North Carolina MPG
Discussion in 'Gen 3 Prius Fuel Economy' started by froSTed, Jun 10, 2010.
  1. froSTed
    froSTed Junior Member
    52
    Raleigh NC
    Unlike much of the USA, North Carolina seems to be a big drain on my new Prius. I believe it's because of hills, absolutely everywhere you go, you are going up or down a hill. Going down a hill does not seem to charge the battery well because you must always go up a hill shortly after, and into the red.
    Looks like I am getting about 35-40 MPG average so far.
    Does anyone have any experience maximizing your mileage on hill after hill?
  2. JasonPro
    JasonPro Junior Member
    72
    Rockville MD
    Unless there is a light at the bottom of the hill, I usually try to get a bit of speed up on the way down to use on the way up. I think the biggest thing though is not push the car far into the pwr range if at all on the way back up.
    One trick I've learned since getting my prius is that I get much better gas mileage when I plan on where to use up the battery power ahead of time. For example, my commute consists of side street driving, then highway, and then more side streets. I usually try to squeeze everything out of the battery just by the time I'm getting on the highway. I do this because I know the battery will charge back up on the highway anyways.
    Also, if it isn't too hot, turn off the A/C. It kills the battery fast. If I'm driving about 40 or below, I just put the windows down a quarter of the way. I know that putting the windows down all the way is supposed to be just as bad as running the A/C at around 30 MPH, but I think that only a quarter of the way down isn't as bad. I've been getting higher numbers anyways.
  3. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,155
    329
    nj
    it's all relative.
    if you had a car that got 20 mpg on the straights you would be getting 15 mpg giong up and down
  4. hsiaolc
    hsiaolc New Member
    617
    44
    UK
    I avoid the hills. You will use a lot more energy going up where as you wont gain all you've lost when you come down the hill.
    I've noticed that and so I avoide the hills all I can but if you can't then you still have a much more eco car than others.
  5. jdcollins5
    jdcollins5 Senior Member
    4,925
    1,075
    Wilmington, NC
    I have driven around Raleigh many times and average around 50 mpg. I do not do much of anything but drive the car and try to drive like the car has no brakes.
    What kind of speeds are you running? Are most of your driving short trips with a lot of stop and go? Short trips with a lot of stop and go are the tough on any car, Prius included. Do you accelerate hard in to the Power zone on starts?
    I can assure you that NC or Raleigh has nothing to do with your low mpg. It has to be something with your particular routes or your driving style.
  6. JimN
    JimN Let the games begin!
    6,528
    762
    South Jersey
    What's your tp? Harder tires=higher mpg.
  7. adamace1
    adamace1 Senior Member
    1,403
    177
    Charlotte, NC
    I have no problems, even when i have gone to Ashville or to the blue ridge parkway.
    You must be driving short trips? Please tell us more
  8. franko
    franko Junior Member
    North Carolina
    Here in the Piedmont I have no problem maintaining 50 mpg average. But we don't have a 'Beltline' (where the traffic ranges between 0 and 80 mph) and the I-40 traffic is not as heavy here either.
    I have found that in climbing up to the parkway my mileage drops closer to 40 but on descending back to the Piedmont the average for the whole trip goes right back to 50. I would not have expected that much recovery. (Admittedly, I try to avoid accelerating heavily while going uphill--Of course I am going to take care not to be a pain to other drivers).
    The one thing I notice that really drops the mileage are the 'mis-timed' traffic lights about 1/4 mile apart in traffic where everyone is compelled to hit 50-60 mph before stopping for the next light.
    But why sweat the small stuff? If you can average 40 mpg you are beating out just about every other 4 wheel vehicle on the road and you don't even have to do anything special to accomplish that.
  9. cwerdna
    cwerdna Senior Member
    12,484
    2,024
    SF Bay Area, CA
    please fill out the questionnaire
    It's hilly here in the Seattle area and wasn't flat everywhere in the SF Bay Area where I lived last.
    Please fill out the questions at http://priuschat.com/forums/gen-iii...-answer-these-questions-esp-if-youre-new.html, otherwise we're all asking the same questions over and over and taking guesses.
  10. froSTed
    52
    Raleigh NC
    Great idea, so, how do I avoid hills in NC? Fly?
  11. adamace1
    1,403
    177
    Charlotte, NC
    No just drive down them. Stop driving up them....
