New hybrid batt. still no go, what'd I do wrong?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DKG1011, Jul 16, 2015.
  1. DKG1011
    DKG1011 Junior Member
    Kansas
    Okay, so tonight I've just finished installing a new Toyota hybrid battery pack (221Vdc) in my 2005 Prius (192K miles). Original codes were P0A80 (replace hybrid battery) and P3021 (battery block 11 weak). ...ordered, recievied, installed that new hybrid battery pack tonight. At the point of "all's safe to test drive this dude" I powered up the vehicle. Much to my surprise, all I get is 1) bout all the lights on the display, 2) NO "ready" light, and 3) something(s) is wrong and my code reader says there are NO codes present. NO Ready, can't test drive it. MFIndicator display says my hybrid battery is at 6 bars (no problem). Now left scratching more than my head about what's wrong.
    Anyone have ideas of what I did wrong, what I didn't get connected right, or what's else for me to check (double check?) concerning this issue?
    Here's picture of the "lights" that show up...
  2. JC91006
    16,470
    8,384
    Make sure the orange plug is locked down (pressed down) on the hv battery
    DKG1011 likes this.
  3. DKG1011
    Kansas
    Yup, that dern orange plug/connector/disconnector is pushed in, levered up, then pressed down to lock it in place. In place, all the way just like when I "watched" voltages while swapping "end of hybrid battery" hardware and computer. ...yes, the "orange plug is locked down (pressed down) on the hv battery."
    gdanner likes this.
  4. JC91006
    16,470
    8,384
    Did you transfer all your old parts to the new battery? The ecu etc
  5. DKG1011
    Kansas
    Oh ya, there was hardware to transfer as well as the battery computer itself that got transferred to the new battery. All the connectors in the vehicle were connected up to the old computer lil box. No loose connectors anywhere. Old puter installed, all connections made.
  6. JC91006
    16,470
    8,384
    You should now check your 12v battery health, what's the voltage?
    DKG1011 likes this.
  7. DKG1011
    Kansas
    Earlier it was 11.89V. The charger was hooked up to it and still did not work.
  8. Patrick Wong
    18,200
    6,464
    Time to get Mini VCI, because it is guaranteed that DTC are present.
    While you are waiting to receive that, put the 12V battery on a charger, 4A charging current position, overnight.
    Disconnect the 12V battery while you are charging it so that the ECUs have a chance to power down and lose the stored DTC.
    DKG1011 and gdanner like this.
  9. JC91006
    16,470
    8,384
    Fully charge the 12v and try again.
    This time disconnect the 12v negative for a few seconds to delete all the codes.
    #9 JC91006, Jul 16, 2015
    DKG1011 likes this.
  10. DKG1011
    Kansas
    Hmmm... 30+ minutes later went to check aux bat volts (12.7V) and "start" the vehicle. Hmm... now have Ready light. Got van out of the way and did a test drive. No oddball lights/messages, car drove fine up to speed limit+ on way and way back. All seems good now! Ready to test drive to work in morning. With working AC at last! Hope all continues well. Will post tomorrow of success or not.
  11. Patrick Wong
    18,200
    6,464
    Your photo showed one bar on the fuel gauge, and if only one bar still is present now, I hope you will purchase gasoline at the outset of your test drive. You really do not want to run out of fuel.
    DKG1011 likes this.
  12. bisco
    49,068
    congrats! and i would still charge the battery overnight. how old is it? something you might keep an eye on.
    DKG1011 likes this.
  13. DKG1011
    Kansas
    When the car went to "ready," the fuel gauge updated properly too showing 2/3 full (bout what I expected). Aux battery is "new," replaced it about 2 years ago. Drives fine to work (30 miles one way). It's nice to have working AC and Cruise!
    Patrick Wong and bisco like this.
  14. strawbrad
    953
    996
    After disconnecting the 12 volt battery TWO pushes of the power button are required to start the car. The first push will light up the dash as shown. On the second power button push the car will start normally. This applies to just the first time starting after the 12 volt was disconnected.
    Brad
  15. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    Ho
    How much did you spend on new battery hybrid
  16. bisco
    49,068
    because we all know that toyota doesn't sell 'new' battery hybrids.
  17. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    ThatThat is. Correct
  18. bisco
    49,068
  19. gdanner
    gdanner Member
    86
    39
    Central Illinois
    I do recall needing to press the "power" button on my Prius more than one time after I reconnected the 12V battery.
  20. gdanner
    gdanner Member
    86
    39
    Central Illinois
    Does anyone know how long it takes for all the ECU units in a Prius to get themselves organized after the 12V is reconnected? My guess is this might take several minutes...
