Must I replace the TPMS sensors when I replace my wheels?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by yadax3, Jun 28, 2010.
  1. yadax3
    yadax3 New Member
    240
    Northern Nevada
    Hi - I've read several threads trying to find a clear cut answer to my question but I'm still unsure and I don't want to make a costly mistake. I'm going to replace my 15" wheels with 17' wheels. Do I also need to order TPMS tire pressure sensors or can I reuse the sensors on my existing wheels? :confused:
    Thanks in advance for your expert advice!
  2. exbauer
    exbauer Active Member
    1,170
    74
    Washington
    You can reuse the sensors from your 15" wheels. It will not be a problem.
  3. yadax3
    yadax3 New Member
    240
    Northern Nevada
    Thanks. Will I need to have the new wheels professionally installed in order to reuse the sensors?
  4. db626
    db626 New Member
    27
    CA
    The TPMS sensor mounts mounts directly on the other side of the factory valve stem. So instead of using new valve stems, the installer will use the existing valve stem units off your Toyota rims. Most vehicles in the past couple of years are equipped with some form of TPMS so I would believe tire installers are familiar with these units. If not, they prob would be out of business by now. Ask to make sure.
  5. yadax3
    yadax3 New Member
    240
    Northern Nevada
    When I phoned my dealer they said whether or not they can make the exchange depends on whether or not the old sensors fit the new rims. Here are the wheels I'm considering:
    Enkei Racing RS05 Bright Silver Paint
    How can I tell if the sensors will fit?
  6. exbauer
    1,170
    74
    Washington
    I was also thinking about those wheels. But, I went with Enkei RS+M. The sensors will work with Enkei wheels and a direct swap. Post a pic when you get them installed.
  7. yadax3
    yadax3 New Member
    240
    Northern Nevada
    Ooh, I like those too. Can you post a photo of yours?
  8. exbauer
    1,170
    74
    Washington
  9. yadax3
    yadax3 New Member
    240
    Northern Nevada
  10. exbauer
    1,170
    74
    Washington
    I was going to get the RS05. But, I was able to find a set of RS+M. They are discontinued just like the RS05 are about to be. Add your pics when you get them on your car. I would like to see what they look like on the 2010 Prius in BP.
  11. yadax3
    yadax3 New Member
    240
    Northern Nevada
    Will do.
  12. a_gray_prius
    2,397
    404
    Chicago, IL
    FYI: when you decide to move your sensors over, buy a new TPMS seal kit (I think they're called service kits in the parts catalog). Also, be sure they put a little silicone grease around the seals, as it helps to prevent leaking at the TPMS valve stem seals.
  13. yadax3
    yadax3 New Member
    240
    Northern Nevada
    Thanks! I wonder if that is included in the $170 my dealership quoted me for doing the change over.
  14. a_gray_prius
    2,397
    404
    Chicago, IL
    I paid $100 at a local speed shop for a mount, balance, and install done by hand with a proper torque wrench (I have Ce28n Eco Drives with aluminum Volk lug nuts). You may want to contact some locals if you want to save some money.
  15. Fusionworks
    Fusionworks New Member
    Kansas
    I just installed my new wheels with new Toyota TPMS sensors, but i haven't had them programmed yet. This car isn't nearly as annoying as some of my other cars, just a little low tire light. My EVO X dings at you every 10 minutes and flashes the dash when I have my track wheels on the car.
  16. yadax3
    yadax3 New Member
    240
    Northern Nevada
    Here's what they look like http://priuschat.com/forums/gen-iii...el-thread-post-your-pictures.html#post1149279
    BTW, my dealership ended up charging me just $135 to mount and balance my new wheels/tires, install and program TPMS, and repair a slow leak in one of my old tires.
