Maintenance tips requested for long-term ownership
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Raidin, Jan 12, 2014.
  1. Raidin
    Raidin Active Member
    238
    182
    Houston, TX
    Hey guys,
    I'm planning to keep my C2 for a long time. I'm near the 100k point and will probably just drive it until it gets too costly to own.
    Do you have any recommendations for anything I should do to prolong its life? All I do right now is follow the maintenance schedule in the manual.
  2. frodoz737
    frodoz737 Top Wrench
    4,297
    2,347
    33
    "All" fluids and filter minimum.
    Debster likes this.
  3. Raidin
    238
    182
    Houston, TX
    Are you implying something beyond regularly scheduled maintenance?
  4. jdenenberg
    jdenenberg EE Professor
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I would add a periodic drain/refill of the Type WS ATF. Lab tests on the ATF in my 2004 Prius (four times now at 252k miles) have indicated that an early refresh at about 30k miles and then repeat every 60k miles thereafter is a good protocol. Your transmission is similar to the earlier Prii and should show similar wear characteristice.
    JeffD
    xpcman likes this.
  5. B2FiNiTY
    B2FiNiTY Active Member
    979
    226
    wow, almost 100k, that's pretty amazing.
  6. frodoz737
    4,297
    2,347
    33
    Yes.
  7. Raidin
    238
    182
    Houston, TX
    So what did you mean?
  8. frodoz737
    4,297
    2,347
    33
    Brake, ATF, Oil/filter, Coolant.
  9. Raidin
    238
    182
    Houston, TX
    Does the brake fluid get replaced when the brakes need replacing? Or is it just the brake pads?
    Also, is the coolant ever replaced in any normal service? Or do I have to request a flush and refill?
    Oil/filter get done normally, and I will get an ATF soon.
    What about a tune up? Or is the ICE exempt in the C?
  10. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    I believe the spark plugs are 100k mile plugs. But don't quote me on that. Has anybody found a maintenance schedule for the C outside of warranty?
  11. jdenenberg
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    On older Prii, the schedule was:
    • Iridium plugs at just over 100k miles, but since this can be a while and the plugs can get hard to loosen, an inspection at 50k miles is a good idea.
    • Coolant (2 separate loops) need a drain/refill (no flush!) at 100k miles with Toyota type SSL coolant (pink, premixed). Then repeat every 50k miles. Removing air from these systems can be a pain.
    • Replace the PCV (Positive Crankcase Ventilation) valve at 100k or earlier even though this was not on Toyota's list.
    • Prius brakes can last a long time! My 2004 at 253k miles is still on its original pads/rotors.shoes/drums. The rotors get rusted from lack of use so periodically go into neutral at about 30 mph (shuts down regeneration) and lightly apply the brakes to clean the surfaces.
    JeffD
    ztanos likes this.
  12. SwhitePC
    SwhitePC Active Member
    495
    214
    ca
    It'd be nice if someone (with free time) compiles everything and makes a nice mile(s) by mile(s) list of what to maintain...
    I'll give you a lot of e-cookies
    minkus and ztanos like this.
  13. Raidin
    238
    182
    Houston, TX
    I checked the maintenance schedule and I see that the coolant is scheduled at the 100k interval, and the spark plugs are at the 120k interval.
    So far, the only things outside of what is recommended by the manufacturer is the ATF, the brake fluid, and the PCV valve.
    Anything else?
  14. jdenenberg
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You missed the PCV Valve suggestion and that the coolant repeats at 50k mile intervals thereafter.
    JeffD
  15. priusCpilot
    priusCpilot Active Member
    631
    208
    LA
    The car should hit 500k no problem if you do things like everyone suggests.
    I can see it go to million even!
    Post pack when you hit 200k. Won't be to long.
  16. Raidin
    238
    182
    Houston, TX
    I need my car for work so it needs to be in good running order all the time. I plan to follow the schedule strictly.
    I run somewhere between 80k to 100k per year so I will keep you guys posted on any issues I come across.
    Thank you to everyone who posted recommendations to keep my car running well!
    ztanos likes this.
  17. Raidin
    238
    182
    Houston, TX
    I talked to the service rep at my dealer to get prices. When I asked about the PCV valve, he told me he's never seen or heard of it being replaced on any Prius, regardless of mileage.
    Why is it recommended to replace the PCV valve?
  18. jdenenberg
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    If a PCV valve gets gummed up, you will burn some oil. It is a genarally good protocol in most cars to replaced the PCV at regular intervals. Note that Toyota treats end of life of their cars as 150k miles. I keep my cars much longer than that so proper maintenance (my son's 1997 Outback is now at 280k miles, my wife's 2001 Jetta is now at 100k miles, and my 2004 Prius is now at 253k miles) is called for.
    JeffD
  19. frodoz737
    4,297
    2,347
    33
    Raidin...please be careful with service reps...especially with the Prius. Many times they won't recommend common sense maintenance because it is not on their list or profitable, then turn around and recommend services not needed...pushed to turn high profits for the department and commissions for themselves.
  20. Raidin
    238
    182
    Houston, TX
    This will be my first car going beyond 110k miles. I plan to keep up with regular maintenance.
    I understand that service departments at dealers don't always say things honestly or straightforwardly, but I just wanted to know what they think, and take their advice with a grain of salt.
    I asked about prices, and got the following:
    Brake job, per axle - $189.99
    Brake fluid replacement - $89.99
    Spark plugs - $114.99
    Coolant flush - $129.99
    ATF - $189.99
    The brakes I can do elsewhere since they're basically 4 times more than most places. The rest is stuff I wouldn't feel comfortable doing anywhere else except hybrid specialists, which I don't think we have here.
