mpg with 91 vs 87, in your prius c
Discussion in 'Prius c Fuel Economy' started by xraydoug, Mar 18, 2014.
  1. xraydoug
    xraydoug Active Member
    571
    176
    Roseburg, Oregon
    I just finished my 700 mile tank, :):) display shows 79.7 mpg calc at pump is 78.5 mpg. I will post a pic later and enter it in the top 20 mpg and 700 mile club.
    DianaM, ztanos, wjtracy and 1 other person like this.
  2. xraydoug
    571
    176
    Roseburg, Oregon
    update on mpg
    tank in feb. 87 e10 gave 52.9 calculated at pump
    tank in mar 91 e10 gave 59.6 calculated at pump (11% increase)
    tank in april 87 e10 gave 57.1 calculated at pump (4% decrease)
    tank in may 92 e10 gave 67.7 calculated at pump (15% increase
    tank in june 87 e10 gave 57.81 calculated at pump(15% decrease) I forgot to log this when I filled up it is on fuelly.
    tank in july 92 e10 gave 79.7 calculated at pump (huge increase) hypermile effort on my part not good for compairson.
    tank in aug 87 e10 gave 57.1 calculated at pump (down a little from june:()
    Read more: mpg with 91 vs 87, in your prius c | Page 2 | PriusChat
    Follow us: @PriusChat on Twitter | PriusChat on Facebook
    orenji likes this.
  3. xraydoug
    571
    176
    Roseburg, Oregon
    october update on mpg:
    regular e10 cost $3.14
    preimum e10 $3.34
    miles with 92 octane e10 since feb.= 2554/39.42 gal gives 64.7 mpg
    miles with 87 octane e10 since feb. = 2403/42.72 gal gives 56.25 mpg
    tank in sept 92 e10 gave 56.84 calculated at pump( lots of hwy miles)
    tank in oct 87 e10 gave 56.18 calculated at pump( 50% hwy miles)
    this shows a 13% improvement in mpg with a current cost of .20 more the cost is about 7% more per gal. so if I am thinking correctly I am saving about 6% on my fuel bill by using 92 octane.
    Read more: mpg with 91 vs 87, in your prius c | Page 3 | PriusChat
  4. wjtracy
    wjtracy Senior Member
    11,315
    3,588
    Northern VA (NoVA)
    That's incredible low cost for Premium delta over Reg! we are much higher.
  5. smackdownC
    smackdownC Junior Member
    56
    17
    2014 Prius c
    I'm running 93 oct from Wawa. Not sure there will be a diff in mpg.
  6. wjtracy
    11,315
    3,588
    Northern VA (NoVA)
    WaWa? You must be in Philly/south Jersey region but you could be by me in north VA as we are starting to get some Wawa's. But most likely you are in the Northeast corridor RFG (reformulated gasoline) EPA zone, where the Premium RFG is probably not going to offer better MPG. XRAYDOUG is in Oregon where he does not have RFG, so he has a better chance for more energy content in his Premium. If you are interested I can send you a link to the RFG counties so you can see (or give us a little better fix on the WaWa location).
    #46 wjtracy, Oct 13, 2014
    ztanos likes this.
  7. Alexinnitro
    Alexinnitro New Member
    You need to learn about compression ratio and octane before you go putting "good gas"(see higher octane) in a car that absolutely doesn't need it.
    The Prius C has a compression ratio of 13.4:1, so it is able to utilize lower octane than say an Audi TT compression with a compression ratio of 10.3:1 so it can handle higher octane.
    When you use an inappropriate octane level for your car, you're tweaking the combustion cycle, which in layman's terms, you're making it spark before or after it should, resulting in your engine pinging, which can turn to a knock, into a thrown rod into a headache.
  8. wjtracy
    11,315
    3,588
    Northern VA (NoVA)
    There are two or three variables, higher octane, which as far as I know does not help a Prius in most cases, as you state, but also energy content can vary. This is due to manufacturing variations, and is not guaranteed to be higher in Premium, but might be depending on where you live. Another variable is ethanol content, most of us are E10 but some E0 out there. Generally speaking it will not be economical nor desirable for a Prius owner to pay more for higher octane grades or E0, but some folks are trying to maximize MPG and/or cruising range. A few Prii drivers feel they may have a special case where they are seeing better MPG with Premium and the cost is not too much more, so they feel may break even or pay off...but this rare at the moment in the U.S. market (as regulated by Congress/EPA)..
    #48 wjtracy, Oct 14, 2014
  9. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    That's probably what it is: higher octane gas is burning slower, so you probably have more energy wasted on heating. Normally that would mean less MPG, but since it is in-town and it goes EV faster, you get reverse effect. I'd bet if it were on long trip you'd see savings switching back to 87.
    Irregardless you are not saving money using higher octane gas.
  10. wjtracy
    11,315
    3,588
    Northern VA (NoVA)
    With the reformulated gasoline in the Northeast (east MD, NOVA, east PA, NJ, east NY etc etc) there is essentially no benefit for Premium as all grades can be thought of as equal by EPA mandate and E10. Once you get to OR or (out past Hagerstown) other non-EPA-RFG states there can be more variations. Usually it will not pay off, but you might get better MPG. Problem is MPG (energy content) is not a spec so it varies and there is no way to generalize except to get data (I get a sample in a gaso can and measure weight, but that's useless data here in NoVA it always weighs the same).
