Most Obscure Prius Facts (Way out there)
Discussion in 'Gen 2 Prius Main Forum' started by 200Volts, Nov 20, 2006.
  1. KTPhil
    KTPhil Active Member
    1,379
    One feature, known by most but a mystery to a small minority, is that if you fail to replenish the gasoline supply when the Prius tells you to, you will run out.
  2. Tideland Prius
    16,206
    The OAT reading is actually in Celsius even for the US-spec cars. Watch, as it'll skip numbers in Fahrenheit.
  3. NuShrike
    NuShrike Active Member
    1,378
    The Power button on the audio head unit is equivalent to pause/mute.
    The JBL amp has a programmable equalizer (although unknown what equipment is needed to aftermarket reprogram it).
  4. Stilview
    Stilview New Member
    61
    Northern VA
    An incoming or outgoing Bluetooth call while listening to the CD pauses the CD.
  5. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    <div class='quotetop'>QUOTE(miwaku @ Nov 21 2006, 09:10 AM) [snapback]352445[/snapback]</div>
    Well, I'll be a monkey's Uncle. My stereo turns on with one push of the mode button, too! Oops. -_-
  6. darelldd
    6,057
    389
    Northern CA
    <div class='quotetop'>QUOTE(Sarge @ Nov 21 2006, 07:21 PM) [snapback]352859[/snapback]</div>
    Ha! Not. Unless they thought we wanted fog lights that do nothing. A cargo light and puddle lights that are too dim to see anything with, arm-rest padding that does't exist, no factory tint stip at the top of the windshield, an exterior antenna that gets in the way of cargo racks, no way to "officially" carry a bicycle outside the vehicle, ugly wheel covers, no height adjustment or lumbar adjustment for the driver's seat, no seat-heat option, dangerously invisible 5W tail lights, no standard interior bulb configuration, no LED lighting except the brake lights (and glove box)....
    Uh... I've decided that I have other stuff to do, and I could be here all night. I do love the car, but it is by no means perfect!
  7. Oxo
    Oxo New Member
    533
    Oxfordshire, UK
    <div class='quotetop'>QUOTE(klevitsky @ Nov 21 2006, 02:45 PM) [snapback]352662[/snapback]</div>
    Yes, but can you get the lid of the fuse-box open first time? Not easy. I was shown how to do it but I still find it hard to open.
  8. Sarge
    Sarge Senior Member
    1,311
    767
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    <div class='quotetop'>QUOTE(darelldd @ Nov 22 2006, 12:43 AM) [snapback]352905[/snapback]</div>
    OK, point taken. :)
    My comment was more of a 'rhetorical' (?) reaction to something I didn't realize, not necessarily to be taken literally. ;)
  9. GeronimoPFudgemuffin
    62
    <div class='quotetop'>QUOTE(darelldd @ Nov 21 2006, 06:10 PM) [snapback]352764[/snapback]</div>
    A while back I got the chance (totally deserted four-lane highway") to do what turned out to be a 9-minute low-speed coast. Rather than hold the pedal just off the stop to maintain a "glide," I instead just shifted to neutral. And guess what? Though I was rolling at about 25-30 mph for several minutes, I got "the missing tooth." No mpg bar was displayed for that period.
    I can't say whether the mileage computer added this distance to its MPG calculations but, based on the missing green bar, it's possible it did not.
  10. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    <div class='quotetop'>QUOTE(Warwind @ Nov 20 2006, 08:52 PM) [snapback]352357[/snapback]</div>
    I didn't think it was true that you couldn't turn on the driver vanity light while moving, but since I can't get to my car now, I checked the wiring diagram. For 2004, the wiring diagram does not support your theory.
  11. DanMan32
    3,799
    26
    Tampa Bay, FL
    <div class='quotetop'>QUOTE(Sarge @ Nov 21 2006, 02:20 PM) [snapback]352628[/snapback]</div>
    That's why there is a jump terminal under the hood.
