Motor reving to 3k-4k but not moving
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 2005dahl, Aug 27, 2014.
  1. 2005dahl
    2005dahl Junior Member
    texas
    I have 160k on my 2005 prius. When letting off the gas peddle in DRIVE the motor is reving up to 4k with out the trans kicking in and moving the car.
    I have replaced the 12v bat, cleaned the t-body and mass air sensor.
    I took it to the local toyota dealer for a recal and now they have had the car for over a week. I am being told it is the floor peddle sending a false voltage to throttle body. I highly doubt that this would not make the care go and not just idle up to 4k.
    Will keep you guys posted as I get more info.
    #1 2005dahl, Aug 27, 2014
    48,999
    thanks, did they pull any codes?
  3. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    You need to get a mini VCI setup and monitor the pedal position......if it goes beyond 15% with your foot off the pedal then yes, that's why the car is revving in park.
  4. 2005dahl
    texas
    No Codes.
    Ok going on 4 weeks in shop, Toyota thought it was the floor peddle sending a voltage via drive by wire and that was not it. Still waiting.
    Mtl hihy. this is while car is in drive not park.
  5. 2005dahl
    texas
    Update
    Ok over a month now. Toyota has replaced plugs and throttle body and still revving. They are (Toyota Corporate) starting to think the Battery Pack is doing something weird.
  6. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Do you have your a/c on full at the time?
    But it is sounding like your HV battery is toast. Others may add their thoughts.
  7. MTL_hihy
    536
    261
    Maritimes, Canada
    I agree if this happens in drive it sounds alot like the battery because the battery is needed to engage the electric fields that allow the transmission to drive the car (without this the car will just rev in place).
    What do you module voltages look like right now? Did you ever get a mini VCI setup? (If not I highly suggest one!!!)
  8. 2005dahl
    texas
    I have not had car for over a month. Toyota said the Battery Pack is showing all good and even cells. When the car starts to rev it is not charging anything at all... Also forgot to add they Replaced the Foot Peddle assembly.
    Will keep you guys posted...
  9. MTL_hihy
    536
    261
    Maritimes, Canada
    Sounds like the transmission (MG1) or the inverter is at fault then.........curious what the outcome will be.
    I have to also assume they changed your 12V battery already too?!
  10. Mendel Leisk
    38,260
    What kind of expenses are you incurring with this?
  11. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    Could you please be clear and concise about the problem?
    You say "DRIVE", so does this occurrence only happen in the "D" position of the shift lever and no problems in "B" mode? Or by "DRIVE" do you really mean "READY" which is just when the car is on and ready to go?
    Does the car operate as normal when *not* letting off the gas pedal?
    The Prius engine can idle as high as it wants without moving the car by design. There is no transmission in the common sense of the word, nothing to "kick in" and move the car. A basic misunderstanding of how the car works, will lead to very poor diagnostics.
    All motive power is sent through the outer ring gear of the planetary gear system which is MG2. If MG2 is staying static, then the wheels will not move at all. This is why it is important to know if the car moves in general and this is a problem that only occurs when the speedometer is 0.
    If nothing is charging the battery with the engine on, it could possibly be an inverter problem.
    All of these things can be easily diagnosed with a CAN reader. The $10 devices you can buy on Amazon or eBay.
    You can check the reported pedal position of the accelerator on the CAN network. This would show you the pedal, although I never believed that would be the issue anyways.
    You can check the RPM of the engine (how are you determining 4K RPM???), the RPM of MG1, RPM of MG2, Current flow into and out of the battery pack (verify nothing is going there), Voltage info of the pack (pack too high, pack too low?) and lots of other important info.
    More info needed to try and guess what's wrong. But with the limited (and somewhat contradictory) information provided, I would say it is an inverter or transaxle problem. When was the last time you replaced the transaxle fluid?
  12. 2005dahl
    texas
    Ok. After 5 weeks of being in the Toyota Shop and mounds of data sent to Corporate. The Inverter has a faulty sensor, bought one off Ebay for 225.00 and after 2.5 hrs of work and a beer my car is back to normal. :) Dealers cost installed New $5400.00 they had a used one 75k miles for $2400.00
    So this is what it was doing. No codes at all. Dealers computers showed nothing.....
    Revving did not happen all the time but was getting worse it seemed. I could slow the revving if I was stopped by putting in in Neutral or Park.
    The Revving could and would happen in all stages of motor warm up.
    I have never used B on trans.
    I could be just sitting at a stop light (ac on/off, heat on/off) and it would rev.
    I could be going down the highway and let off the gas and the motor would rev.
    I could be trying to hypermile and the motor would rev.
    Hope this helps.
    Cheers
    David D.
    2009Prius and northwichita like this.
  13. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    Do you have a part number?
  14. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    Any theory on why a faulty sensor in the inverter would cause the engine to rev?
  15. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    MG1 is (almost) always keeping engine from revving by generating power. If for same reason inverter didn’t send enough power from it to somewhere (mg2 and/or battery) engine would just rev.
  16. MTL_hihy
    536
    261
    Maritimes, Canada
    X2
    I believe the inverter controls the field current for MG1 so if there was no (or not enough) current supplied to the windings then the engine would just rev in place and the vehicle wouldn't move (since there are no mechanical connections between the wheels and the motor itself).
  17. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    I have not heard of a dealer replacing individual inverter parts. Just the whole inverter. The dealer replaced a part, it has a part number. It sounds like they did one thing and said another.
  18. northwichita
    481
    102
    29
    Wichita KS
    Dealers don't buy parts off Ebay either, the OP did (a $225 inverter) , fixed the problem himself, not the dealer.
  19. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    I read that post as they replaced an "inverter sensor" which doesn't make any sense. That's why I wanted the P/N. If the OP just bought a new whole inverter on eBay, then good for him, that's a good course of action.
  20. valde3
    2,002
    745
    Finland
    Engine is connected to power split device. In power split device power is (normally) divided into two. To wheels and to MG1. But if MG1 isn’t sending power to anywhere it’s going to turn easily and all power is going to there and non to the wheels.
