odometer accuracy
Discussion in 'Prius v Fuel Economy' started by schinia, Jun 19, 2013.
  1. schinia
    schinia Member
    162
    25
    cape carteret,nc
    OK, "you can take this to the bank" i had a 2009 toyota Venza, and took a trip from Cape Carteret, NC to Cairo, NY. three trips in the Venza, same route, three times trip was 765 miles +or- 3 miles (due to finding eats or motel) one trip in Prius v, 800.3 miles. will post return trip mileage. it sure makes the MPG look good.
  2. woppa
    woppa Junior Member
    60
    NYC
    2013 Prius v wagon
    Wth??? This is a serious problem if this is true.
  3. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    I'd like to know if it's a serious problem too. Not only does it effect gas mileage calculations, but also mileage for warranty purposes. I know v5 has different tires the v2 or v3, but the rotation difference between tires should be very small. I had check my '10 Prius IV with my GPS phone app and knew it was off slightly with the original Yoko tires, but when changed to new Bridgestones, it was dead-on accurate.
  4. rdgrimes
    rdgrimes Senior Member
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    Might require more than one trip to rule out things like "user error". Most major freeways have "odometer check" sections every so often, and you can also use the mile posts for a rough estimate.
    Most cars register 1-3% faster than they are actually going, this is by design. Haven't had a chance to check the V yet.
    Its also very possible that in the OP case, the Venza was wrong.
  5. jhinsc
    1,167
    259
    South Carolina
    Honda had this problem several years back and they compensated owners with longer warranty periods, and extended the mileage on their leases. I downloaded a GPS app and will check my miles going home tonight and report back.
  6. woppa
    woppa Junior Member
    60
    NYC
    2013 Prius v wagon
    This also effects resale.
  7. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    Prius odometer is actually slightly pessimistic. When you have gone 100K miles, you have really gone slightly over 100K miles.
    Tire size makes a huge difference. If either car has been through a tire change where the tires weren't exactly the same size as the ones specified, the odometer and speedometer would be off.
  8. schinia
    schinia Member
    162
    25
    cape carteret,nc
    the Venza had new tires put on it but they were the same as the replacements. also the mileage was taken with the original equipment. near the end of the trip, i compared the mile marker's w/the prius's odometer which wasn't keeping up. (the prius wasn't keeping up) the nysthruway's (which i retired from) mile markers are extremely accurate. go figure.
  9. rdgrimes
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    If the Prius isn't "keeping up" with the mile markers, then its registering LESS distance, not more. If its ahead of the mile markers then its registering more mileage.
  10. jhinsc
    1,167
    259
    South Carolina
    Tonight going home I traveled 25.5 miles according to my Prius v's odometer, but my phone GPS app said I traveled 25.36 miles. This represents a difference of .552%, much lower than the OP's difference of 4.575%. If my GPS app is accurate, over actual 50,000 miles, my odometer will read 50,276 miles. I am okay with this difference.
  11. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    That is more in line with the real world data and the error is purposeful.
  12. schinia
    schinia Member
    162
    25
    cape carteret,nc
    return trip 797 miles. using different roads mile markers, as I 95, I81, I84. the odometer was racking miles faster than the roads miles. i couldn't use the gps nav unit because when i put in home, it wanted me to take a certain route, and when i kept taking my best way it kept changing the miles. i need to find a better way to measure the miles.
  13. rdgrimes
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    You should expect ANY odometer/speedometer to be fast by 1-4%. They are designed that way. The MPH error in the speedometer will increase as speed increases.
  14. schinia
    schinia Member
    162
    25
    cape carteret,nc
    end result- OD miles 1,759.4 used 42.8 gal i get 41.1 miles per gal. this is at speeds of 65 mph to 77 mph. sound a bit much? if you subtract the 67 miles (i believe is over) i come up with 39.5 miles per gal. more believable? car was filled to almost overflowing each time, (started with full tank, and ended with a full tank) i know how many gallons i used. it's the miles i'm not sure of. unless i take the route i'm handed, then i can use the gps in the car. but i was unwilling to thru washington DC (with countless tractor trailer traffic, and the garden state pkwy,ect) what i do know is how many miles i travel a year (12,000) maybe keep track of the gallons, and calculate it that way, and leave it at that.
  15. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    GPS doesn't take road gradients into account so is only accurate on flat roads.
  16. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    That doesn't matter on normal highways.
    A continual 6% grade will only introduce a bit less than a 0.2% error, or less than 0.2 miles in 100 miles. Do the math.
  17. jhinsc
    1,167
    259
    South Carolina
    The roads in my area are mostly flat, except for the occasional overpass being the only elevation I experience.
