Observation in heavy traffic this morning.
Discussion in 'Gen 4 Prius Technical Discussion' started by Frederickdawg, May 26, 2016.
  1. Frederickdawg
    Frederickdawg Active Member
    596
    335
    Florida Unfortunately
    Well I drove the wife to work in her Prius ( yeah I know.. ) this morning. I noticed in heavy stop go traffic, the engine was idling more than normal. Normally the EV light is on when I am stationary ( idle) in traffic, but for some reason today almost more than 70% of the stop go traffic the RPM was felt via the brake pedal and EV light was off, but the battery had at least 3 bars or more I think.
    The load on the vehicle was the usual, AC on at 65 in ECO mode and radio. I guess this question might be more a hybrid newbie question than anything else. So, just curious what "drives" the vehicle to be in EV mode when stationary in traffic or in my case earlier this morning what prevented it? Thanks.
    ETP likes this.
  2. MrMischief
    MrMischief Active Member
    426
    443
    Denver CO
    I'm finding that mine likes to run the engine more in the morning. It's not exactly what I would say is cold outside (44 degrees F, but sunny), so I don't think the car is doing it for my benefit. I left the climate control off yesterday morning to see if that made a difference, it didn't. I am suspecting that the car is using the ICE to somehow warm the battery and/or other electrical components. On the way to work I'm in the low 40 mpg, on the way home I'm in the high 60s to 70s mpg. I suspect the long cold soak overnight gives the battery chills.
  3. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    65 degrees? I'd say ambient temperature is what's causing the extra idling. As in, it's warmer now, so the AC has to work harder to keep the interior cool.
  4. DavidA
    2,326
    1,812
    Chicago western burbs
    ^ This, probably (I have a 2010). With mine, to keep it in maximum EV usage, I set the mode to ECO and set the AC somewhere between 74 and 77 degrees and the fan at two bars or less. The ECO setting lowers the AC power by 200 watts and that alone will do wonders with EV mileage. I will occasionally go lower temp or higher fan if it is absolutely stifling outside, but those settings work wonders, at least on a GenIII.
    Vintage Pep likes this.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    Many times New Prius Owners, are paying attention to everything very closely.
    Which is good and bad.
    So I don't mean to sound snarky, when I say the best advice is don't worry about it.
    Basically the two parameters that seem to influence the availability of EV the most are state of battery charge, and how warmed up the engine may or may not be.
    But I've been driving my Prius for nearly 3 years now, and sometimes I believe the engine is warmed up, the HV battery is charged enough, and still it will be resistant to going into EV mode.
    Other times, the opposite. It may be cold outside, or I haven't been driving that long, and I'll glance at the dash, and indeed The Prius is motoring along in EV mode.
    So really? Even though clearly some factors DO affect the availability of EV, the primaries being engine temp and battery state of charge, I've given up worrying about them.
    It only leads to "imagining" their might be something wrong. New Prius Owners believing something is wrong if they are "idling" more or not going into EV mode as much as they think they should.
    For the most part I judge the efficiency and evaluate the operation of the Hybrid Synergy Drive by one factor. My gas mileage.
    If my tank to tank...NOT trip to trip, but tank to tank gas mileage is good? Then I assume the Hybrid Synergy Drive is working correctly. Which means I don't worry too much on any given trip or any given moment whether the vehicle is operating on battery power, ICE, or a blended combination of the two.
    In short...to paraphrase Bobby McFerrin- I don't worry...I be happy....
  6. Frederickdawg
    596
    335
    Mmm possibly. We were already 35 mins into our journey when we hit heavier than usual stop go traffic. The temp yesterday morning outside was approx 82F I think. Perhaps a couple of degrees more than other mornings.
    The AC is typically set between 65-69F in ECO setting, with fan blower being on one or two bars.
    LG-H901 ?
  7. Frederickdawg
    596
    335
    You are correct, but also like I mentioned I wasn't really worried about it, more curious than anything else to be honest, since the behavior mentioned is new to me as I'm not a hybrid veteran.
    You also mention a very good point about judging MPG by the tank overall instead of merely a single trip.
    The other thing I noticed was a high pitch screetch type of sound as I was moving in the traffic. I could here it since there was concrete construction walls placed on the median. It definitely wasn't the EV pedestrian speaker as vehicle was not in EV mode.
    Like I said most my questions are curiosity based and they sometimes get translated to complaints.
    For the record my only real complaint is wind noise, but that was a different topic / thread. LOL.
    LG-H901 ?
    #7 Frederickdawg, May 27, 2016
    The Electric Me likes this.
  8. ETP
    ETP 2021 Prime(Limit),Highlander HYB Plat,B52-D,G,F,H
    2,799
    1,170
    Auburdale FL
    65 is the answer. The AC is a killer to MPG. Crack the window, open the vent, and set the temp to 68 with the AC off and fan on low.
    A real man doesn't need AC.:LOL:
    I never use the AC in the morning except during rain.
  9. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    "The other thing I noticed was a high pitch screetch type of sound as I was moving in the traffic."
