Need to order new tires
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by milestoempty, Sep 25, 2015.
  1. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    I didn't point this at you.. just in general.
    Do not really understand why Michelin would discontinue ES.
    Defender seems not to be the direct replacement, and they have higher rolling resistance. More expensive than TrueContact and don't handle as well:
    Tire Test Results : Testing Passenger and Standard Touring All-Season Tires: Which Are Truly More Than Just Round and Black?
  2. Mendel Leisk
    Mendel Leisk Luddite
    38,376
    Someone forgot to tell Michelin?
    From their website just now. Note Michelin's opinion of the two tires fuel efficiency:
    Still, I think you'll be ok with the Defenders, the differences are not that great, and they're great for handling and wear life.
    WilDavis likes this.
  3. cyclopathic
    3,292
    547
    2014 Prius c
    If ES are discontinued it makes my choice easier: True Contacts.
    Just hope Continental is not ran by ex VW executives.
  4. jdenenberg
    jdenenberg EE Professor
    3,844
    1,831
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I have been using Nokian tires since trying the original GY Integrity (lousy tires) and then Michelin MXV4+ (much better tires). First their WR then WRg2 (twice) and next will get WRg3. They are great LRR all weather tires that match most winter tires for traction in bad weather. They all lasted about 50k miles each (I have 278k miles on my 2004 Prius).
    JeffD
  5. Mendel Leisk
    38,376
    I heard the WRG3 roll easier than the 2 version. Did you notice that?
    Gotta say I was underwhelmed by WRG2 RR when I used them on a civic hybrid. There was a distinct mpg downturn, compared to our regular EP20's.
    #25 Mendel Leisk, Oct 1, 2015
  6. cyclopathic
    3,292
    547
    2014 Prius c
    I've looked into getting eNTYRE 2.0, until read about how long they last in Consumer. They estimated 35,000mi, this is after putting 16,000 on them. I think they are not the best choice if your temperature may get over 70F, YMMV
  7. jdenenberg
    3,844
    1,831
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I am still working on wering out my WRg2's (at 32k miles with enough tread for this winter) so I haven't tried WRg3s yet.
    My records show that the WRg2s do quite well MPG (about 3% better than the OE GYs and about 1% better than the discontinued Michelin MXV4+ "Energy Savers"), but not quite as well as the old WRs, I expect that some of the newer LRR tires will do better due to progress in building LRR tires, but few of them will beat or even match the WRg2s in ice/snow traction (WRg3s likely the exception).
    JeffD
  8. milestoempty
    milestoempty Junior Member
    Annapolis
    Thank you for choosing Tire Rack. A product specialist will be with you shortly.
    You are now chatting with 'Gavin'
    Gavin: how can I help you today?
    Charles: Hello, checking on the Michelin Energy Saver AS tires. Have they been discontinued?
    Gavin: They are being phased out in America.
    Gavin: May I assist with anything else?
    Charles: Is there a comperable replacement?
    Gavin: The Defender is the most similar, second being the Premier AS.
    So far my Prius is showing a 52-45mpg difference with the new tires. Now they are inflated at 35/33 vs my old 40psi and they're brand new tires... So I hope they go up a few mpg.
    #28 milestoempty, Oct 2, 2015
  9. milestoempty
    Annapolis
    Well I can report the mpg dropping from 52-55 a tank down to 43. I'm missing the energy savers and wondering why they stopped selling them in the US. I'm tempted to go back to Costco and exchange them for another set of something.
  10. Mendel Leisk
    38,376
    That sucks. EP422 Plus are a good option. The Michelin Premier A/S are a notch down in RR, but a good all 'round choice.
  11. cyclopathic
    3,292
    547
    2014 Prius c
    So looks like Conti TrueContact is the best MPG tire left in Prius size? I will hold on to what is left of energy savers as long as possible. We got 58.5mpg on last trip to Canada, MPG was in low 60s until that rain soaked 700mi dash alone I95 from Maine. Running a/c dehumidifier hurt it a bit.
    #31 cyclopathic, Oct 6, 2015
  12. Mendel Leisk
    38,376
    It's a head-scratcher, Michelin always making the Energy Saver A/S available in dribs and drabs, then apparently stopping. o_O
  13. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    Defender no 1 tire consumer reports Nov issue
  14. cyclopathic
    3,292
    547
    2014 Prius c
    They also report TrueContact #2 and RT-43 #3.
    TireRack, which actually tested performance found that Defender is inferior to TrueContact in fuel economy and handling, and Tire Rack survey lists Defender #5, TrueContact #1 and RT-43 #2.
    I think Defenders got better score from Consumer Reports because they understated their longevity. CR estimated life expectancy by thread wear over few month 16k interval. What they did not take into consideration that Michelin has a severe problem with sidewall cracking and should be replaced after 2-3 years irregardless of mileage. How do I know? I own them.
  15. jdenenberg
    3,844
    1,831
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Note that Tirerack doesn't review all brands of tires. Their reviews exclude Nokian tires which would rank highly for use on our Prii (especially the WRg3).
    JeffD
  16. cyclopathic
    3,292
    547
    2014 Prius c
    I was set on getting eNTYRE 2.0 (where we live we get hit by snowstorms but snow isn't permanent fixture), until I read about CR testing them and discounting for horrible thread wear. Despite the 80k warranty they estimated life expectancy of 35k.
    As I suspected the tests were done in Western Texas, so most of that wear is due to tire's inability to take heat. Which would be a problem for me too, perhaps not to the same extend.
    WRG3 is a great tire for places where it doesn't get hot in summer and it doesn't get bad to the point where you MUST have a dedicated studded tire. It is a great choice as it works all year around and saves you on buying a second set of wheels.
  17. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    Tire rack bias to only the tires the get big discount make there sales profit higher not a big discount for defender.consumer reports does not sell tires. More accurate review in my opinion.
  18. cyclopathic
    3,292
    547
    2014 Prius c
    Dry rot is a well known problem with Michelin.
    Michelin Recalls 100,000 in North America - Tire Safety Group
  19. cyclopathic
    3,292
    547
    2014 Prius c
    2-3 year old tires weathered cracking sidewalls? | Tires & Wheels | Bob Is The Oil Guy
    Google Michelin sidewall crack dry rot and you will see the full picture.
    I really liked Energy Savers for MPG and ok handling, and sidewall cracking wasn't a bit issue for me as I put ~30k a year, so they will be gone by they crack. I did have one sidewall blow on me.
    90k out of Defender? unlikely, unless you drive 50k a year or religiously put SPF-50 sunblock on sidewalls, YMMV.
  20. johnnyb588
    johnnyb588 Member
    193
    73
    Tempe, AZ
    I
    FWIW, I live in just about the hottest desert in the US with more sunshine than anywhere else in the country, and I have never had a Michelin dry rot out of four or five sets (currently running Michelins on two of my four vehicles). Of course, like you say, cyclopathic, YMMV. I have heard of the Michelin dry rot problem, but I have not experienced it. Perhaps because my climate is so prone to the problem, my lack of dry rot is a result of protecting against it.
    Best defense against dry rot: keep your tires out of the sun. This is by far the most important factor.
    Next step against dry rot: apply some sort of UV protectant regularly. 303, PC rot, etc.
