Most recent tank
Discussion in 'Gen 3 Prius Fuel Economy' started by wesayso, Jun 2, 2011.
  1. kenichols29
    kenichols29 Active Member
    250
    109
    Mckinney, Texas
    The owners manual states that once the gas light starts flashing you have 1.6 talk nd of gas left. Mine starts to flash at 23 miles left typically.
  2. FrankB
    FrankB Member
    117
    53
    Well, the computer display could be misleading me but I "feel" that my MPG average tends to increase on the last 2 bars of the fuel gauge. I had attributed that to the decreased weight of the gas. This seems to happen every tank but I don't have any measurements to back it up.
    To play devil's advocate, the computer display of MPG also seems higher than it should when I fill up as well which is counter to the above logic. I attribute this to the smaller number of miles to use in calculating the MPG allows the higher display. Again, no hard data, just observations over time.
    Frank
  3. Mendel Leisk
    38,322
    Yeah, the car's lighter with a near-empty tank, there is a slight advantage there. Full to empty is what, 45 liters, which is 45 kilos. So a full tank is kind of like having an extra passenger. Still, I just put that out of mind.
  4. wesayso
    wesayso Member
    385
    35
    Hampton, VA
  5. Gabriel Maestu
    Gabriel Maestu New Member
    Tampa
    Just ran through my first tank in my brand new 2014 Prius Four.....babied it to the max, barely ever went to the power bar mode.....got 42 mpg....that's stinks. It's worse than the 2011 insight I traded in. Totally regret buying this thing.
  6. Gabriel Maestu
    Tampa
    42 mpg, 1st tankfull brand new 2014 Prius four, babied it, barely over 2000 rpm. Terrible. My 2011 insight never went this low......total waste of money for this Toyota, as soon as I'm even on trade in, going back to honda.
  7. Gabriel Maestu
    Tampa
    The only sure way of figuring mpg is start with a full tank. Drive till you fill up. Whatever gallons you replace divided into miles driven is your true mpg......not all the hocus pocus readd out numbers on the dash. I can't believe I'm the only one getting barely over 40 while driving mostly in the Eco range.
  8. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    I will be passing the 1000 kilometer mark today. I am on the last blinking bip and it tell me I have 23 kil . before running out ,but I am going to push on because I have 50 kil. to go to reach 1000 tank. I'm at 4 ltr. per 100 for this tank. average speed is 54 kpr. h
  9. kenichols29
    250
    109
    Mckinney, Texas
    MPG is miles divided by gallons replaced. You said gallons replaced divided by miles. My first tank on my 2014 was 44.1 and it went up from there. Its a new car and it will get better mpgs once the tires and the engine are broke in (roughly 600 miles). Also try either no ethanol gas or top tier gas, both of those should net a decent mpg increase. And lastly if the car sat on the lot for a significant amount of time then there could have been some old gas in the tank. Mine sat on the lot for 6 months and I ran a cleaner through the system on my second tank just to clean out an deposits that where left in the fuel system from the old gas (we bought 2 and the other one was on the lot for less than a month and it got well over 50 mpg on its first tank.) Techron is a good cleaner and I think it is on sale at autozone for 2 for $8 too.
  10. cipsaz187
    cipsaz187 Member
    147
    42
    My best tank with pretty much no A/C use. Re-filled and non flashing pip. The temps are dropping so probably won't be able to beat this for quite some time..
    523.90 miles
    8.73 gallons
    $3.359/gallon
    $29.32 total
    60 calculated mpg
    62.5 computer mpg on tank.
    22 mph avg. speed
  11. Gabriel Maestu
    Tampa
    Kenichols.........When I bought my insight in 2011 they suggested techron. Which I will go to after the 2 gas vouchers I got from the dealer, they are for shell gas.
    Have you done a comparison between the reg & premium gas after the car got broke in?
  12. Okinawa
    Okinawa Senior Member
    1,333
    317
    You will get a lot better than that after a few miles.
  13. HaroldW
    716
    95
    Well I filled up and took 10.56 gal for 620 miles = 58.71 mpg
  14. Okinawa
    1,333
    317
    Outstanding.
    HaroldW likes this.
  15. HaroldW
    716
    95
    Thanks , Okinawa. I still had 4.5 liters left! H
  16. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    You cannot judge fuel economy by the results of one tank of gas. Plus, if you are making lots of short drives where it really doesn't get to operating temperature, fuel economy will suffer.
  17. kenichols29
    250
    109
    Mckinney, Texas
    No. gas milrage usually suffers when you go up to a higher octane. Higher octane pump gas typically has less energy and it is harder to ignite. The general consensus is to only run it if the manufacturer calls for it or you have problems with pre-detanation.
  18. John Bergendahl
    102
    17
    gulfport,ms
    I still wonder how I always fill up with 9 gallons and gas indicator is blinking and says like 2 miles left.I always go pump once the 2 miles are up.Does it mean i still have gas let in the tank and the indicator is not accurate?
  19. retired4999
    2,652
    625
    Eau Claire, Wi.
    It is accurate, it just does not want to have you run out of gas! :)
    Okinawa likes this.
  20. John Bergendahl
    102
    17
    gulfport,ms
    ok but isnt tank 11 gals? why cant i fit 11 in then
