MAINTENANCE REQUIRED
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by tonia taffaro, Oct 11, 2013.
  1. tonia taffaro
    tonia taffaro Junior Member
    83
    i brought my prius somewhere else to get the tires rotated and the light is still on.
    anyone know how to turn it off?
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    It's in the owners manual... can't remember what page. Do a search for it here and you'll find it.
  3. tonia taffaro
    83
    i did a search in the prius c thread and ntohing came up. i found it in other threads tho but im not sure it will work...
  4. sph101
    sph101 Prius 4
    156
    92
    32
    Brevard, NC
    2018 Prius
    Reset the maintenance data (U.S.A. only)
    After the required maintenance is performed according to the maintenance
    schedule, please reset the maintenance data.
    To reset the data, follow the procedures described below:
    Vehicles without a smart key system
    Switch the display to the odometer (P. 188) and then turn the
    engine switch off.
    Vehicles with a smart key system
    “POWER” switch off.
    Turn the engine switch to the “ON” position. The multi-information
    display's initial screen will be displayed for a few seconds. While the
    initial screen is being displayed, press the “TRIP” steering switch
    (P. 186) 3 times, pressing and holding the switch on the third
    time.
    Turn the “POWER” switch to ON mode. The multi-information display's
    time.
    Continue to press and hold the button until the trip meter displays
    “000000
  5. tonia taffaro
    83
    all this does is zero out the trip
  6. sph101
    sph101 Prius 4
    156
    92
    32
    Brevard, NC
    2018 Prius
    don't think so all i have to do is hold the trip button in and it resets to 0
  7. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Are you starting the procedure by first selecting the odometer on the display, rather than Trip A or Trip B? It won't work otherwise.
    ztanos likes this.
  8. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    ^this.
    ftl likes this.
  9. tonia taffaro
    83
    I apologize for doubting you. you are correct - your instructions worked perfectly.
    There are similar instructions in the manual, however it does not state to turn the vehicle OFF first. That is the trick.
    Thanks so much for your help. I printed your instructions and will keep them in the folder in the glove compartment.
    ftl likes this.
