Owner of a new Blizzard Pearl/Advance Questions/Concerns
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by jverdin, Mar 27, 2012.
  1. jverdin
    jverdin New Member
    28
    Alabama
    Great car, Love it! It's a big improvement from the 2006 Prius.
    Concerns
    When applying the brakes and holding the pedal down, I notice that the indicator for slippery/traction yellow icon appears in my dash when completely stopped.
    There is no map option on the steering wheel that allows you to switch back to the Nav/Map system on the HD display. Is there a voice command?
    My Entune app updated and worked the first day I had it, but now it doesn't work and the charging station location option doesn't work.
    My charge sometimes goes up to 13.1 but in some instances it only goes up to 11.1. Any ideas?
    Btw: I found a lock that fits the hole on the charger plug. No drilling necessary!
    When would I use ECO? I use HV/EV during interstate driving but not quite sure when to use ECO.
    Thanks for the feedback..:)
  2. spiderman
    spiderman wretched
    7,473
    1,450
    Alaska
    Nice upgrade!
    On the first concern... it sounds like you might be activating the hill-assist function. Do you hear a beep when the light comes on and two beeps after a few seconds after you release the brake pedal?
  3. SimiPrius
    SimiPrius Member
    247
    60
    Simi Valley,Ca
    For the second item, that should be a programmable feature on the NAV option screen to automatically revert to the map.
  4. Allannde
    Allannde Just a Senior
    871
    135
    Washington State
    You must have a ScanGauge. I find that the higher charge reading comes first. Later there is the lower charge rate. Since everything seems to be working properly, I presume that the higher charge rate happens when there is "recovery" charging and the lower charge rate happens when it achieves "maintenance" level charging.
    I expect my PiP any day now. I hope to know more, soon.
  5. ClaySacramento
    ClaySacramento Junior Member
    58
    Sacramento, CA
    I have noticed the slip indicator light at least once while breaking at a stoplight. I don't remember if the light was flashing or if I heard a buzzer, indicating that I had activated Hill-start assist control, but I'll pay more attention if I see it again. The owner's manual shows the following about this indicator light:
    I've also noticed hit and miss performance when attempting to use Entune. Usually if I force quit the app on my iPhone and re-open it, the car will start communicating with it properly.
    Page 247 of the owner's manual shows the following about ECO mode:
    If you prefer the accelerator pedal response when ECO mode is on, you can leave it on at all times (in EV or HV mode). If you don't want the air conditioning performance to be limited by ECO mode, a Toyota dealer can turn that off.
  6. SimiPrius
    SimiPrius Member
    247
    60
    Simi Valley,Ca
    Not sure I would agree. If you are only showing 11.1, and you drive normally, that is all you will get vs some that consistantly gets 13.3 and drives normally. They will have almost 20% more of additional range.
  7. H2OSkier
    H2OSkier Member
    272
    Did you ever determine if there was an issue with your car ie just getting to 11.1 ?
    Mine does seem to bounce around. The first couple of charges were 11.1 then some at 13.3.
    Ken
  8. jverdin
    jverdin New Member
    28
    Alabama
    Thanks everyone for your input. You have anwered just about all my questions! I need to check on the NAV option. I hate having to hit the Nav button on the dash to see the map.
    I believe I heard a beep or two when applying the brakes. I will listen more carefully next time.
    Thanks,:)
  9. ryogajyc
    ryogajyc Active Member
    985
    158
    Reseda, CA
    The EV miles range adapts based on how your car is driven. If driven in difficult terrain and/or with heavy acceleration, the max EV miles will go down and vice versa.
    Yep, me too. :)
  10. H2OSkier
    H2OSkier Member
    272
    Ok you two are you going to let us know what lock you bought ? :)
  11. ryogajyc
    985
    158
    Reseda, CA
    It's actually not that hard to find. The straight section of most luggage locks will fit in the locking hole. I couldn't the exact lock I'm using, but this one is pretty close:
    Products - Set-Your-Own Combination - 4687DNKL - Master Lock®
  12. jverdin
    jverdin New Member
    28
    Alabama
    Absolutely, Master Lock model #4680DNKL, works great!:rockon:
  13. kstitt
    kstitt Junior Member
    San Bernardino
    How hard are you depressing the brake pedal? I noticed that I inadvertantly activated the hill start assist control by depressing the brake pedal very hard. Try less pressure on the brake pedal.
  14. jverdin
    jverdin New Member
    28
    Alabama
    Hard enough to stop the flow of power from the battery to the electric motor.
    Thanks,
  15. 4MsPrius
    4MsPrius New Member
    Raleigh, NC
    Jesse, I had the same question:
    from nav to map and vice versa. Could not find it in the manual. Is this true that we can custom this?
    the lock for the charger plug, is this something that came with the prius or had to purchase!
    thanks
    4msprius
  16. SimiPrius
    SimiPrius Member
    247
    60
    Simi Valley,Ca
    Master Lock 4680DBLK - on Amazon for about $10
  17. Tideland Prius
    3,379
    40
    "Map" or "Show Map" voice commands will bring the screen back to the map screen (at least with my Gen 6 Denso unit)
