1. Offline
    shagzie New Member
    Aug 5, 2007
    I've got under 12,000 miles on my 2008 hybrid highlander and the tires are almost worn out. I don't drive this car hard or fast. I'm getting about 29mpg on every tank here in the mountains of WV.
    I just looked on tirerack and they only show bridgestone as the correct size. The reviews on that tire show that the wear is almost as fast as the stock tires.
    My last SUV was a Jeep Grand Cherokee had the original tires lasted over 75,000 miles. Is there not something like that for this car? Am I going to be forced to buy new wheels just so I can get a normal tire?
    Anyone else noticed their stock tires wearing quickly? Anyone had to buy a new set of tires yet?
    A firend of mine said his parents have a toyota sienna and they got free tires from toyota at 18,000 because the wear was so bad. I have not tried going up the chain of command at toyota yet with this complaint but wanted to check online to see other's experiences first.
    Thanks!
  2. Offline
    morpheusx Professor Chaos
    Mar 6, 2007
    1,514
    Akron, OH
    Your Vehicle Year:
    unfortunately OEM tires on nearly all cars have taken a dive in quality. I have noticed the same Goodyear Integrities that came on my Prius on alot of new cars everything from Dodge Chargers to Lexus'. The tires not only wear incredibly fast they handle very poorly when half the tread is still left.
  3. Offline
    Mar 8, 2008
    9,153
    1,793
    Your Vehicle Year:
    My 2006 HiHy 4WD-i came with 225/65R17 Goodyear Integrity tires. I replaced them at 6K miles as they were ~40% worn and I was planning a snow trip. I bought Bridgestone Dueler H/L Alenza and they are a big improvement.
    I assume that you have 19" wheels since you say that Tirerack only shows Bridgestone tires. If you move down to 17" wheels you'll have a much bigger selection.
    Compare Tire Search Results
  4. Offline
    PRIGREEN New Member
    Jun 26, 2009
    denver
    Your Vehicle Year:
    I am on my second set of nokian wrg2's. I got 53,ooo out of my first set. Unlike my integrity's. The only down side is they're like $750 for a set. But compared to the $550 for the integrity's it was well worth the extra $200. Plus they are made from canola oil. They're "green" tires. You should check out the website @ nokiantyres.com i got mine from boulder toyota
  5. Offline
    jumpsuit38 New Member
    Jul 15, 2009
    georgetown, tx
    Your Vehicle Year:
    I am considering buying four new tires for my 2004 Prius with a little over 50,000 miles. I came across what appears to me a very good deal on tirerack.com -- namely
    Sumitomo HTR H4 (High Performance All-Season) $55 apiece.
    Anyone got any info on this tire-- it rated high against many higher priced tires.
    I forgot to add, the dealer said my tires are ok, but I'm wondering if I should push it and keep driving on my original Goodyear tires until the dealer says they need replacing or go on and bite the bullet and buy some new tires now?????
  6. Offline
    TKY New Member
    Jul 7, 2009
    231
    24
    Colorado
    Your Vehicle Year:
    Jumpsuit, Check your tires your self. The tread depth is easy. Check a couple of spot on each tire. If the tread is getting too shallow or the steering and ride control starts to feel uncomfortable, replace the tires. If you have a tire pressure gauge, check to see if it has a depth gauge indicated on it. If not, a good rule of thumb is to use a penny with the crown of Lincoln's head into the tread. If you can see the top of his head, the tire has less than 3/32" (original entry was typed late and fast, ignore the previous listed fraction) of tread and that is considered too little tread in most states (But check the statutes in your state to be sure.) --TK
  7. Offline
    Mar 8, 2008
    9,153
    1,793
    Your Vehicle Year:
    40K miles on my 2006 HiHy 4WD-i including 34K miles on the Bridgestone Dueler H/L Alenza tires mentioned in post #3 above. Those tires had ~5/32" of tread remaining when measuring the center of the tread; the sides were more worn.
    Since we'll be heading to Lake Tahoe soon for our annual December trip, I wanted to get new tires. I decided upon Michelin Latitude Tour and have applied for the $70 Michelin rebate. The new tires are quieter than the Bridgestone tires since they have a less aggressive tread pattern. We'll see how they do in the snow.
  8. Offline
    Jack_K New Member
    Mar 10, 2010
    Bettendorf, IA
    Your Vehicle Year:
    My experience was similar with my 2008 Highlander Hybrid Limited with P245/55R19 tires. I found three matches on TireRack.com and was going to go up to a P250, but my Toyota dealer said the hybrid and AWD computers required staying with original size. I live in IA, and travel to the Upper Peninsula in MI at Christmas and winter in CA so I needed better tire traction than the Bridgestone All Season. I bought the Blizztech, and know I will wear these out sooner than I expect, but I wanted the traction. I am very pleased with the Bridgestone Blizztech in snow, freezing rain and heavy rain, as well as desert sand and mud. But, I am concerned about mileage (yet to come).
    Jack
Share This Page
