Need help diagnosing my 2016 Prius
Discussion in 'Gen 4 Prius Main Forum' started by PowerPrius443, Mar 22, 2024.
  1. PowerPrius443
    PowerPrius443 New Member
    United states
    Hey all, I have a 2016 Prius hybrid and started noticing a few issues:
    *all issues started in the past 2 days. I’ve owned the car for 3 months and the car was previously crashed in the front. No external leaks are present
    1. going regular speeds are fine but at ~60-65mph I see a lot of dense smoke coming out of the exhaust.
    2. My coolant light comes on every 40-50 miles and I have to refill it.
    3. my engine has massive blow by(not sure if normal with these engines)
    4. Codes for engine coolant temperature low circuit low input; insufficient coolant temperature for closed loop fuel control
    I already checked with a combustion leak tester in the coolant reserviour and no exhaust gas there.
    HELP!!
  2. sclevine
    sclevine Active Member
    118
    136
    New York, NY
    2024 Prius
    Search this site for heat exchanger
  3. FuelMiser
    FuelMiser Senior Member
    1,305
    891
    Monument, CO
    You're losing coolant through the heat exchanger in the exhaust pipe. There's a work-around that involves bypassing the heat exchanger circuit with a U-shaped coolant hose. The other option is replacing the portion of the exhaust pipe with the heat exchanger.
  4. ChapmanF
    16,006
    Those are incentives for solving this problem as quickly as possible, and not continuing to drive unnecessarily.
    2. The "coolant light" isn't a warning about the coolant, it's about the engine being too hot right now. The right time for a coolant warning would be earlier. The light coming on is bad.
    4. The coolant temperature sensor is a "negative-temperature-coefficient thermistor", which means the input goes lower for higher temperatures. When you get the code about the input being so low the ECM thinks it's a sensor or wiring problem, in this case it's the engine getting so hot the ECM doubts that could even be a real reading. That's hot....
    Brian1954, Mendel Leisk and BiomedO1 like this.
  5. BiomedO1
    BiomedO1 Senior Member
    1,651
    857
    SacTown, Ca
    There's a TSB on the 2016 exhaust gas heat exchanger and may be covered under state or federal emissions warranty. If the car has a salvage title all bets are off.... That's assuming you haven't blow or burnt up the engine by continuously running it HOT.
    Hope this helps....
  6. PowerPrius443
    United states
    I did the reroute via a YouTube tutorial. I tried driving on it for a day but I’m still getting white smoke out the exhaust and losing coolant, any ideas?
    #7 PowerPrius443, Mar 26, 2024
  7. FuelMiser
    1,305
    891
    Monument, CO
    If the coolant is not entering the exhaust via the heat exchanger, then the only other way is if there is a blown head gasket, Blown Head Gasket Symptoms & Causes | Fel-Pro Gaskets
  8. Tim_HI
    Tim_HI New Member
    Hawaii
    You will get white smoke for couple more days until that coolant burns in exaust
    could you tell what kinda combustion leak tester did you use?
    #9 Tim_HI, May 1, 2024
