mice debris in heater box
Discussion in 'Gen 2 Prius Main Forum' started by earthman, Nov 24, 2009.
  1. earthman
    earthman New Member
    47
    Vermont
    That was a helluva afternoon. Spent the best part of it cleaning debris out of the lower part of the heater box, below the fan. Tried sucking it out through the caged plastic frame but had no luck, in fact ended up breaking a small plastic bar of the frame. Finally decided to remove the plastic bottom. First the electronic gizmo mounted to it. Then barely managed to get a screwdriver on the four phillips screws holding the bottom on. I did get them removed, just barely separated the bottom of the frame from the sides then sucked crap out wth the skinny wand that comes with the vacuum.
    Anyway, there has to be an easier way..........please God, let there be an easier way to get this cleaned out.
    Anyone?
  2. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    For cleaning, you can get a vacuum machine adapter kit at home centers (I got mine at Home Depot). You can then put small diameter vinyl tubing on the adapter tip.
    To keep the mice out, you remove the windshield wiper arms and the plastic piece that goes across the car above the engine. That gives you access to the holes they get in through. Attach mesh over those openings and your A/C system will be mouse resistant.
  3. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    This file has the best easy to follow instructions and pictures for removing the windshield wipers and cowl:
    [​IMG] BT Tech Strut Tower Brace Install - By GadgetDad (Lee) v2.doc
    While you're in there under the cowl I would screen-off the several small and large openings to prevent mice from entering the cabin. Mice have been known to especially like building homes in the cabin filter area.
    Here's a pic of my quick and dirty screening job using vinyl double-screened gutter guards and tape (the best or better screening job would use metal screens and screws):
    [IMGLINK]http://priuschat.com/forums/members/boo-albums-prius-picture460-strut-tower-brace-install-while-you-have-plastic-cowl-removed-its-good-time-put-screen-over-holes-where-mice-other-rodents-can-otherwise-enter-into-dash-cabin-areas-i-didnt-have-metal-screening-material-self-tapping-screws-handy-so-i-used-what-i-had-plastic-gutter-guard-gaffers-tape-i-think-itll-work.jpg[/IMGLINK]
  4. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    Well I am still stuck on the seemingly very simple step of removing the wiper arms, especially the driver side. The arms seem stuck very tight on the threaded post. I did raise the blades to relieve the tension but still had trouble pulling the arm out. The driver side arm base sits in such a deep and narrow well (part of the plastic cowl)
    that I haven't been able to find a suitable puller to insert into there to help me pull the arm out. :(
  5. Boo
    5,051
    483
    97
    Flushing, NY
    Unless I'm misunderstanding your dilemma, go to the next page of the instructions I posted. The arm doesn't lift up without first unscrewing the bolt. You'll need a 14mm socket as shown and described in the instructions.
  6. Patrick Wong
    18,199
    6,464
    After you've removed the wiper nut, put the wiper blade back down so it is resting on the windshield glass. Press down on the wiper arm with one hand to relieve the pressure that the spring in the arm creates, and try to wiggle the pivot point at the end of the arm that the threaded shaft runs through. Then hopefully you can just pull up and remove the wiper arm without having to use a puller.
    Regarding the OP's post, if debris was found below the fan then I assume that the mice got through the cabin air filter. If the filter was undisturbed, then it sounds like the mice may have entered the car at a location other than the front cowl, such as the openings behind the rear bumper near the hatch.
  7. earthman
    earthman New Member
    47
    Vermont
    Yes, the mice chewed right through the cabin air filter, bits & pieces of it in & below the fan along with the rest of the debris.
    So the trick is to keep them out in the first place, got it. But when they do get in is there an easier way to clean up other than disassembling everything? Even with a smaller more flexible hose you still won't get into all the nooks & crannies.
    Patrick, more openings on the rear of the car to screen? Easiest way to get to them? I'm thinking of using that 1/4" hardware cloth, think that will suffice?
    Thanks for the help guys.
  8. 2009Prius
    2,705
    510
    63
    Yes I did remove the nut first.
  9. 2009Prius
    2,705
    510
    63
    So maybe I don't understand the mechanics of the wiper arm spring. Did you mean that even with the wiper blade raised (as if I was cleaning it), the spring would still apply some stress that resist the wiper arm removal? :confused: I just don't see how could this happen. :confused:
  10. Patrick Wong
    18,199
    6,464
    I'm not aware of an easier way. 1/4" metal wire mesh would be fine.
