Maximum EV range
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by plchung, Apr 18, 2012.
  1. mikenewmediary
    100
    24
    Bridgewater, Ma.
    Bisco,
    The one nice thing about waiting is we can take all the stuff we have read over the past 6 weeks, and try it for ourselves.
    I am curious about how Paradox regen his battery while driving terrain he was familiar with, I will definitely try this. I been mapping my commute out with hills etc.... for the pas 3 weeks...
    Mike
    52,724
    absolutely. i have a big hill to climb 1/2 way thru my commute, and although it ate up some battery, on the way back i picked some of it back up, giving me the extra i needed to get home.
  3. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    Ok, so I drove home today with the fan on the whole way. I played around with the AC during the stop lights to observe the change in current from the battery. Here are my observations:
    Turning on just the fan appears to draw about 1 amp - the fan was on "3 bars", set to LO with no AC
    Turning on the AC appears to draw an extra ~5 amps immediately. However, it seems that once the compressor is running, the fan + AC combo was drawing about 2.5 - 3 amps.
    The fan "bars" go up to 6 or 7. I turned it up and noticed the current would go up by about 0.5 amps for each additional bar, roughly.
    I estimate that on my drive home today, with the fan on 100% of the time and AC on for about 50%, I lost about 0.25 to 0.5 miles of EV range.
    This was all done in Eco mode. Although my route is the same, there are variances in traffic flow and traffic lights. Today, there was more traffic on the streets than normal, hence the range of 0.25 to 0.5 EV miles lost. All the current readings were from the Torque app running on an Android tablet, connected via ODB2 bluetooth adapter. All the readings were "recorded" while stopped at a traffic light. I have a log of all data recorded in 1 second increments if anyone is interested.
    Having done this "test", I will not hesitate to use the fan or the AC when the need arises.
    8 people like this.
  4. SimiPrius
    SimiPrius Member
    247
    60
    Simi Valley,Ca
    Interesting....When I turn on the fan (with or without air) I lose about 1 mile of EV range. However, I did not pay any attention to the fan speed. I will try adjusting that tonight and see if the range varies. Thanks. I have been drinving with the windows open to increase range, but it will get hot soon and that will have to end. Thanks
  5. epoints
    epoints Junior Member
    86
    Sunny Southern Cal
    Does the EV range improves base on how you drive? For example, Monday my EV range show 11.8mi, Tuesday and Wednesday, the range show 12.5? And today, the range showed 12.5 and after 4.8mi to train station, it still shows 9.4mi. I am pretty sure that I was driving within the EV range.
  6. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    This model is all about offering an affordable plug-in.
    The room for expansion and a bump in energy density will be a natural path for the 4th generation Prius.
    A loss of vertical storage space (about 2 inches) wouldn't be a big deal. I wouldn't have as much of a desire to plug in at work though, since the pack wouldn't be completely depleted.
  7. mrbigh
    3,686
    699
    Long Island, NY
    I completely agree with Paradox, I rather loose some "spare unusable area" in order to gain more electrical range
  8. ultraseven
    ultraseven New Member
    47
    SF Bay Area
    Silly question but is there a hack to extend EV range? Essentially it's just the same battery, but the 11.5 miles I usually get is hopelessly conservative considering I have at least 80% battery capacity after one trip.
  9. mrbigh
    3,686
    699
    Long Island, NY
    Working on it...........
  10. bisco
    52,724
    yes, it's constantly recalculating based on available battery and past usage.
  11. bisco
    52,724
    and make sure temp is set to 'low'.
  12. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    Why would you suggest that? If it's cold, setting the temp to low prevents the ICE from starting to provide heat, but SimiPrius says it's going to get hot. Setting it to low when it's hot will cause the A/C to run extra hard, depleting EV range even faster.
  13. bisco
    52,724
    the a/c won't run if it's off.
  14. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
  15. ryogajyc
    985
    165
    Reseda, CA
    I'm asking about gallons saved based on a single full charge not cumulatively. I usually see 0.2G saved (resetting the EV Driving Ratio before driving will a full charge) and I'm wondering if those who managed to get 15+ EV miles saw 0.3G or more.
  16. rogerv
    1,639
    317
    OK, thanks for explaining. I'm using trip 'B' as a cumulative record, and trip 'A' I reset each time I refuel, so obviously I don't get the individual trip/charge results that you do.
  17. iFreedom45
    iFreedom45 New Member
    The PRIUS C puts the traction battery under the rear seat. I wonder if in the future, an addtional battery pack could be installed there to extend the range even more ...:confused:
  18. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    While not directly under the seat like you're sitting on it, in the Prius the gas tank is there. I don't think they want them that close perhaps.
  19. bisco
    52,724
    i made my 14.9 mile commute tonite with .4 to spare. i think i'm developing some techniques (trying not to p&g) speeding up going into a hill and slowing as i go up. my ev range went from 13.3 yesterday to 13.5 today.
  20. drash
    drash Senior Member
    2,593
    1,337
    Upstate NY
    XLE AWD-e
    Yep what I found too. It doesn't drain nearly as much if the speed increase is going downhill. It seems to work well with "energy driving" to allow the car to pick up lots of speed going down a hill and then let it bleed off going uphill. I just keep a steady pressure on the gas pedal. Works like a charm. Plays hell with whoever is following though.
    :D
