No extra energy created?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, Feb 6, 2014.
  1. markabele
    5,084
    1,782
    Nebraska
    I was sitting waiting for a train today and it was so cold that even with it set at 65 the ICE wouldn't turn off, yet I watched my range go down very slowly. What's the deal?
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    turn off the auto, ICE will turn off then:D
  3. markabele
    5,084
    1,782
    Nebraska
    Thanks, that is obvious, but that's not my question.
  4. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    It's always worked like that in cold temps.
    It sucks, but there's nothing you an do other than use the seat heat and be happy to have a warm car...
  5. markabele
    5,084
    1,782
    Nebraska
    Surely there is extra energy created though, right?
  6. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    yeah....65 is still warmer than 12 over here. So I turn off the auto when I'm warmed up.:cool:
  7. markabele
    5,084
    1,782
    Nebraska
    Thanks for the input.
  8. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    How far did it go down and in what period of time? And how full was the battery?
  9. markabele
    5,084
    1,782
    Nebraska
    The battery was probably in the 45 or 50% range I'm guessing. During the 7-10 minutes I sat there it went down about .4 miles.
  10. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    We see a similar occurrence when we leave EV mode to head out on the highway in HV, the EV range seems to diminish at first but is then normalized later. Do you feel that what you saw was something different?
  11. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,999
    Fort Lee, NJ
    I have observed the same. ICE running (cabin heat) yet EV range decreased. A bit perplexing but I think this is a special mode or something unique about PiP.
    I am not sure if the actual SOC got lowered or the estimate gets (re)calculated based upon idling.
    I'll check it out with Torque app to see what's really going on.
  12. markabele
    5,084
    1,782
    Nebraska
    This is a very different situation I think.
  13. markabele
    5,084
    1,782
    Nebraska
    Ya, Torque should be able to tell us a lot more. Thanks, man!
  14. Pasaman
    Pasaman Active Member
    289
    111
    Southern California
    Mine does this also. If I'm sitting in my garage in the morning I hit the EV button to turn it off since my car needs to warm up. The miles drop from 12.6 to 11.8 within a minute or so.
  15. markabele
    5,084
    1,782
    Nebraska
    That's a whole different situation.
  16. ny_rob
    1,968
    813
    L.I.- NY
    It would be interesting to hit the "energy monitor" function on the big nav display when the OP's situation happens to see where the battery power is going...
  17. markabele
    5,084
    1,782
    Nebraska
    True. Next time I'll have to watch it.
  18. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I just came back from the store, had to use ice since it's zero outside, on the way after the car warmed up I turned off auto and my EV jumped from 7.0 to 7.8
    SGH-M919 ?
  19. Pasaman
    289
    111
    Southern California
    Forgive my ignorance but what do you guys mean when you say turned off auto?
  20. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Delete.
