My Prius v (lowercase v) Mods
Discussion in 'Prius v Accessories and Modifications' started by Eric "v", Nov 17, 2014.
  1. jzchen
    jzchen Newbie!
    3,298
    1,010
    Arcadia, CA
    Sometimes I wish I lived in another state that is less strict like yours. I have a feeling the intake would pass the performance portion of the test. I'm pretty sure that they'd get one on the visual inspection portion. I have a K&N intake on a '99 GS400, and when I took it to get smogged the one guy was nudging the other, I think to fail me, for a darn K&N prefilter I had put on! I have the EO sticker in plain view right next to the intake!
    I have to agree that the cotton gauge filters do a good enough job from my own use/research.
    Just curious, did you see a carbon element somewhere in the stock intake, or is it built into the filter element? I was under the impression that the carbon element was separate.
  2. Eric "v"
    Eric "v" Member
    229
    44
    'Vegas, NV, Baby
    2013 Prius v wagon
    jzchen,
    I have not dissected my two stock air boxes. But you've got me curious about the carbon element so I'll look tomorrow and hope I don't have to cut into a filter to find out. (I'm saving them in case the next owner wants to revert to OEM air boxes.)
    Nevada does follow California's smog test protocol and standards EXCEPT that I can run any air intake I want as long as it does not light up a "check engine" light. Nothing (yet) about needing a carbon filter for "seep back" exhaust after the engine is shut down.
  3. jzchen
    jzchen Newbie!
    3,298
    1,010
    Arcadia, CA
    Definitely don't cut into the stock filter. It would be a waste. Like I said I thought it was a separate element altogether. Should be easy enough to see, one would think, just looking at pictures of filters on the net, if it is part of a single filter. I'll hopefully get some time to search filters later.
    The tester can fail you here just by seeing an aftermarket part without a CARB EO#. It is sad, but partly a money making thing here I guess. I didn't know that is what the carbon is for. Thank you.
    MT2L03 ?
  4. jerryhe
    jerryhe New Member
    2437 s morgan st seattle wa 98108
    2015 Prius v wagon
  5. jzchen
    jzchen Newbie!
    3,298
    1,010
    Arcadia, CA
    So I was looking into purchasing a replacement air filter and got to see some pictures. I can't see any type of "carbon" on the aftermarket replacements on AutoZone or O'Reilly. Strange, but if the carbon is in the filter, then these aftermarket filters would not be CARB compliant! I ended up purchasing a aFe 31-10228 Pro Dry S but am thinking it may not be compliant. (Maybe should have just gone with the Injen intake!)
  6. Eric "v"
    Eric "v" Member
    229
    44
    'Vegas, NV, Baby
    2013 Prius v wagon
    I wonder if INJEN makes an activated charcoal (carbon) impregnated dry filter. I'm going to call them next week and ask.
    Maybe there is even one we could slip overt the regular filter.
  7. jzchen
    jzchen Newbie!
    3,298
    1,010
    Arcadia, CA
    It wasn't too hard to find an example of the hydrocarbon filter from a Toyota. A modification to remove it to improve performance can be found here (I honestly don't know why it takes me a while to figure out things, ie. in this case it took me days to figure to do a Google search on "hydrocarbon filter"):
    Toyota 4Runner Hydrocarbon filter removal
    Here is a picture of the actual filter from that same page:
    http://www.top4runners.com/cgi-bin/image.pl?/ja/2007/hcf/hcf8.jpg
    The page notes that "H C" is stamped on the top half of the airbox, and the carbon element is attached permanent style to the top. I honestly don't remember seeing this "H C" on the Prius v box anywhere, shown on this picture from that same page:
    http://www.top4runners.com/cgi-bin/image.pl?/ja/2007/hcf/hcf7.jpg
    The example vehicle is a 2007 4Runner 4.7L V8...
    The hydrocarbon filter seems to be a separate more permanent part of the air filter housing. From the looks of the 4Runner V8 setup, it is on the engine side of the housing, meaning the hydrocarbon filter would go on the inside of the conical filter of the intake.
    Maybe I shouldn't have rushed to buy the aFe filter if there is no hydrocarbon element in the Prius v and could have hope for a CARB EO# for the Injen Intake, although I don't see them show the dyno results...
    #67 jzchen, May 23, 2015
  8. jzchen
    jzchen Newbie!
    3,298
    1,010
    Arcadia, CA
    Never mind. I just looked over the installation instructions for the Injen Intake from their website. In one picture you can clearly see the "H C" stamping on the top half of the airbox just as they show removing it.
    It is on Figure 6....
  9. Eric "v"
    Eric "v" Member
    229
    44
    'Vegas, NV, Baby
    2013 Prius v wagon
    Amazon sells "cut-to-fit" carbon impregnated filter covers for about $9.
    So anyone worried about a needing a carbon element over their conical cold air intake can make one. Likely some kind of glue for foam (maybe as used by upholstery repair) can be used in fabricating a cover.
  10. Prius rv
    Prius rv New Member
    Fort Myers,Fl.
    Hey Eric "v" did you ever replace the stock shocks on your "v"? I know you did exhaust tip, but did you do tuned muffler or exhaust system? I love your "v", building mine on what I learned from your set -up. Looking for adjustable Shocks and Exhaust muffler for my silver zvw40 2012 v m5. Anyone else have their 2 cents on modifying "v"? I love My little v......
  11. jzchen
    jzchen Newbie!
    3,298
    1,010
    Arcadia, CA
    The smog check station could fail you on the visual inspection without a CARB EO#. No "sniffer" test necessary. I wish it were so simple...
  12. mikefocke
    3,729
    1,665
    Sanford, NC
    We have to be careful not to assume that our smog check experience translates from state to state. Some states and even areas within states have no smog checks or different ones.
  13. jzchen
    jzchen Newbie!
    3,298
    1,010
    Arcadia, CA
    Yup. Should have specified for California only. My apologies.
  14. chipr
    chipr Junior Member
    16
    Cascadia
    2014 Prius v wagon
    e.g. Vashon Island is exempt from King County/WA's smog test
  15. Air_Boss
    Air_Boss Senior Member
    4,002
    1,093
    New Yawk
    NY State just instituted tint testing at annual safety/emissions inspection: > 70% transmissivity (< 30% tint)
  16. natsmada
    natsmada Junior Member
    Planet Earth
    Here's some photos of an HPS CAI that I installed a few months ago. I really like the sound and added thrust that it provides.
    YMMV
    Happy Driving!!
    Burna J likes this.
  17. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Nice! Did it affect your fuel economy in any way?
  18. Air_Boss
    4,002
    1,093
    New Yawk
    Did you add the stickers for their incremental 10BRWHP?
  19. black Sunshine
    black Sunshine Junior Member
    Atlanta
    How hard was the install? I did this on my first car and I remember loving the sound too!
  20. natsmada
    Planet Earth
    The install was pretty straight-forward and took about 25 minutes. You may need an long (>12") ratchet
    extension to get some of the 10mm bolts removed. Regarding gas mileage, it seems to have improved
    slightly, but I do seem to be heavier on the gas pedal now that it sounds so "throaty".
