Optima battery delivered sideways...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sorka, Mar 13, 2012.
  1. sorka
    sorka Active Member
    1,004
    196
    Merced, CA
    2019 Prius
    My new Optimia Yellow Top came today. It was left on the side with the arrows pointing sideways and not up. I have 4 MP high surveillance and one of the cameras clearly recorded the delivery van and showed the box also on it's side when the rear door of the van was opened, so it wasn't just the brief time it was in my breezeway.
    Aren't the Optimas a spiral gel-cell design and if so would it be ok for them to be on their side. I'm assuming so, but the arrows saying to stay up would seem to indicate otherwise.
    Should I contact elearnaid first and see if the battery should be exchanged?
  2. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    I dont think Optima batteries are so sensitive. If so, they should have some indication of the inproper handling. IMHO, it is just a safety measure for the transportation.
  3. cnschult
    cnschult Active Member
    772
    96
    Michigan
    whether it affects the optima or not, that is just unacceptable of the carrier, most things in the world probably aren't built as well as an optima.
  4. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    58
    Fullerton CA
    Optima Yellow Top Battery - Deep Cycle YellowTop Batteries
    says:
    Completely spill-proof, mountable in many positions
    I would infer that you don't need to worry.
  5. wjtracy
    wjtracy Senior Member
    11,329
    3,593
    Northern VA (NoVA)
    Sounds like batt OK but you might advise elearnaid for their info. Mine was packed so well with foam inserts etc it would not budge. Kept some of the foam, use it under my jack to protect floor.
  6. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    Yes.
  7. HyperFX
    HyperFX NIMFY (not in my front yard)
    81
    35
    30
    New Jersey
    You should be fine. The battery is gel based so think of it like Jello but harder. As long as your battery terminals aren't damaged, your good to go.
  8. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Doesn't matter, all is well.
  9. malibucarl
    malibucarl Member
    237
    Malibu, Ca
    Both mine came the same way and worked fine. They are packed securely.
  10. OptimaJim
    OptimaJim Member
    74
    Wisconsin
    sorka, I'm sorry to hear your shipper did not transport the battery as indicated by the instructions on the box. However, as others have indicated, your battery should be just fine. Our batteries can be mounted in a variety of orientations (although we do not recommend mounting them upside down) and many of our batteries spend their entire existence mounted on their side.
    Jim McIlvaine
    eCare Manager, OPTIMA Batteries, Inc.
    Optima Batteries (@OptimaBatteries) on Twitter
  11. bstephens
    bstephens Junior Member
    36
    Oklahoma
    Oh look at that; the Optima internet guy is monitoring our board! Makes me glad I went the Optima route!