    I'm curious about that one too. I haven't heard it on my car (yet). What could it be? Let's hear from the Prius Vets. Driving a Prius for the first time, is definitely an interesting learning experience. I seem to hear a new "Star Trek"'sound every day! What is all that stuff?! :confused: I open the door, sit down, and before I even touch anything I'm hearing all kinds of "buzzing", "whirring", etc. It's fun.
    Re: Fuel mileage. It amuses me that some Prius drivers are checking their mileage during a short 3 mile trip! I don't mean to offend anyone, but isn't that kind of silly, and not even realistic? I'm a "full tank" guy. Drive that thing EMPTY... and then tell us what kind of MPG you got. My last little 3-mile trip, ("from the flag") showed something like117 MPG. Now, we all know that's not real... so why even look at it? It's just entertainment, I guess.
    ETP and his Macho Men!
    Thanks, that one made me laugh! :D
    You got very warm weather in Florida, Frederick. I'm curious to see how my Prius performs when it gets up to 90 here. It's only been 75 recently, and I'm already running the AC every day. Doesn't seem to affect the gas mileage. And the only time I hear the ICE motor come on, is when accelerating. I've never heard it come on when stopped at traffic signals, driving in very slow traffic, etc. Or, maybe I've just tuned it out already?
    pakitt and ETP like this.
  10. Weasle543
    Weasle543 Member
    55
    38
    Ohio
    Sounds that I have observed and identified are:
    The buzzing/whirring you hear before pressing the power button is the brake pump. I believe when the driver's door is opened triggers it to cycle. You'll also hear this many times when you come to a complete stop.
    When you press the power button, from under the rear seat, you'll hear main power relay for the high voltage battery pack close. Depending upon the battery pack temperature, you could hear the battery fan begin to operate.
    If it's quiet enough and there's a bit of air in the engine coolant, you can hear the coolant and air moving through the heater core when the engine coolant pump starts running.
    If you have the climate control system on and depending upon the selected temperature and the measured temperature inside the car, you can hear the air conditioner compressor operating (remember it's an electrically powered).
    I still have not heard/identified the pedestrian warning sound.
    pakitt and Coast Cruiser like this.
  11. MrMischief
    426
    443
    Denver CO
    Yep it's entertaining! I keep the from the flag gauge up all the time for the entertainment it provides, and it shows me how I'm driving impacts milage immediately. If I keep track of the small trips the overall tank will take care of itself. I'm sure eventually this game will get boring but for now I love seeing things like 65 mpg on lunch because those are the trips where I'd get single digit MPG in the vehicle the Prius replaced.
  12. Frederickdawg
    596
    335
    It's Florida ( swamp) man, if I don't have the AC on then the humidity makes it as if it almost rained inside the car. Plus when cooler I run fan only and no AC . bear in mind, the AC is on eco mode and low blower setting.
    Perhaps the MPG got dinged after ambient temp started to exceed 91F and traffic.
    LG-H901 ?
    ETP likes this.
  13. Coast Cruiser
    2,267
    2,571
    PriUncut likes this.
  14. ETP
    2,799
    1,170
    Auburdale FL
    Got to be tough. Never used the AC while commuting to work for 14 years in Florida.:ROFLMAO::LOL:Love the heat. Vegas heat in the morning before the sun comes up is perfect.:)
    Noises are the squirrels in the squirrel cages in the cage drive. You did put the peanuts in the box?????
    Noises are for blind people to get out of the way. The other noises are start up noises. Electric shocks for the squirrels.
  15. PriUncut
    PriUncut Active Member
    268
    266
    Southern California
    Four Touring
    That brings up an interesting question: How much of a difference do you see in average MPG, when driving in the Power Mode?
    As opposed to driving in the Normal Mode, but driving more aggressive (non-hybrid) type of driving?
    Any thoughts?
    ETP likes this.
  16. ETP
    2,799
    1,170
    Auburdale FL
    Remember a thread several years ago on that. Seems it was a hit but if you have a calibrated foot it may not be a huge difference.
    Let me look.
    #16 ETP, May 28, 2016
    Coast Cruiser likes this.
  17. Coast Cruiser
    2,267
    2,571
    The only difference I notice between the 3 Drive Modes? The gas pedal gets firmer or lighter. Horsepower is the same. With practice, I believe a driver could get nearly the same MPG in all 3 modes.
    pakitt, kithmo, krmcg and 2 others like this.
  18. ETP
    2,799
    1,170
    Auburdale FL
    Well still looking. No real MPG data that I could find.
    Mine did go down in power mode on my first 3 Priuses so I don't use it at all.
    Just push on the peddle if you need power. Also I have a hard time telling the difference between normal and eco because of my calibrated foot and was never able to prove one was better than the other.
    kithmo, PriUncut and Coast Cruiser like this.
  19. Coast Cruiser
    2,267
    2,571
    Agreed. I drove the first month in Eco mode. 2nd month in Normal mode. Gas mileage was exactly the same; maybe even a bit better in Normal.
  20. ETP
    2,799
    1,170
    Auburdale FL
    You too???? I wasn't going to say that.:ROFLMAO::LOL: However it does seem to do better in eco with my wife driving.
    It may be driver related. Maybe people in a hurry need to be in eco mode. Turtle power is just turtle power for me.
    Most likely!
