On startup no outside temp, mpg stuck at 100mpg
Discussion in 'Generation 1 Prius Discussion' started by Prodarwin, Sep 16, 2014.
  1. Prodarwin
    Prodarwin Junior Member
    30
    2002 Prius
    I tried numerous methods of searching for this, but I'm quite sure I don't know the correct terminology to use.
    2002 Prius, ~165k miles. When I first start the car, the first 30 seconds or 1 minute the "Consumption" display will show no outside temp and the mpg gauge stuck at 100mpg. After warming up (I use that term loosely as its still 70s/80s here), it will operate like normal. Shutting the car off and turning it back on will not bring the issue back - the car will need to sit for a few hours or overnight for the problem to come back.
    Any ideas what is going on here?
  2. ChapmanF
    15,110
    Strange intermittent failure of the gateway ECU? During that first 30 seconds or 1 minute, are you fast enough to bring up the MFD's diagnostic screen and see what shows as ok/not ok in the service check mode?
    -Chap
  3. bwilson4web
    15,407
    He can bring it up to IGN and as long as the engine is not started, get a chance to monitor the controllers. Need to verify IGN does not have the effect of 'running the clock' that leads to the condition cleared.
