New TSB for EGR and gaskets (TSB 00-27-16)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by reedog117, Apr 14, 2016.
  1. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Well since my TDI was the only one I've ever had issues that had to be addressed, for time being I will take your word for it (as you stated) because it would require more effort than I care to waste just to debate the issue...but...an engine does not need an EGR system to work.
  2. Former Member 68813
    3,524
    981
    US
    translation: i was wrong, but will not admit it.
    BTW, i love the American style of communication.
  3. Mendel Leisk
    38,316
    So fourth gen has both increased EGR, and by taking the gasses from further along the exhaust circuit, lessened the likelihood of clogging. Accordingly it'd seem they're aware 3rd gen is problematic.
    It wouldn't be so bad if it was something like a PCV valve. But the cooler component, with all it's coolant hose connections and buried, and not cheap: it's a mess.
    #43 Mendel Leisk, May 5, 2016
  4. frodoz737
    4,297
    2,348
    33
    Actually the only thing I admitted to was the inability to write code, the need to find who has or can for this purpose and the need for it on Prius...thus far.
    Out of respect to the others, if you want to continue this "discussion", bring it on in FHoP.
  5. GasperG
    GasperG Senior Member
    1,168
    598
    Slovenia
    2018 Prius
    Well, we both have 2010 Prius, it may be that we will be both reporting EGR problem in the near future, I'm looking forward to your "EGR delete" solution, after all you are an aviation engineer and you know what you are doing.
  6. frodoz737
    4,297
    2,348
    33
    A fouled or failed EGR valve is not the same as a bad valve, bad cooler, bad cooler butterfly valve, 2 leaking high temp pipes, associated gaskets, seals and compound,failed vacuum lines, expensive hardware, anti seize, cleaning one of the worst examples of intake manifold fouling I've ever seen, plus 2 days of labor on my days off...just to have the system fail again in 40K-60K miles. The results from the delete I performed on the VW were excellent, the engine never ran better and on top of that the system would never fail again.
    If needed, I could do the same for any car, including the Prius. After my fortunate experience with the 2010 Prius and subsequently sale of the VW, I replaced it with...you guessed it...a 2015 Prius...and for the record our 2014 Corolla has the 1.8L engine too.
    So to be clear what I stated...and I quote:
    #46 frodoz737, May 5, 2016
  7. Ev1lTw1n
    Ev1lTw1n Member
    37
    31
    So, if my car falls within the specified VINs for this bulletin, does that mean Toyota will take care of this work under warranty (still under 36k) even if there is no CEL or problem indicated with the car?
  8. Ginto
    Ginto Junior Member
    28
    Typically no they need to see the CEL to charge Toyota for the work. I told my coworker to report the car was knocking when cold and his dealer said you are within the TSB but with out codes we can not do anything at this time. But if your are bringing your car in for service give it a shot does not hurt to ask.
  9. Ev1lTw1n
    Ev1lTw1n Member
    37
    31
    Since I had bought my new PIP out of state, I needed inspection and emissions done. I added the TSB to the work order and when they called to tell me the inspection was done they asked about the TSB and were like...huh? They didn't see a CEL and no codes stored in the ECU so they couldn't do anything. I'm a bit miffed as it is apparently a known issue affecting cars in a certain range of VINs, yet they won't do the repair unless it actually faults. At least I am now on record for asking for it so that if it ever happens after my warranty expires, I have some ammunition to get them to cover the repair.
  10. Former Member 68813
    3,524
    981
    US
    you are confusing TSB with a recall.
  11. Ginto
    Ginto Junior Member
    28
    So just an update to the P0401 EGR issue. I got a letter today from Toyota. They will fix vehicles with this issue no mileage limitation until March 31, 2017. I did sneak past my SMOG check but the light keeps coming on. I will contact the dealer and let them replace the valve. I was leaning toward a different brand for my next car but with this Toyota will be high on my list...
    For those in need the letter is marked Warranty Enhancement Notification - ZF3
    Tbkilb01 likes this.
  12. tajlano
    tajlano New Member
    Jordan the kingdom
    helloooooooooo dear friends am tariq from Jordan
    i would ask what is the use of cleaning the EGR pipe ?
    and what is the best type of oil change for the prius 2013 ?
  13. BoydG
    BoydG Junior Member
    Marysville, WA
