No TPMS? Canadian version
Discussion in 'Prius c Accessories and Modifications' started by FireFire, Nov 23, 2015.
  1. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    Common sense says that the car should be able to at least store the IDs for 9 sensors - four summer, four winter and a spare. That would eliminate 90% of the issues that people have with them.
    Alternatively, a user-programmable means of resetting the IDs such as the one implemented on the Chevy Volt would really useful.
  2. ColdCase
    ColdCase Junior Member
    New England USA
    2015 Prius c
    I've read its only the asian built cars that require ECU programing of TPMS IDs. NA built cars auto adjust. When I swap winter/summer tires on my Jeep, it relearns the IDs before any fault is indicated. I like that Toyotas provides a set point capability (reset), however. For most other cars, the target psi is factory programmed and not adjustable.
    #22 ColdCase, Nov 30, 2015
    Jeffersonalan likes this.
  3. ColdCase
    New England USA
    2015 Prius c
    European countries have a requirement that the sensors can be disabled by the owner, same with DRLs. Presumably to encourage winter/snow tire usage. Most car companies do this by timing out the warning light after so many hours or miles. Cars built for the US won't have the disable feature. do not know what Canada requires.
  4. RobH
    RobH Senior Member
    2,369
    978
    70
    Sunnyvale, California
    High end Toyota vehicles support two sets of TPMS sensors. The extra cost is a switch to select which set is active.
  5. Mendel Leisk
    38,321
    That's interesting.
  6. Tideland Prius
    16,081
    Hmm interesting. Just like how European cars have the ability to turn off the Auto-Stop feature (but it resets to on the next time the car is started).
    Canada usually follows whatever the U.S. has.
  7. dborn
    dborn Junior Member
    44
    Montreal, Canada
    2015 Prius c
    The TPMS light started blinking again for a minute and then stays lit. Will it turn off again in the coming weeks? Still too early to tell if this is a repeatable pattern or some kind of malfunction.
  8. RobH
    RobH Senior Member
    2,369
    978
    70
    Cold weather. If you check the tire pressures, I'm sure you'll find at least one tire low. Top them all off (including the spare), and check them again when it warms up.
  9. stephane
    stephane Prius v owner
    120
    64
    Quebec Canada
    2013 Prius v wagon
    Hi Guy my first post here from Quebec, I just bought 4 xTPMS sensor from ebay and a Ateq TPMS quickset to program my winter tire by my self very easy I pay 159$ canadian racingking.ca
    now I could swap my tire and just need to push a button to change the TPMS in second
