should I just use them until they need replacement, and THEN go with a LRR tire?
  10. HaroldW
    716
    95
    GY Integrity are LRR tires. I found them not bad on my gen2. Hal
  11. PriusGuy32
    1,417
    514
    HaroldW likes this.
  12. HaroldW
    716
    95
    I found them to be a very efficient tire. Did not last long however. H
  13. Iamjo20
    Iamjo20 Member
    259
  14. Iamjo20
    Iamjo20 Member
    259
    OK--I am going with Energy Saver AS--will be installed tomorrow! Will keep you posted!
    Aaron Vitolins likes this.
  15. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    Good choice.
    John (Britprius)
  16. Iamjo20
    Iamjo20 Member
    259
    hope so! :)
  17. Mendel Leisk
    41,334
    I would get the Energy Save A/S in a heartbeat, if they came in 215/45R17. :(
  18. Iamjo20
    Iamjo20 Member
    259
    thanks--appreciate your comment---;-)
  19. lar.smith42
    lar.smith42 Active Member
    203
    118
    Double Oak , Texas
    For what its worth; I have 195/65-15 Yokohama AVID Ascend tires on my 2010 Prius 11. I have about 5,000 miles in them. Last two days its been raining constantly. I can not make these tires lose traction on our wet roads. Last night we got 1/2 inch of sleet and freezing rain so I took it out to see how it did in those conditions. Had no trouble at all and was going the speed limit most of the time. No problem stoping or starting at all. The first 55 years of my life I lived in Erie, Pa so I'm used to driving in extreme conditions. These tires are quiet, Good ride, And handle very well. They are rated for 51 psi but I run 40/38. Take this with a grain of salt because I am the one that also thinks my Prius handles extremely well at highway speeds 75-80 and in the wind. Very stable.
    Iamjo20 likes this.
  20. HaroldW
    716
    95
    Only problem with Energy Savers is they last for many miles! If they get noise with age then your stuck with them for a long time. Anyway good luck with them. Hal