    #50 wjtracy, Jan 30, 2015
  11. cyclopathic
    3,292
    547
    2014 Prius c
    I would have to dig out our receipts from west coast trip to see if there were any anomalies with gas in OR.
    OR is the only state in CONUS which does not allow to pump your own gas. There was a NJ, but well it is no more.
    Problem I see is that "C" tank is very sensitive for many pumps and can cause premature shut off. Also pumps dispose by volume, so depending temps, adjustment etc you get different amount pumped. This would not matter if he goes by trip computer MPG.
    Another issue with many locations in west that with cheap E85 around there is too much discrepancy in alcohol content, esp when gas was $4. And they sell 85 and 86 regular also. At many locations 85 would be more expensive than 87, and E85 has been much cheaper. So 87 would be a mid-grade for them, and they would make it by mixing more expensive 85 with E85.
    Unfortunately they do not store it premixed, it is done during dispense. And the cheapest way for the gas station owner to make free money by adjusting the ratio to ~20% or more content.
  12. wjtracy
    11,315
    3,588
    Northern VA (NoVA)
    In general what you might notice is reformulated gasoline (our stuff) is lower energy content because that's how EPA achieves the cleaner burning formula. Of course the ethanol is also lower energy content. NJ still same as OR right? (does not allow self serve). I don't know if you are following some of the fill-up threads but some of us are turning the nozzle 90 degrees to help get fuller fill-ups. I am doing this but usually my wife fills up so I don't have too much data on it yet.
  13. cyclopathic
    3,292
    547
    2014 Prius c
    I'll try it next time. Wed was my first "C" fill up, and the pump would shut off every few seconds, unless kept really low. The same pump didn't give any trouble on Gen3 or any other cars. I will try different pump and 90deg trick next time.
  14. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Close but no cigar.
    It is mixed when it goes into the tanker trucks that deliver the fuel to the station, or at the terminal right before the trucks fill.
    The station owners have NO control of the ratios.
  15. wjtracy
    11,315
    3,588
    Northern VA (NoVA)
    I assumed Cyclo was talking about special blender pumps. Blender pumps allow the consumer to dial in 15% ethanol which several car manufactures have appoved and US EPA has approved. Blender pumps if widely available would allow consumers to choose 15% ethanol, but the issue is cost and availability of the special pumps. I've never seen a blender pump.
    Currently the ethanol lobby wants to go to E15 (15% ethanol) but due to the E10 (10% "blend wall") that 15% goal is currently stymied. The 10% blend wall is caused by a couple things: some cars not approved for 15% but more to the point the whole E10 blending/distribution system has corrosion/issues over 10% ethanol. So the blender pumps provide a way in theory to break the 10% ethanol barrier to help meet Congress's ambitious ethanol quotas which currrently exceed the 10% blend wall level.
    #55 wjtracy, Jan 31, 2015
  16. cyclopathic
    3,292
    547
    2014 Prius c
    If you go to gas stations which sell mid-grade gas (89 around here) it is made by mixing regular (87) and Premium (93) in the pump. Mid-grade gas is a scum, it does not exists in nature.
    All additives (detergent, octane booster, alcohol, etc) are added to gas at the terminal when it is poured into tanker truck. Gas companies share terminals, so when you are buying gas at Shell station it could be Texaco or Exxon/Mobil gas, but the additive package is unique to the gas company.
    The pumps are checked and sealed by state department of weights and measures, but unfortunately there are ways around it.
    There is a lot of shady business going on: the software on gas stations had been hacked and it is not really protected by any safeguards. Another illegal profit venue is to bring gas out of state. Sell it and pocket the tax difference.
    BUT you are correct, the easiest way to adjust alcohol ratio at unload.. dump some E85 from the tanker into regular tank at gas station.
  17. wjtracy
    11,315
    3,588
    Northern VA (NoVA)
    hmm...I checked ethanol% twice last summer...both times it was 9% or less.
    Messy mix with water, don't try it unless you need to and have better equipment than I did.
  18. cyclopathic
    3,292
    547
    2014 Prius c
    E85 is expensive in Mid-Atlantic, it makes no sense to mix it in.
    Mid-West different matter. It was an issue every time I've been through South Dakota. In fuelflex car it just meant really bad MPG, but on the bike w/o oxygen sensor I had to pull off the highway due to overheating. No issues after switching to more expensive 86 regular.
  19. wjtracy
    11,315
    3,588
    Northern VA (NoVA)
    Well I guess that gives us another possible reason why folks like XrayDoug see better MPG with Premium. If the Regular is >10% ethanol that's another variable. If it was me in I would be occasionally measuring density, ethanol, and fuel temperature to see if there is a difference. But here in NoVA it makes no sense to check for variations as we no variations (reformulated gasoline).
  20. Easy Rider 2
    1,584
    257
    Ocala, FL
    But that has no bearing on the ethanol content or when THAT gets blended.
    AND not all areas or station brands do it that way.
    Some actually have 3 tanks in the ground.