    Note that when you slam the door shut with the windows closed, that you don't feel any pressure on your eardrums. The reason is because there are a couple of rectangular vents in the hatch area, one on each side. You might have to remove the 12V battery on the right side to find the opening on that side. Also note the traction battery ventilation duct, you might want to screen the opening for that duct.
    No, if you raise up the blade the spring is no longer applying pressure. However the hole in the arm is still cocked against the pivot shaft due to the pressure previously applied by the spring, so that makes it hard for you to pull off the wiper arm.
    If you push down on the wiper arm with the blade on the glass, then you are applying force to counter the pressure that the spring had previously exerted. When you do so, you should find that the arm will wobble a little against the pivot shaft.
    Thus the hole in the arm no longer will be cocked against the pivot shaft, and you may now be able to pull the wiper arm off with your hand. Try it and see.
  11. patsparks
    10,664
    567
    Adelaide South Australia
    I have never used a puller in my life to get a wiper arm off, with the arm up off the screen just wriggle it and it will come off.
  12. earthman
    earthman New Member
    47
    Vermont
    I ended up screwing some 1/4" hardware cloth over the openings in the wall behind the windshield wiper motor. Of course to do this I had to remove everything we've already talked about plus the wiper assembly & the black pan below & behind it. Then I was able to drill pilot holes for the screws I attached the screen with. It came out good, if I do say so myself.
    The only problem is it was only after I had everything back together that I thought oh yeah, I should check the heater fan box again. Sure enough in the week since I last cleaned it there were signs of mice. A little chewing on the cabin air filter, debris & mouse shit. Now I have to wonder are the little bastages still in there or not. Guess I'll know if & when it starts to stink of death. Or will they chew through something else to get out. Ahhh, life in the country.
  13. Ct. Ken V
    Ct. Ken V Active Member
    535
    57
    Bolton,CT
    all,
    I may be totally off base here, but when I had my windshield replaced earlier this year, I don't remember the glass installer removing the driver's side wiper (maybe I'm wrong). I remember him removing the 2 capnuts at the middle that held on the passenger side wiper & lifting that off as one piece (I think that's what I did too when I screened off my openings). But for some reason, I don't remember him having to remove the driver's side wiper from its shaft.
    I know he took the passenger side plastic tray off, but I don't seem to remember him removing the driver's side tray (which WOULD require removal of the driver's side wiper arm). I thought he just loosened it to get at the nuts underneath that hold on the wiper's motor/transmission assembly. I thought he then just lifted everything off together as one unit. I DO remember thinking how much easier his method seemed compared to what I had actually gone through when I did my screening of the openings. I could be totally wrong though.
    For any of you who take off the driver's side wiper, be aware that there is a little clear dot in the black area near the lower part of the windshield (even on the aftermarket glass that I got) to align the outer tip of the driver's wiper with before pushing it all the way onto the shaft & tightening. You shouldn't need to worry about the alignment of the passenger side wiper if you undid the 2 capnuts of the articulated linkages because when you remount that it should come back into place automatically. My original windshield had a clear dot for the tip of that wiper too, but not the replacement windshield.
    Ken (in Bolton,Ct)
  14. earthman
    earthman New Member
    47
    Vermont
    That sounds about right Ken. You could probably avoid removing the drivers wiper.........but what the hell, it was not that big an extra step. And, it's done.
  15. 2009Prius
    2,705
    510
    63
    I tried to push down on the wiper arm with the blade on the glass in vain at home. Frustrated I asked some coworkers for help. What he did was to raise the blade and rock the short arm back and forth with some force until the two cones separated. It was like magic! I guess the rocking is more effective than just pushing in one direction to break the bind between the post and the hole (both cone shaped). Thanks for the suggestion and detailed explanation - it always helps to understand the underlying principles of things.
    By the way he thinks the nut was put on way too tight although I was using a good torque wrench tightening to the spec ~ 15 ft-lb.
  16. Patrick Wong
    18,199
    6,464
    Glad that you've been able to figure that out. As a DIYer you need to be able to remove the cowl that runs across the hood compartment, in order to perform tasks like replacing the front struts, removing the cylinder head valve cover, gaining service access to the inverter, finding the brake pressure accumulator pump mounted to the firewall, etc.