  12. rctech
    rctech Junior Member
    46
    Chicago
    Sometimes there are routes that go around the higher (and lower) points which are within a direct path. These alternate routes may be longer, but don't do as much elevation change (which appear to affect mpg more).
    I am sortof blessed by living in flat Chicago, but once a year I make a trek to Brevard, NC to visit the in-laws. There aren't always viable alternatives, but in some towns, I can take some alternate roads to avoid some really steep slopes, and minimize vertical travel over the entire route.
    However, it is almost impossible without experience and knowledge of a particular area's topography (and gps is no help either).
    Good Luck
    rich
  13. froSTed
    52
    Raleigh NC
    I get into the power zone allot, almost every hill requires the power zone to keep up with traffic.
  14. homersparkey
    homersparkey Older but not Senior Member
    Raleigh, NC
    I drive all around Raleigh. Yes it is hilly, but I average between 45 and 55 mpg- depending on whether I'm running the AC or not. I don't try to keep up with the fastest traffic (75+) just the traffic that's going just fast enough to not get caught :).
  15. jdcollins5
    4,925
    1,075
    Wilmington, NC
    Speed has a direct impact on Prius mpg, or any car for that matter. If you search for a link on here, Bob Wilson has a chart showing speed versus mpg.
    Once you get above 60 to 65 mph, your mpg will start dropping below 50 mpg. When I run 75 to 80 mph on I-40 around Raleigh my mpg will drop to about 45 mpg.
    With the Inner Beltline and the I-40 Outer Beltline, it would be easy to run in the 75 to 80+ mph speed range. Expect your mpg to be impacted, though.
    I have learned to try to stay at the 70 mph or less range in the Raleigh area to help improve mpg.
  16. froSTed
    52
    Raleigh NC
    When I start out going anywhere I end up in the power zone because the acceleration must be so as to not offend other drivers in back of me. Otherwise I would take the time to get up to speed slowly in the green. Also, to leave my house, I go up and down hills, to go down the street in any direction, I am going up or down a hill, and it's mostly residential, so I stick to the speed limit of 35mph. So far, I am going through about 1/2 a tank a week and I don't drive it that much. Maybe there is something wrong with my prius or perhaps I just don't get it. My Scion XB got about 35 to 38 MPG and I spent the same on gas.
  17. jdcollins5
    4,925
    1,075
    Wilmington, NC
    Are most of your trips short trips with a lot of stop and go? If so, try taking a 50 to 100 mile trip on the highway and see what your mileage does.
    Short trips with a lot of stop and go will lower the Prius mpg, like any car.
    As for acceleration, I do the same thing when accelerating and go to the right hand side of the Power zone in order to keep up with traffic. But once I get up to speed, I can let off the accelerator and coast as much as possible when traffic will allow.
    With hills and the Raleigh traffic, I understand the need to keep up with traffic but you should be able to coast as much as possible when going down the hills.
  18. Ophbalance
    Ophbalance Member
    205
    16
    North Carolina
    I'd guess this is the most prevalent reason for sure. Are you mostly just driving in downtown Raleigh? Crapital Blvd? Beltline?
  19. snead_c
    snead_c Jam Ma's Car
    664
    57
    Hendersonville
    I live in the mountains of NC and spend time in Raleigh visiting family. When I drive instead of my wife, who pays no attention to fuel econ and drives just above posted speed limits, I average 5 MPG higher than her. I get around 50 MPG daily driving at home. She just drove to Raleigh and returned driving 578 mostly highway miles...the display showed 45.8 MPG and ac ran a lot due to near 100 temps.
    One of my worst MPGs was during an extended stay in Raleigh when the temps were also very hot...38 MPG. I kept up with traffic and kept the air on high to survive.
    I guess I'd suggest you make sure you:
    Drive as "conservatively" as possible. Note numerous driving suggestions on PC.
    Keep the air up in your tires (42,40).
    Use 0w-20 synthetic oil.
    Reduce use of ac when possible.
    Experiment with MPGs when out of town and in less conjested areas for comparison's sake..
    Make yourself feel better by keeping a log of all seasons driving averages. They will go higher and you should "average" in the 45+ range per yearly numbers...if you use winter mpg strategies as well.
  20. froSTed
    52
    Raleigh NC
    I drive around the glenwood area mostly from crabtree mall up to brier creek, also I do drive the beltline where ever possible.
