MD-Tech PHEV Conversion Kit
Discussion in 'Gen 2 Prius Accessories & Modifications' started by sushp, Dec 14, 2012.
  1. sushp
    sushp Junior Member
    27
    Darmstadt, Garmany
    There is a lot of confusion about who designed the Enginer PHEV kit and who owns the patents.
    MD-Tech is a brand name owned by Shanghai Fountainhead Electronics, SFE.
    The original idea for the PHEV kit is credited to Enginer. In the early years SFE and its Engineers did the research and development for the PHEV kit. The PHEV kit was supplied to Enginer which set itself up in Shanghai and then the US. Enginer do not hold any patents on the PHEV kit developed by SFE. MD-Tech have always had the kit on sale with a one year non-compete agreement for the US. This period is now over as Enginer have not bought kits from SFE for over a year. SFE lost their PHEV designer to Enginer but now that Enginer has gone out of business the PHEV designer is back at SFE.
    SFE are working with Plug-in Autos UG out of Germany, for European distribution. The current status of the kit is, vehicle EMC testing is underway by TÜV labs in Shanghai.
    There are many changes to the kit in the latest version and these may not be reflected in current documentation available. As soon as all the changes have been confirmed they will be posted here and on the Plug-in Autos website, http://www.plughybrid.de
    I believe the above information to be correct, if anyone knows anything different please comment.
    52,861
    thank you!
  3. sparkskard
    sparkskard Junior Member
    cotati
    2002 Prius
    Are there any in the us to take there place ??Is there any one still interest in Prius conversion ? Any kit still being make in US ??
  4. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    The kits were always built in China. I think Jack Chenny ordered in bulk from China. MDtech 上海樟村电子有限公司 were the original makers of the Enginer kit.
    It is just a matter of somebody becoming a distributor of MDtech in the USA. As far as I know there are no distributors in the USA.
    [email protected] likes this.
  5. sushp
    sushp Junior Member
    27
    Darmstadt, Garmany
    The kit puts out 1-20 amps, which is good for city driving a Prius averaging 30-35km/h. The Prius uses about 14 amps at 33km/h. You'll get an hour of driving at that speed on the 4kWh rated battery.
    The reworked Kit has the E-Mark certification.
    The new BMS (HW version 8.0, software version 1.0) data is up on PHEV kit System - Plug-in Autos
    A couple of notes on the data: The graph shows single cell voltages against time. The PHEV kit was charged and plugged in at the start of the test, then bench tested at 210v 18 amps, then recharged.
    Charge cut-off has been reduced for a single cell Hi 3.65v. Charging restarts if the Hi cell drops below 3.35v. The B1-B16 columns, (cells 1-16) in the data show active balancing with a "+" sign. Active balancing is on permanently.
    It is tab delimited so save it, then import it with a spreadsheet app like Excel.
    Here is the direct link to the data.
    https://www.plughybrid.de/wp-content/uploads/2012/05/for_web_3x35V-recharger-test-data.txt
  6. lopezjm2001
    1,146
    407
    Sydney Australia
    Hi Sush,
    Good to hear your kit is doing well. I noticed your website shows the old Version 5 MD-Tech converter which I have in storage and is faulty.
    1. Why are you not asking for the Converter to have your own design logo on it. I would be slapping my own label on it and the entire kit itself. This is what Nilco2 does in Australia. Hardly anybody notices that it is a Enginer kit.
    2. Are you going to have Version 6 available.
  7. sushp
    sushp Junior Member
    27
    Darmstadt, Garmany
    The Enginer V6 open architecture was adopted for overheating issues with the converter. Components have been changed in the MD-Tech converter to reduce waste heat losses and EMC noise. In Europe the climate is more temperate, converter heat protection shutdown is not as big an issue as it may be if you are living in a hot region. The open architecture has been discussed and it will be offered in the coming months. MD-Tech have version control for their changes now, so hardware, software and components are easily referenced. Labeling and version control should help users discuss any issues they find and discover resolutions quickly.
    There are some legal issues if I relabel the kit. It may be useful to have one name for a worldwide presence. This eliminates much of the confusion about who is the manufacturer and helps to build MD-Tech's brand name. By setting up a contract with MD-Tech as a Sole Distributor for your region, you will have the ear of MD-Tech for any changes you need for the kit to work well in your region, if climate or layout is still an issue with the latest changes. The feedback loop for changes is very fast. They have the R&D Team and they have EMC, testing lab facilities at a big University. As you can see with the BMS data, things are going very well. We are getting around 88% efficiency for the system overall, (energy in vs. energy out).
  8. lopezjm2001
    1,146
    407
    Sydney Australia
    So your bms16D is balancing permanently. It mostly balances at the bottom? So your cell 7 causes a HVC at 3.65v.
  9. sushp
    sushp Junior Member
    27
    Darmstadt, Garmany
    Okay, please analyze the data, the pack balances quite well on average to within 0.05v for the difference between the Hi cell and the Lo cell.
    Please refer to the BMS as MD-tech V1. BMS16D is a bifurcation Enginer had last year. There was split between Enginer and MD-Tech in 2011.