  12. DanMan32
    3,799
    26
    Tampa Bay, FL
    That's not true. It will display 99MPG. At least it does on the 2004-2007. For the classic, it displays 0.
    Reason: divide by zero is an error, but something has to be displayed. However, a display as close to infinite is more logical based on approach analysis. If you manage to drive 50 miles and use 1 gallon of gas, you get 50MPG. If 1/2 a gallon, that's 100MPG. If 1/4 gallon, 200MPG. Keep bringing the number of gallons smaller and smaller, and the MPG goes up and up. So if you were REALLY, REALLY close to zero, your MPG would be REALLY REALLY high.
  13. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    the 12 v battery being in the trunk area and the jump post being in the front serves two purpses.
    1) familiarity. the jump post is where its "supposed" to be.
    2) safety. jumping a battery can be a hazardous job. escaping hydrogen gas could explode due to arcing when connecting jumper cables. that is why its recommended that you used a grounded part of the car instead of the negative battery post. connecting jumper cables on a point at the opposite end of the battery (dont panic, new batteries are way less susceptible to this problem) just makes the process a no-brainer for anyone
  14. Sarge
    Sarge Senior Member
    1,311
    767
    2023 Prius Prime
    XSE Premium
    <div class='quotetop'>QUOTE(DanMan32 @ Nov 22 2006, 08:47 AM) [snapback]352959[/snapback]</div>
    I also tested the vanity light on my 06 yesterday on the way home. Driving ~30MPH, I pulled down the visor and slid open the cover and indeed the light came on while in motion. It also turned off when pushed (almost) all the way forward, just as the passenger side does.
  15. koa
    koa Active Member
    980
    45
    Hawaii
    Not sure if this is unique to my 06, but every time I park on our sloping driveway (15-20 degrees) nose down and power off, the gas gauge will reset to FULL no matter how empty it is. It does not reset when powered off on level ground. It will go back to normal when it is filled up again. Not good if this is how it is suppose to work. It works fine if backed in.
  16. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    It's not in the manual, but the 2004-07 comes with a hand crank that can be used for 'flash charging' the traction battery, in case you're away from a 220v outlet and it goes dead on you...
    [laughing]
    Little know Prius feature: even if you're going well above the speed limit, people still tailgate you...just 'cause you're in a Prius. (it's times like these that a modified suspension comes in handy).
    Data Daedalus likes this.
  17. Warwind
    Warwind New Member
    137
    Hedgesville, WV
    I checked in my car, and you're right--the light comes on when you slide open the mirror cover whether you're moving or not.
    But I swear, I checked both lights while driving once, and the driver's side one wouldn't come on while I was moving. When I stopped the car, I checked again, and it came on.
    Hasty assumption on my part...mea culpa!
  18. KTPhil
    1,379
    "That's not true. It will display 99MPG. At least it does on the 2004-2007. For the classic, it displays 0.
    Reason: divide by zero is an error, but something has to be displayed. However, a display as close to infinite is more logical "
    The math geeks here will point out that zero is just as "close to infinity" as 99. Both are infinitely far away, with no mathematical distinction made between the two measurements. It is not intuitive, but the accepted theory of infinity expresses that:
    "X plus infinity equals infinity"
    So in this case with the diference between 0 and 99 equaling 99, we have:
    "99 plus infinity equals infinity"
    Of course, for the average human being, this argument is gibberish, and of course you are right, Dan.
    It took me years to (mostly) undo the damage from being a math major...
  19. hill
    8,278
    <div class='quotetop'>QUOTE(Pinto Girl @ Nov 22 2006, 04:35 PM) [snapback]353178[/snapback]</div>
    Best of all ... the crank will directly engage the the drive line, allowing you to atain speeds up to 50mph, providing your non-steering-arm can withstand the 2,400 rpm's necessary to reach that speed.
  20. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,999
    Fort Lee, NJ
    HV battery pack has usable energy (600 Watt Hours) of about 4 tablespoons of gasoline.
