Most recent tank
Discussion in 'Gen 3 Prius Fuel Economy' started by wesayso, Jun 2, 2011.
  1. JimboPalmer
    12,470
    6,871
    Greenwood MS USA
    Honestly, I have never owned a tank. I tend to buy very small cars.
  2. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    524.3 miles
    10.11 gallons
    $3.199/gallon
    $32.34 total
    51.86 calculated mpg
    54.6 computer mpg on tank.
    $0.0616/mile
  3. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    522.2 miles
    10.057 gallons
    $3.159/gallon
    $31.77 total
    51.9 calculated mpg
    54.0 computer mpg on tank.
    $0.0608/mile
  4. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    163
    Pierrefonds (Montreal) Quebec Canada
    2450 PSI with a steel 100, at depth of 55' for about 52 minutes.
    With a previous Al-80 was lasting less than 40 mins. Both dives in Maui.
    Yes, on www.ScubaBoard.com I post my Prius mpg.
    Just to keep things in perspective.
  5. yyyiiikes
    yyyiiikes Junior Member
    84
    Austin, TX
    First tank of gas:
    Calculated: 46.6 MPG (448 mi with 9.6 gal) that assumes the tank was topped off by the dealer.
    ECU: 51.0 estimated
    Really nice going 2.5 weeks without stopping for gas.
  6. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    545.3 miles
    11.41 gallons
    $3.249/gallon
    $37.04 total
    47.79 calculated mpg
    50.5 computer mpg on tank.
    $0.0679/mile
  7. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    508.2 miles
    10.113 gallons
    $3.099/gallon
    $31.40 total
    50.25 calculated mpg
    53.0 computer mpg on tank.
    $0.0617/mile
  8. djlen
    djlen Junior Member
    68
    Somerdale, NJ
    Ok, now I'm seeing probably the main reason why I'm getting lower mileage than some of you guys. Your trips are much longer than mine. I'm only driving 7 miles to work and 7 back. With the colder weather coming on I'm seeing that affect my mileage even more. Just did my first fill up since delivery (dealer said the tank was topped off) and got 48.0 on the computer and 44.30 calculated. We'll see if that changes much between today's fill up and the next one.:cheer2:
  9. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    I think 11.4 gallons refill is running tank too low. If fuel pump doesn't get fuel, doesn't it suck air which can damage, if someone can verify? When mine hits 1 pip, it's refill time.
    On that note, the owner's manual seems to be missing a section that explains the last pip will blink.
  10. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    Well, I was having a "Kramer" moment. :D
  11. walter Lee
    1,126
    376
    Maryland
    0. The Problem/Challenge
    - MPG drops for short trips & in the cold.
    With a commute less than 10 miles in the winter ( temperature
    less than 40F for most of the trip), under normal stop and go
    traffic ( non highway) the Prius ICE may have difficulty reaching
    its optimal operating temperature because the ICE is
    regularly being turned off and on. In addition, the HV batteries
    are less efficient in the cold. If your Prius is switching back and
    forth between electric and gas power - it may take about
    6 to 8 minutes for the engine get over 130 F and up to 40
    minutes to get over 170 F - that's bad news for fuel efficiency.
    Initially, the Prius aggressively warms up to heat up
    the catalytic converter to get its ultra low emissions levels.
    The Prius thus has a higher warmup cost than other
    vehicles with dirtier emission levels SO to still get good fuel
    efficiency that warmup cost has to be spread out across the
    entire trip (the longer the trip the less impact the initial
    fuel cost becomes). The Ford Fusion Hybrid's behaves in
    a similar fashion as well - with its MPG improving even more
    dramatically as it is driven over 10 miles/40
    minutes.
    I. The hypermiling solution (warmup/mini P&G cycles)
    ... is to use mainly gasoline power during the first three
    to six minutes (avoiding using electrical power
    as much as you can) increasing your speed if necessary
    with each mini burst of acceleration via the ICE. This
    promotes the warming-up of the engine. Once the ICE
    is warmed up to its optimum temperature - a hypermiler
    driver relies on other standard hypermiling tricks like
    P&G cycle to raise the MPGs back up. This technique
    works best if you have a temperature gauge.
    II. The engineering solution
    .... is to install a 400W engine block heater (EBH)
    and warm up your Prius before you drive it. Warming
    up the Prius ICE to even 100F will shorten the
    time the Prius ICE gets to its most optimum operating
    temperature and push up fuel efficiency(FE) significantly.
    The down side is you must use electricity to warmup
    your Prius and it takes 30minutes to 2 hours prep time.
    However, combined with other hypermiling techniques,
    a warmed up engine can produce steller MPG results.
    III. grill blocking +temperature gauge solution
    .... is to block the lower air intake grills of the
    2010 Prius (e.g. with pipe foam insulation) to help
    the engine warm up faster and monitor the temperature
    with a temperature gauge (e.g. ScangaugeII xgauge-FWT)
    to make sure your engine doesn't over heat.
    IV. The trip planner solution
    is to plan and accomplish several small trips sequentially
    within a few minutes of each other so that each
    successive trip benefits from having a warmed up
    engine created by a previous trip with the first trip
    being the longest trip.
    hope this helps
    Walter Lee
    2010 Toyota Prius III Blue Ribbon/Dk Grey, Oem floormats
    Yokohama Avid S33 (50/48)
    ScangaugeII (FWT,SoC, RPM, GPH)
    50% grill blocking (100% lower, 0% upper)
    Odeometer = 17400 miles, overall 60.9 mpg
  12. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    488.1 miles
    9.699 gallons
    $3.079/gallon
    $29.88 total
    50.32 calculated mpg
    53.2 computer mpg on tank.
    $0.0612/mile
  13. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    439.8 miles
    9.083 gallons
    $3.129/gallon
    $28.42 total
    48.42 calculated mpg
    51.5 computer mpg on tank.
    $0.0646/mile
  14. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    325.7 miles
    6.768 gallons
    $2.979/gallon
    $20.16 total
    48.12 calculated mpg
    50.8 computer mpg on tank.
    $0.0618/mile
  15. AEROENGR
    AEROENGR Junior Member
    57
    Connecticut
    508.0 miles
    9.001 gallons
    $3.599/gallon
    $32.39 total
    56.44 calculated mpg
    58.7 computer mpg on tank
    $0.0638/mile
    36 miles to empty indicated
  16. Phil_R
    Phil_R Scofflaw
    Live Oak, FL
    470.1 miles
    8.44 gallons
    $3.329 gallon
    $28.11 total
    55.7 MPG calculated
    58.9 MPG computer
    $0.06 mile
  17. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    425.2 miles
    9.129gallons
    $3.159/gallon
    $28.84 total
    46.57 calculated mpg
    49.4 computer mpg on tank.
    $0.0678/mile
  18. badbob47
    badbob47 New Member
    Hawaii
    336.8 miles
    5.876 gals at fill up
    $24.79 total @ $4.219/ gal
    57.31 calculated MPG
    59.3 computer MPG on tank
    Note: Last 4 fillups have all been in the 57 MPG calculated MPG range. I've had the car since late August. It now has around 4200 miles on the odometer. I have never gotten less that 53 MPG calculated. It seems that as the car has broken in with mileage, the gas mileage has steadily climbed.
  19. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    416.3 miles
    9.137 gallons
    $3.259/gallon
    $29.78 total
    45.56 calculated mpg
    47.9 computer mpg on tank.
    $0.0715/mile
  20. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    496.1 miles
    10.369 gallons
    $3.299/gallon
    $34.21 total
    47.84 calculated mpg
    50.6 computer mpg on tank.
    $0.0689/mile
