Nokya LED Fog Lights
Discussion in 'Gen 3 Prius Accessories and Modifications' started by wick1ert, May 16, 2012.
  1. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    Guess its a good thing i've done the Fog Light only mod. :)
  2. Air_Boss
    Air_Boss Senior Member
    3,920
    1,069
    New Yawk
    If so, you may want to check legality in your neck of Whereverstan.
  3. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    uh oh...
    V C Section 24400 Headlamps on Motor Vehicles
    uh oh... Don't think my Fogs are 22" up from the ground...when I was stock let alone now that i'm lowered... :( So no driving around w/ only Fogs at night.
  4. Air_Boss
    3,920
    1,069
    New Yawk
    Aw, maybe just a little...
  5. xliderider
    xliderider Senior Member
    7,849
    3,103
    Honolulu, HI
    Your foglights would be considered auxiliary lights, so that law does not apply. However, I'm sure there is a law against using only auxiliary lights as your primary light source as well. ;)
  6. 32kcolors
    32kcolors Senior Member
    5,683
    952
    124
    Redondo Beach, CA
    Maybe use xliderider's mod to convert your high beams into yellow headlights at a reduced power and use that with the fogs?
  7. Air_Boss
    3,920
    1,069
    New Yawk
    Yes, there is.
  8. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    Not sure how that would work on a G2.... we only have 1 bulb BI-Xenon for both Low Beam and Hi Beam.
  9. Air_Boss
    3,920
    1,069
    New Yawk
    There exist 3000K yellow Bi-Xenon HID bulbs...
  10. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    As far as I'm aware - they do make bi-xenon bulbs - but not dual kelvin rating (3000k & 4300k). I mean i have the 9006 3000k HID fogs bulbs already and I know they make a 3000k & 4300k HID D4R bulb for my G2 headlamp, but I wouldn't be able to toggle between white light 4300k (normal night driving) and foggy driving with the 3000k out of the same headlight assembly. What toggles my hi - low beam is a shield w/ a solenoid - 1 bulb. Its not foggy all the time so normal white 4300k is most optimal for that - a dual capability with two different bulbs would be most optimal like the G3 have - not the G2.
    Which is why i have 3000k fogs and 6000k (prob not the most optimal kelvin rating) headlights.
    My fog lights tend to project close to the car where the headlights are further out - are you saying that that the 4300k lights negate the 3000k foglights?
  11. xliderider
    7,849
    3,103
    Honolulu, HI
    In foggy conditions, the headlights would beam higher into the fog and create a lot of glare back at the driver.
  12. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    ah gotcha. So unless i'm finding a way to add 3000k bulbs into the headlight assembly along with the normal 4300k bulb - i'm not legal in CA to drive w/ only my fogs on. :(
  13. Air_Boss
    3,920
    1,069
    New Yawk
    Bingo.
  14. Air_Boss
    3,920
    1,069
    New Yawk
    3000K Yellow Bi-Xenon HIDs
  15. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    If you know of some - please show me.
  16. 32kcolors
    5,683
    952
    124
    Redondo Beach, CA
    I didn't know you had a G2, but I think what Air_Boss meant is convert your white headlights into yellow, as I believe it's legal to drive with yellow headlights.
  17. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    Sorry to take this thread on a turn away from the original Topic of some cool looking foglights:
    In CA it is, chkd with the CA DMV. But I'd like to have both 3000k for those foggy times... and 4300k for regular driving.
    Have thought about the 3000k D4R bulb for the headlights but its only foggy in the mornings and rarely rains - the rest pretty clear and pitch black - optimal for the 4300k bulbs. Just like the option of both - thought i was doing that with the 3000k HID fogs and the 4300k headlamps...but its not legal to drive with only the fogs on unless they are 22" from the ground even as your primary lighting source in the OEM location unless i was running around like so...
  18. 32kcolors
    5,683
    952
    124
    Redondo Beach, CA
    You can always upgrade to the G3 but I like the idea of a monster Prius better.
    Justdidit likes this.
  19. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    Where can I buy a set of these ? Planning to install them in my Yaris :)
  20. Burna J
    1,063
    3,331
    53
    Long Beach, CA.
    Nokya no longer makes them… At least that's what I was told.
    After a year and half of dealing with them, and returning two defective sets. They told Tuners Depot just to refund my money, that they weren't going to make anymore. :(
    So I went these.
    Morimoto XB LED Fog lights
    sfv41901 likes this.
