NE1 using Mobil 1 5w-20?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by xliderider, Jul 23, 2014.
  1. xliderider
    xliderider Senior Member
    7,904
    3,136
    Honolulu, HI
    I was tempted to try it. Costco has it and there was a coupon discount.
    Residing in a warm weather climate, I'm not worried about the difference between 0w and 5w viscosity for cold start up.
    SCH-I535
  2. JC91006
    16,500
    8,412
    It won't make that big a difference in Hawaii, use 0w or 5w, it would be the same in your climate.
    I find using mobil 1 oil burns quite easily in my Priis. When I switched to Pennzoil Platinum, the oil burn/usage reduced. Not sure why
    Merkey likes this.
  3. GregP507
    GregP507 Senior Member
    3,002
    480
    I'd never use a non-synthetic. Based on my past experience, it's the difference between "some" engine-wear and no engine-wear. Several of my previous vehicles have gone over 250,000 miles using it, and I've often gone more than 20,000 miles between oil changes, with no apparent bad effects.
    I can see why Toyota recommends it.
  4. xliderider
    7,904
    3,136
    Honolulu, HI
    ???, Mobil 1 and Penzoil Platinum are both synthetic.
  5. JC91006
    16,500
    8,412
    Although both a synthetic oils, both are not made of the same synthetic formula. All oil companies have their own special formula for success. I believe the mobil 1 formula is their great advertising :)
  6. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    How cheap was it? I just paid 22.99 for a 5 qt jug of mobil one.
  7. JC91006
    16,500
    8,412
    This sounds like a Mobil 1 advertisement
  8. GregP507
    3,002
    480
    It's a bit like asking yourself: "Do I want engine-wear, or no engine-wear."
  9. JC91006
    16,500
    8,412
    I experience no engine wear on my cars too. When they are parked
  10. xliderider
    7,904
    3,136
    Honolulu, HI
    IIRC, it was about $26 for a case of 6 quarts.
    SCH-I535
  11. GregP507
    3,002
    480
    Not bad at all when you stretch it to 20k.
  12. wjtracy
    wjtracy Senior Member
    11,329
    3,593
    Northern VA (NoVA)
    Walmart has Mobil-1 for $22.xx 5-qts jug, just got some 0W-40 (not for the Prius) but that is really low price.
    As far as OP I see no issue with 5W-20 in Hawaii.
    As far as who has the best synthetic, I do not know. Most say the Toyota brand is made to quite high specs.
    You can look for ACEA A1/B1 A5/B5 rating but last time I looked, I do not think many if any USA 20 weights have that rating (30 weights for Gen2 we can get ACEA A1/B1 A5/B5 on the label).
