Maintenance required
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dstamant2001, Mar 20, 2010.
  1. dstamant2001
    dstamant2001 New Member
    Seekonk, MA
    I am very new to the Prius. I just bought an '06 with 47K. As soon as it hit 48K the "maint reqd" light came on. Is this just an indication of an oil change or could it be something else. It is going back for a repair on the bumper and a couple of other things and they are taking care of the light. I just want to be sure that they do what needs to be done and not just reset the indicator light. Any input would be most appreciated.
    Thank you,
    Dave
  2. Prius 07
    Prius 07 Member
    715
    Toronto, Canada
    Hi Dave and :welcome:to Priuschat. Yes you're correct - based on when the maintenance required light was reset light was reset last time it is time for you next maintenance. If you look it your maintenance manual the recommended service interval is every 5K miles. The maintenance manual will spell out what is required or you can check on-line by going to Toyota / dealership's web-site ....maintenance schedule ... follow instructions on the screen:
    Toyota Parts and Service
    Not sure if you're late for your 45K or early for 50K (likely the former), but your dealer should be able to tell you from their on-line records (assuming service was done at one of the Toyota dealers).
    Enjoy your Prius experience:),
  3. dstamant2001
    Seekonk, MA
    Thank you so much for the information. Everyone one the forum is amazing and extremely promp with answers to questions.
    Thanks again,
    Dave
  4. Caroline
    Caroline New Member
    DC
    Hi -
    I'm new to Prius and new to being a car owner in general. My "Maintenance Req" light came on today. Does that just mean I'm approaching a pre-set mileage milestone at which it's recommended to get maintenance - or does it mean that something is actually wrong with the car? I'm approaching 28,000 miles, and there is a convenient sticker on my windshield telling me to get an oil change at 28k....
    Thanks!
    Caroline
  5. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    The Maintenance Required light comes on approximately every 5000 miles. It doesn't mean anything is wrong with your car. Just means that you're approaching the mileage mark for when some maintenance (usually it's an oil change, some visual inspections, tire rotation) is required according to your maintenance manual/schedule. Check your maintenance manual/schedule for details. If you don't have a maintenance manual, you can get the maintenance schedule for your car from edmunds.com (among other places) or by registering your car with ToyotaOwnersOnline.com http://www.toyotaownersonline.com/
    Note that if you do your own service, you can shut off the Maintenance Required light. Instructions are in the Owner's Manual.
  6. richard schumacher
    7,663
    1,038
    United States
    It's just a mileage meter. It doesn't know anything about what the car needs.
    A more direct link to Toyota's service schedules is
    Note what is listed there and when it says to do it (miles or months, whichever comes first). Print out the appropriate list and hand it to the service writer at a dealer. Tell them to do that stuff and nothing else. *Don't* let a dealer sell you their own "X months/Y miles service package". They are always packed with overpriced unnecessary stuff.
    The 28,000 miles sticker was almost certainly placed there 3,000 miles ago, but the car only needs oil every 5,000 miles or six months. For Toyota's (not a dealer's!) recommended 30K miles service you should pay not much more than $100. You can save money by buying and installing new cabin air filter and engine air filter yourself. They're easy to do. Just don't put them in backwards/upside down. We can also talk about tire rotation... but those are finer points that you don't have to worry about if you don't want to.
    If you don't have the correct Owner's Manual, buy one, either online or from a dealer. It's filled with info you need to know.
  7. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    I'm 250mi short of oil change interval, the light came on 100mi ago. I can't not look at it!!
    Gonna wait till I get the 400mi back to SoCal to do the oil change. #yolo hahah
  8. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    The only thing I would ADD to Toyota's recommended services is a Transaxle ATF (with Toyota ATF WS) fluid change.
    Once at 30,000 miles, then every 60,000 miles (should be near $100 at a dealer, about $40 in parts if you DIY)
  9. Ariel_lopez
    Ariel_lopez New Member
    Rosemead
    Four Touring
    Just got an oil change on my prius and maint. Required light is still on.
  10. bisco
    48,998
    welcome!
    the directions for turning it off are in the owners manual.
  11. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Whomever changed the oil should have also reset the light for you.
    The process is in the book but it is a bit tricky.
