1. Offline
    John in LB Life is good
    Start a Conversation
    Aug 5, 2006
    388
    22
    Orange County
    Your Vehicle Year:
    Interesting, I just Ass-U-Med it to be a defogger. Will confirm the next time I defog my rear window...
  2. Offline
    andyprius New Member
    Feb 21, 2005
    2,181
    157
    Sacramento, California.
    Your Vehicle Year:
    The hood has TWO places to insert, one for high and one for very high, almost vertical! Impossible for MOST people to hit thier heads.
    1 people like this.
  3. Offline
    Allannde Just a Senior
    Jan 7, 2006
    804
    105
    Washington State
    Your Vehicle Year:
    Yep:
      File size:
      96.9 KB
      634
    1 people like this.
  4. Offline
    Feb 21, 2005
    2,181
    157
    Your Vehicle Year:
    A major improvement over my 2005, the height is now 1-2" higher, I can now clear those stupid parking cement blocks! My 05 looked like beavers had been chewing on it. :D
  5. Offline
    ultraturtle Newb
    Nov 24, 2011
    98
    57
    Peachtree City, GA
    Your Vehicle Year:
    After scratching my head for a week trying to figure out why the A/C button on the remote would not turn on the air conditioning as I approached the car, I took the unmanly action of actually reading the manual.
    Loving the car's feature of turning off whatever headlights you use when powering down, my initial habit had been to leave the Headlight Switch in the Daytime Running Lights on position. Turns out, they must be off in order for the remote A/C function to work. While it does not appear to be a hard requirement in the initial system operation description, a later section states "The Remote Air Conditioning System may stop operating temporarily if other features that use electricity (for example, the seat heater, lights, windshield wipers) are in operation or if the charge level of the 12-volt battery becomes low."
    Operating conditions
    The system will only operate if all of the following conditions are met:
    The shift position is in P.
    The “POWER†switch is OFF.
    All doors are closed.
    The hood is closed.
    The brake pedal is not being depressed.
    When leaving the vehicle
    Check that the headlights are switched to either off or “AUTOâ€.
    Check that the wiper switch is turned off.
    Check that all windows are closed.
    4 people like this.
  6. Offline
    ThatTallGuy Junior Member
    Mar 7, 2012
    65
    Southern NH
    Your Vehicle Year:
    I believe it's a defogger. It's in the driver's line of sight to a blind spot; the one of the left side is not.
  7. Offline
    Chris Allingham New Member
    Apr 22, 2012
    San Jose
    Your Vehicle Year:
    Anyone notice there's a little spotlight on the ceiling that shines down onto the shifter knob? Only visible at night. Kind of a neat little effect.
    Regards,
    Chris
    MarkPressey likes this.
  8. Offline
    CharlesH CA HOV Decal #0005
    Nov 27, 2005
    896
    194
    San Jose, CA
    Your Vehicle Year:
    Our Honda Pilot has the same thing. (You can do lots of things with a Prius, but hauling an RV trailer is not one of them.)
  9. Offline
    9G-man Active Member
    Jul 2, 2005
    1,232
    143
    Atlanta, GA
    Your Vehicle Year:
    The power windows actually slow down as the glass nears it's up and down limit, so they don't bottom or top out with much force. That's cool.
  10. Offline
    devprius /dev/geek
    Jan 2, 2006
    837
    212
    San Francisco Bay Area, CA
    Your Vehicle Year:
    I have always have my headlight stalk switch in the DRL mode, and I had no problem activating the AC via the remote key fob. I did multiple tests to make sure.
  11. Offline
    radiocycle Active Member
    May 10, 2007
    540
    71
    Morro Bay, CA
    Your Vehicle Year:
    I knew this... only because I was looking for a place to put a decal that I like but I didn't want to put it on the defogger wires. I was going to put one on each of the rear side windows until I saw that. You beat me to listing it in here though :eek:
  12. Offline
    crewdog AARPrius User
    Jul 23, 2009
    280
    88
    Woodstock, GA
    Your Vehicle Year:
  13. Offline
    plugable Junior Member
    Feb 19, 2012
    49
    Rancho Cordova, CA
    Your Vehicle Year:
    The following link indicates that there is an in-glass AM/FM antenna in addition to the roof-mounted antenna, so I'm voting that it's an antenna!
    2012 Toyota Prius Plug-in Hybrid Models
  14. Offline
    bfd Plug-In Perpetuator
    Mar 19, 2009
    472
    78
    Close to SDSU in the Far Southwest Corner of Calif
    Your Vehicle Year:
    The Emergency Response Guide revealed several items I'd overlooked!
    Cool!
    1) Lumbar support…
    2) Telescoping steering wheel. (I'd noticed the vertical adjustment, but not the Z axis!)
    Since my Gen II had neither of those features, I didn't even notice until I read this! (And yes, I did RTFM! - It's on my iPad in PDF form.)
    These are the kinds of surprises I like.
  15. Offline
    wmmmmm Junior Member
    Mar 5, 2012
    53
    SF Bay Area
    Your Vehicle Year:
    I give up. Where is the Lumbar support? Is it adjustable?
  16. Offline
    Mar 19, 2009
    472
    78
    Your Vehicle Year:
    It's the circular button.
    [IMG]
    Yes, it is adjustable!
  17. Offline
    Mar 5, 2012
    53
    SF Bay Area
    Your Vehicle Year:
    How about that! I had go to try it out and it works. I was thinking about getting a support but now I won't have to!
    And I also read (skimed) the entire manual but missed them.
  18. Offline
    Sep 6, 2005
    1,887
    285
    N.Babylon, Long Island, NY
    Your Vehicle Year:
    Lumbar support is also available in the base package to?, I do not recall seeing a round knob in mine but I could also be wrong......
  19. Offline
    janie Precious Prius Plug In
    Aug 31, 2010
    163
    36
    Your Vehicle Year:
    No lumbar support on the base package :(
  20. Offline
    Mar 19, 2009
    472
    78
    Your Vehicle Year:
    Or - It's an EXPENSIVE upgrade on the Advanced pkg.
Share This Page