  10. lopezjm2001
    1,146
    407
    Sydney Australia
    Like you said. The Enginer kit is not really suited to the Australia's climate. It is also not suited to a country that is lowly populated with low density. To make the Enginer kit really work and get the best fuel efficiency you need to drive at low speeds in heavy traffic which is associated with heavily dense populations. In heavy traffic the Enginer kit has a better chance to top up the Prius battery and is then induced to do more EV or stealth mode.
  11. sushp
    sushp Junior Member
    27
    Darmstadt, Garmany
    Correct. You should still see some decrease in fuel consumption. Starting the engine to help the topping up process will allow you to go back in to EV mode more often and for longer periods than without the kit. Every amp should save fuel.
    tjgeel and [email protected] like this.
  12. lopezjm2001
    1,146
    407
    Sydney Australia
    Just a thought. It would be handy if the MD-Tech BMS display unit would show whether a HVC occurred during the last charge cycle on the display screen (and not having to go into the SD card). If the display unit would show the last time a HVC occurred, the number of times it has occurred with a time/date stamp next to each HVC and the number of successfull charges (i.e. no HVC), the estimated charge time, this would be of great help to indicate that the RFE battery pack is balanced. It is really important that a bettery pack is balanced at the end of a charge cycle. It can also indicate any other underlying problem that may cause a HVC at the wrong time.
    Its a wonder that with all the R&D being done that they have not thought of this idea.
    At this point of time I have not seen much improvement in the Enginer BMS16D to install any confidence. At this point I still recommend using a miniBMS instead. Only time will tell.
  13. lopezjm2001
    1,146
    407
    Sydney Australia
    Your cell 7 is causing HVC.
    Your cell 13 is causing LVC. Not balanced. It probably just needs more time to balance. Is this the data you are referring to? Maybe you have a link to your most current data log.
    The third graph shows all the values of Cell 13 when it was being balance injected by the MD-Tech BMS.
  14. lopezjm2001
    1,146
    407
    Sydney Australia
    That is a hard habit to break. After all it was the creation of Jack Chenny not MD-Tech. In what ways has the MD-Tech BMS Ver. 1 improved over the latest version of BMS16D?
    Since you are located outside the US and your MD-Tech V1 BMS is selling for US$394 most Enginer users (majority are in the USA) may source a different BMS from inside the USA at a better price. And then take the cost of a international delivery into account from Germany to USA.
    Are you selling the kits internationally at FOB (free on board) sea freight or by air-freight like DHL.
  15. sushp
    sushp Junior Member
    27
    Darmstadt, Garmany
    If people can see the last 3 minutes of load, before LVC cut off, 75% of the pack is showing rapid voltage drops. This is an indication that the pack is at the bottom of its useful range. Keep in mind that the requirement of the BMS is to protect the battery cells from over discharge and over charge. This BMS fulfills these requirements. (BMS16D had problems with HVC set at 3.85V, over time the high cell, if not balanced would fail. ) By reducing HVC to 3.65V the margin for damage to the cell, due to any errors in accuracy or delay in cut off, are further reduced.
    Another requirement of a BMS is to balance a pack. Enabling it to take a charge according to its specs and deliver that charge as a measurable output. The battery pack is rated at 4kWh. The useful energy coming out is around 3.85 kWh as can be calculated from the data. The BMS fulfills this requirement.
    The BMS is doing its job.
    BMS Display is "nice to have" and is useful for diagnostics. The BMS Display is not a requirement for operation of the BMS.
  16. lopezjm2001
    1,146
    407
    Sydney Australia
    I never said that your BMS was not doing its job. It will keep injecting current into cell 13 and other low cells which may increase the range a bit more. It still has a bit more balancing to do.
    Changing the hVC from 3.8 to 3.65 volts is good.
    What is the MD-tech charger end voltage? At 15amps it is a low charging rate (0.1875C) into four buddy cells..
    Below is a quote explaining why it would be a good idea to decrease the HVC on the MD-Tech BMS.
    Discussions about LiFePO4 cells and Battery University | Page 3 | PriusChat
  17. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    116
  18. NortTexSalv04Prius
    915
    116
    Will MD Tech sell on Ebay site?
  19. sushp
    sushp Junior Member
    27
    Darmstadt, Garmany
    You would have to ask MD-Tech about ebay.com. I will be posting on ebay.de in March 2013 under username "Plug-in-Autos". You need a Distributor in the country (or economic area), that you are in to handle service and warranty. Similar to vehicle service warranty procedures, you need service warranty procedures and price lists for those repairs that can be claimed under the service warranty. If you are interested in becoming a Distributor please contact me and I can give you some pointers. There will be differences for the country that you are in, but a small business adviser or a government small business advice bureau should help you with the basic things that you need.
  20. glyndwr
    glyndwr Member
    219
    42
    South Wales, UK
    Hi Lopez,
    I have an enginer ver.5 4kwh kit with a bms16D software rev 3.3.
    Is there anything i can adjust myself or mod on my bms that can reduce the HVC to 3.65v.
    The balance function is set ro OFF position and i manually balane myself, but i do rely on the bms for the high and low voltage cut offs.
    I have enquired with minibms and they are unsure that their system will work in the UK as we are on 240v mains supply other that 120v US supply voltage, althouh at 240v we have a lower amperage, which may help.
    Thanks, Anthony.
