New Prius 4 moves after P is pushed
Discussion in 'Gen 3 Prius Main Forum' started by Mark Richard, Sep 3, 2013.
  1. Mark Richard
    Mark Richard New Member
    We just bought a new 2013 Prius 4 and after getting it home noticed that when you push P to park and then let off the brake, the car will roll a few inches. Is this normal or should I ask our Dealer to look at it. This is our first Prius and except for the Nav unit we love everything about the car.
    Thanks,
    Mark
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Normal. The car is just taking up slack between the parking pawl and the gears.
  3. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    Welcome to the forum. What you describe is normal. If you don't want the car to rock or move when parking, apply the parking brake before hitting "P".
  4. Mark Richard
    Thanks, It just seemed to roll a little more than our gas cars do. We hardly ever use a parking break.
  5. vskid3
    vskid3 Active Member
    773
    228
    My Prius and Escape Hybrid both do the same thing. It seems like there is more roll than in a conventional automatic, though.
  6. K9CRT
    K9CRT Junior Member
    16
    Central IL
    What is the complaint with the nav unit
  7. xliderider
    xliderider Senior Member
    7,901
    3,130
    Honolulu, HI
    Why not? Especially if you park on an incline, it will relieve stress on the parking pawl.
  8. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    That's called low rolling resistance. ;)
    And you SHOULD be using the parking brake.
  9. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    Like others, I always use the parking brake so I haven't really noticed it. I hate the feel of the car slamming against the parking pawl.
  10. fuzzy1
    10,272
    I suspect the teeth in the Park gear / pawl are rather coarse (greater pitch between teeth) compared to some other cars, so it can roll farther to get centered on a fully engaged position.
  11. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Always a good practice to use the parking brake whenever you leave the seat. It prevents accidents such as this.
    Also, you do not necessarily need to hit the P button. Powering off automatically puts the car in park.
  12. michinnom
    michinnom Member
    162
    29
    normal within ANY car.
  13. VicVinegar
    VicVinegar Member
    264
    48
    Northern Virginia
    I agree, it seems to shift more than I'm used to. As a consequence, I use the parking brake more.
  14. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    The Camry Hybrid does not roll at all, just like traditional transmission.
