Modify Prius C software
Discussion in 'Prius c Technical Discussion' started by Garycs, Oct 8, 2015.
  1. Garycs
    Garycs Junior Member
    Montgomery
    Hi:
    I have seen references to PHEV kits but have not found much information concerning the modification of the Prius C ECU. I would like to modify the software to allow/cause the car to stay in EV mode when I switch it in. It seems to come out of that state around 6 MPH. Most of my commutes are less than 10 miles. I would also like to build a charger that I can dial down to 350 mah or so for battery conditioning and then ramp up to ~30 A when I am at work. My employer supplies "free" charging stations.
    I saw a charger that was constructed from two LED drivers with a few other parts from ebay but lost the link. That charger would work well for the maintenance.
    My battery indicator never lights the top bar. the car was a total that sat for about a year before I found it and put it back together. I am guessing that the battery suffered from non-use which is why I would like to build a maintenance charger.
    Any help, information, or links would be greatly appreciated.
    Gary
  2. vskid3
    vskid3 Active Member
    773
    228
    If you're looking to do 10 miles of EV driving, a PiP or other PHEV is the best way to go.
    Look at the grid chargers people make for the Honda Insight and Civic Hybrids for ideas. You'll probably need to adjust the max voltage to the C's max. Maintenance charging periodically isn't a bad idea. However, you probably don't need one. The Prius tries to leave some extra space in the battery for regen. Unless you're going down a large hill, its pretty normal for it to not get charged all the way. I'm not sure how it is in the C, but my Gen2 will "actively" charge the battery to 6 out of 8 bars and try to maintain it about there. I don't think I've ever seen it get to 7 or 8 bars without going downhill.
    Turning your Prius into a PHEV using just the stock battery is a pretty sure way to drastically reduce the battery's life expectancy. The car only uses about the 40% to 80% charge range (again, this is for the Gen2, may be a little different for the C) of the battery in order to make it last for years. This is range is scaled to the battery charge indicator, so 0 bars is actually ~40% and full is ~80%. Also, charging the battery at 30A would be unecessary if the car is going to be plugged in most of the day. The pack is only ~7Ah and should be at least 50% full most of the time. That 7Ah brings us to how small a non-PHEV Prius' battery really is. Multiplying that by the 144v of the C's battery pack gives you about 1kwh if you go from 100% all the way to empty. Most EVs average around 300wh per mile, so at best that would give you 3 miles of EV.
  3. Garycs
    Montgomery
    Vskid3 Thank you for your reply.
    I didn't realize the battery was so small. It looks like I will need to give up the "trunk" to add more electrical storage.
    I see quite a few Prius battery cells on ebay.
    Do you know what the charging logic looks like?
    It doesn't seem to bring the battery back to a consistent level.
    Reading your reply it looks like this behavior is by design.
    Do you know of anyone that has increased the battery capacity?
    Gary
  4. Toppcat
    Toppcat Member
    223
    69
    Northern California
    You be better off trading it in for a volt! Way in the cost of convertions voided warranty, hardly worth it!
  5. vskid3
    773
    228
    Take a look at the Enginer PHEV kits for the regular Prius. A setup like that would probably be the easiest route to go (other than buying a PHEV). They might even be able to work with the C, I believe the DC-DC converter's output voltage was adjustable.
  6. bisco
    48,996
    try pis for a (turnkey?) solution but expensive. iirc, there may be a thread here from a guy building a larger battery for the c, try searching. not sure he ever finished though. the best thing you can do is buy all the schematics and study what others have done on the hardware and software side on the lift back. some very intelligent people have made a go of it, but it's not easy.
  7. djdawn
    djdawn Active Member
    255
    116
    Escondido, CA
    2014 Prius c
    A means to force EV mode when I want sounds like an awesome idea. It would be useful if I'm only moving my car from one parking spot to another, or if I want to restrict acceleration to only using the battery. I wish it was a normal option. Regarding 6MPH, highest speed I've ever maintained and still remained in EV was 42MPH. I found that if I was too aggressive on the accelerator I would drop out of EV immediately.
  8. bisco
    48,996
    i hope 'low speed ev anytime' is on all the new hybrids.
    djdawn likes this.
  9. dborn
    dborn Junior Member
    44
    Montreal, Canada
    2015 Prius c
    It's not on the 2015 C anyway. It's not on my 2013 Camry hybrid either.
    I don't know why Toyota isn't giving us low speed EV either. At least moving without the "gas" pedal should be allowed for moving the car around the driveway/parking lot.
  10. bisco
    48,996
    absolutely.(y)
  11. ericbecky
    ericbecky Hybrid Battery Hero
    4,365
    3,209
    Madison, Wisconsin
    It would be better to have 2 different chargers.
    The trickle charger is easy to make. Parts would be less than $100. Basically buy some led drivers and wire them in series. Add a fuse and other safeties. I have shared plans in the past.
    Making a 30amp charger could be a bit challenging. Do you just want to use it at home? Buying one might be pricey. How much are you looking to spend.
    Lastly, I haven't researched much about adding EV mode. How about making an out of gas more instead?
  12. priusmatty
    priusmatty Active Member
    304
    108
    Louisiana USA
    2020 Prius
    L Eco
    I am not sure if this directly addresses your topic, but I do know that the computer intentionally keeps the battery from about 30% to about 60% charged, because shallow cycles make it last longer.
  13. X HCH2
    X HCH2 Member
    119
    38
    Upstate SC
    Actually the charge is maintained very closely between 40 and 80%.
    X
    priusmatty likes this.
