Mileage penalty for Central Texas winter
Discussion in 'Gen 3 Prius Fuel Economy' started by Jonny Zero, Oct 14, 2012.
  1. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    First "winter" with my Prius. What can I expect? Most of the time highs would be in the 60-70, and lows would be in the 30-40. Freezing is rare, snow / sleet would typical shut the city down anyway. My commute is 16 miles one way. Car is parked in an attached garage with also houses a water heater. It stays 10 degrees above outside temp in the winter.
    My old 2002 Camry actually did better in the winter than the summer, because of no AC use.
    48,996
    that's not winter my friend, that's autumn.:p but you will probably see a 10% reduction. do you get winter blend?
    Jonny Zero likes this.
  3. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    No idea about winter blend.
    48,996
    if you don't get winter blend gas, you probably won't see much change. depends how much driving you do with the heat on.
  5. rebenson
    rebenson Member
    364
    43
    Suburb of Chicago
    I agree, winter??? however I would think you would actually do better since I would "hope" you would be using that A/C alot...
    Don't forget, the compressor is on when front defrost is on....
  6. Spindifferent
    Spindifferent Member
    155
    79
    Central Texas
    Having been through two Central Texas "winters" with a 2010 Prius II, I have noticed that the MPG does decrease a small amount when temps are consistently below 50 degrees. Maybe 3-5 MPG reduction depending on temps, distance, road/weather conditions.
    - Spindifferent
  7. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    You might consider blocking 50% of your lower grill for the "winter" months. If you have a scan gauge, you can monitor the engine temps, but you should be fine (I've driven in 90+F with 50% grill block and my engine temps were still around 190 - 195F range, which is the normal, unblocked engine temperature).
    The grill blocking will help with the initial warmup period, because it is limiting the cool morning air going into the engine (cooling down the coolant when the car is desperately trying to warm up the coolant). You may not see as much of a drop off in your winter MPG's by doing this.
    If you have a scan gauge, you can also find out when you car exceeds the 159F mark (thus going into the S4 stage. This is when I, finally, turn on my heater and turn off my seat warmer.
